Question about HP OfficeJet 7110 All-In-One Thermal Printer
HP 7110 printer paper rollers
How can I replace the rollers for my printer.  It keeps feeding too many sheets, or none.  Where can I find replacement rollers?
  • 1,003 Answers
Usally when a printer picks up too many sheets the pickup rollers are dirty or covered with paper dust use a microfiber towel moistened with water or rubbing alcohol wipe them off then if it still picks up too many sheets the surface of the pickup roller is worn.replace pick up roller the printerworks .com may have parts or hp
Posted on Jan 07, 2008
HP 5100 paper feeding problem
Hello Paper feed problem are usually caused by worn feed rollers and separation pads. If you printer can not pickup the paper or pulls more than one sheet into the printer at a time then the rollers and pads need to be replaced. This is a user replaceable kit. You can get the kit here:
Apr 19, 2013 | HP LaserJet 5100 Printer
My HP5200 13.20.00 Paper Jam
sounds like your fuser sensor or the fuser is bad
Jul 28, 2017 | HP LaserJet 5200 Printer
A sheet of paper keeps getting jammed - we remove it and try again but it keeps jamming. We have cleaned the rollers inside where the cartridge goes and it did not help
If the first sheet of paper is correctly feeded and it shows up after fusing unit and that happends every time, then probably you have damaged exit paper sensor. It have to be replaced with new one.
If the paper feeds only few santimetres then you have to replace paper feed roller
Feb 23, 2011 | Samsung Office Equipment & Supplies
Single sheet paper on my HP LJet 1100a works fine
There is a recall fix on this printer if it has specific feed problems like pulling in multiple sheets etc. Might be related. You can contact HP and they'll send you a DIY fix kit to replace the rubber that pulls the sheet in and onto the rollers.
Feb 07, 2010 | HP LaserJet 1100 Printer
My laserjet 1020 develops a paper jam after printing the first page of a multipage print instruction .I have deleted the printer and re-installed it including all drivers but problem still...
Reinstalling the printer is related the Software.
If the paper gets physically jammed than its the driver setting issue or hardware issue.
Check if two sheets get jammed or only one sheet.
If it is two sheets than printer is picking up multiple sheets and paper gets jammed.
If the printer is jamming a single sheet than remove the Tray and look there is rubber roller inside if there are marks or lines on that rubber roller or if the roller roller is worn out than that rubber roller called as paper pickup roller need to be replaced.
If that looks fine than try to priny using manual feed and if the problem persists from manual feed too than try another toner cartridge
If the problem is not from Manual feed Tray that Replace the main Tray with known good Tray and check if the issue resolved.
Jul 01, 2009 | HP LaserJet 1010 Printer
HP All in one 7110 powers up fine, printer roller is not working
Remove the rear axis door and then try to clean the rollers with a soft cotton cloth and then try to print again. The rollers might not work if there is any dust and pieces paper got struck in the rollers.
May 20, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Hp LaserJet 1100: Runs louder than normal and continuously, BUT will not grab paper and print
Fred shine a flashlight down the paper feed throat and see if the feer roller is rotating when the printer tries to print.
I have had to replace many of the feed rolls and separation pads in this series of printer.
the tires get dirty or worn and feed multiple sheets or none at all. check for obstructions as well-sometimes the black mylar sheet which sits in front of the feed roll gets in the way of the paper path and has to be pushed in place. I have also seen paper pieces stuck next to the paper path switch which is visible after removing the toner cartridge. hope this helps.
Mar 28, 2008 | HP LaserJet 1100 Printer
Multiple paper feed
The paper separator pad is worn out and will need to be replaced. It's a rubber pad that rests behind the paper pickup roller and is supposed to prevent what you're experiencing. Contact your nearest authorized HP repair center.
Apr 13, 2007 | HP OfficeJet K80 All-In-One InkJet Printer
HP OfficeJet 7110 All-In-One Thermal Printer Logo
274 people viewed this question
Ben Johnson
