Question about Dishwashers
Water backing up into sink
Does the DU943PWK00 have a food disposal? Dishwasher works find until draining cycle, when it backs up into the sink.
  • 6,784 Answers
This unit dose not have a on board disposal.
Posted on May 26, 2009
Water backs up from the drain in my dishwasher and smells. what is the problem?
Two things can cause this problem:
1. The check valve in your dishwasher may be defective, allowing water and food debris to seep (or run) back into your dishwasher.
2. Your drain hose may not be "mounted up" the way it should be. Look under your sink. Look at how your drain hose is connected to your garbage disposal. If the hose runs down to the floor of your cabinet and into your dishwasher, that is wrong. Instead, it should be mounted up so that water from the sink and garbage disposal would have to flow up first to get into the dishwasher. If you do this, then even if you have a bad check-valve in the dishwasher, it will prevent the problem (or greatly reduce the problem) of dirty water flowing back into your dishwasher.
May 17, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
Frigidare dishwasher did not spin
  1. Waste Disposal/Sink trap
    • Empty your food waste disposal unit if your dishwasher's hooked up to one. If it's not empty, the old food inside it will back water up into your machine. Check that your sink trap isn't blocked by unscrewing it from the base of your sink if you don't have a food waste disposal unit. Make sure your dishwasher or any other appliances connected to it are not running when you do so.
    Incomplete Cycle
    • You may have opened your dishwasher's door mid-cycle before it's had a chance to drain. Check the progress indicator on your machine's control panel. The structure of this will differ depending on which Frigidaire model you're using, but it should show the point your machine has reached in its cycle. If this is the cause of the problem, close your dishwasher's door and let it finish.
    Drainage Pipe
    • Inspect the drain pipe that runs from your machine to your waste disposal unit or sink. If this is kinked or has been squashed under another appliance or a base unit, the waste water inside your dishwasher will be unable to escape. Check that water can flow through your waste pipe freely.
    Filter
    • Remove the bottom shelf from inside your machine and take out the plate covering the filter area. If you don't rinse your plates before you put them into your washer, food debris could block your filter and stop water from reaching your drainage pipe. You can unblock your filter with your fingers. Turn off your machine's power before you attempt to do so.
Feb 02, 2012 | Dishwashers
Water in the bottom and not working
Check for a clogged drain (e.g.: via drain hose), or a water pump malfunction due to foreign obstruction (e.g.: glass, etc).
Note: If you changed a food waste disposer (kitchen sink area) and did not remove "plug" from disposer for dishwasher drain hose (assuming dishwasher drain hose connected to food waste disposer), then water cannot drain from dishwasher.
Apr 14, 2010 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Dishwasher overflowed, garbage disposal still works. Ran the dishwasher and noticed food and debris shooting back into sink thru garbage disposal. Water was on floor. Upon completion of full cycle, water...
Before loading into the machine you have to remove food particles. Washer will wash the greasy surface. If particles are left in the dishes, the same will find entry to the drain system. Check the drain filter in your machine. Clean them. Mostly problem will be solved!
Apr 08, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
My dishwasher backed up into my kitchen sink , it was about 30 minutes into a 2 hour wash cycle--i drained the diswasher, but 1 inch stayed in it till this morning, the sink drained on its on
It sounds like an issue with the sink drain rather than the dishwasher. Many dishwashers are connected to a double sink, one bay of which contains a garbage disposal. If yours is connected in that configuration, run the disposal to clear any food debris that may still be present while running the HOT water into the disposal.
If you have no disposal or if the dishwasher is connected to the other non-disposal bay, check the sink drain again for proper drainage.
The easiest way to do this is to put a plug in the drain (both sides, one at a time), then fill the sink about half way with luke warm water. Then reach in and pull the plug from each side, watching to see how each side drains, but especially the side with the dishwasher connected. If it's slow draining, focus your efforts on clearing the drain on that particlular side of the sink. Try a plunger first before resorting to other methods to clear the sink. If you plunge the dishwasher side, get underneath the sink and pinch off the discharge line from the dishwasher if possible. A pair of vise grips works well, but don't overtighten them.
Some dishwashers have a soft disposal that can eject enough ground up particles into a sink to cause plugging up over time, especially if the dishwasher empties into the disposal side.
Jan 20, 2010 | Whirlpool 24 in. GU980SCG Built-in...
Cycle finishes but water is not draining
Sounds like too much water leftover.
Give me a make and model number of the dishwasher.
Check that the drain hose isn't kinked, and that where the drain connects at the garbage disposal at the sink isn't partially clogged. And, is the garbage disposal clean/clear of food stuff's.
I had a similar thing happen to me a few weeks ago, and it turned out the kitchen sink drain line was clogged.
Dec 16, 2009 | Cars & Trucks
2 weeks ago, I had a plumber come and put in a new garbage diposer and since then somewhat old/dirty water seems to be sitting at the bottom after all cycles are done. I calle dhim back and he says that...
There is a breakaway stub in the garbage disposal's dishwasher hose port, it needs to be removed before connecting the dishwasher drain hose when installing the disposal.
Disconnect the dishwasher drain hose at the disposal, get a screwdriver and, insert in the disposal's dishwasher drain port and tap on it with hammer until it breaks off. Then remove that stub from the sink side.
Oct 14, 2009 | GE 24 in. Profile PDW7800 Built-in...
There is water in built in dishwasher when cycle is done.when you open door it runs out and rest remains in bottom of dish washer about an inch and a half of water.
The drain hose is supposed to go from the garbage disposal to a high point under the sink in back to keep the water from gravity draining into the dishwasher when it shuts off. If you look you will see that the hose is laying on the bottom of the sink cabinet. Get a hook and wire it up so you're not washing dishes with water from the disposer. Be sure to run the disposer. if it is clogged with food the dishwasher will not drain, water will back up and drain back into the dishwasher. Also make sure that the pipe exiting the disposer isn't clogged and draining slowly. hhe best solution is to have an air gap that mounts on the sink. It goes between the washer and the disposer to keep this from happening.
Mar 25, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Dishwashers Logo
75 people viewed this question
Top Dishwashers Experts
