Question about Mitsubishi TS-50611 50" Rear Projection Television
Mitsubishi TS-50611 projection tv has no video
Everything on the tv works except there is no picture. The set worked earlier today, but we also had a thunderstorm move through earlier. Is there any type of reset or is the tv done for???
  • 1 more comment
  • brenda808502 May 26, 2009
    hatman1,
    Thank you for responding.....After unplugging the set and waiting 10 mins, there were no lights from the LED when plugged back in. I pushed the power button and the set came on, LED stayed a solid green. Tried the Menu and Input buttons and the LED never started blinking....just stayed solid with the set on or off (held for 30-45 seconds both ways). Still have audio but no video. Other suggestions???
  • brenda808502 May 27, 2009
    Thank you again for the info! I will definitly check in to finding a repair shop around here and see about getting it fixed. I can repair about any printer, monitor, computer, laptop, fax or copier out there, but haven't messed much with tv's at all. I truely appreciate your help! If the part is somewhat easily accessible, could you email me with general location. I can usually fix about anything as long as I have a general idea what is wrong and where the parts are located on the units. My email is brenda808502@yahoo.com. Thank you again so much for the help!
    You are probably right. I have worked on several computer monitors, but they have pretty well become disposables any more, so it has been a while. I do have a good idea what you are talking about tho, and I do appreciate the help! They are pretty touchy. I will post and let you know when I get someone to come out and fix it. You've been a tremendous help!!!
  • 126 Answers
You can do quite a bit to narrow things down....
First thing, unplug the set and wait 10 minutes. Then plug it in and watch the green power LED. If it does nothing push the power button and watch the power LED. If the set doesn't respond hold down the MENU and INPUT buttons on the front of the set until the LED starts blinking. If it blinks at this time count the blinks and then repost.
Posted on May 26, 2009
  • hatman1 May 27, 2009
    Well, you may think that the response you just gave would mean very little. But actually it tells me volumes. It has been my experience with that model that the only thing that can allow the set to come on with audio but no pix is a failure of the vertical sweep circuit. It's a little compicated but if the vertical circuit stops the microprocessor blanks video to protect the picture tubes but leaves the audio alone. You either have solder problems in the vertical circuit or it will need a new vertical output IC. Either way this is a job for a reputable tv shop. The average repair cost would run around $200 to $300. And BTW that is a good set worth that repair.
    Sorry, no emails, however the first place to go is the solder connections on the deflection yokes. But you have to understand that no matter how 'handy' you are if you don't understand the nomenclature of a technical nature as respect to the workings of a television this is gonna get a little rough. From the front of the set remove the speaker grill and then the front access panel beneath the screen. On each picture tube neck is a deflection yoke with a plug in connector on the right side. This connector plugs into a small circuit board and on the back side of the where the pins are solder you may see 'ring cracks' on the top two pins. Those are for vertical. If bad they are causing the no picture. You will have to use a small mirror to even see them. And they a almost impossible without rotating the yoke. Once you do that repositioning the yoke is real tricky and if done incorrectly you will get colored ghosts of the color of the particular yoke you moved. If you mess with all of that a professional tech will have to charge more to correct for problems you have induced. Sorry, but I don't really believe this is a repair for the handiest of all but professionals.
All of a sudden, last evening while watching, I got colored shadows around the images, like watching 3d without the glasses. Trying "convergence" I am only able to align the center...
hello spititttome!
seems like one of the color tubes is worn out, it has to be replaced. contact your local service, and let them tell you before repairing how much it will cost. so you can decide to repair or buy a new one,
regards
Feb 27, 2011 | Mitsubishi TS-50611 50" Rear Projection...
Lost remote, blue screen
Sounds like you're stuck on..... Video 1 or Video 2 (whichever). If you can access your TV's menu at the front panel, you should be able to switch over fairly easy. Hit MENU. Using your VOLUME UP & DOWN buttons, Go to CABLE/SATELITE/ANTENNA, hit VOLUME UP or DOWN 'til it switches back to TV picture then hit ENTER. If you do not have an access panel in front but possibly have any other remote (cable or satelite or home theater, etc...) that can be paired with this TV and has an INPUT button, you can change the setting that way.
Hope this info was helpful. Good Luck!
Jan 29, 2010 | Mitsubishi VS-50611 50" Rear Projection...
No video but have sound everything works except picture lamp has been replaced
Ballast Board or you have a defective Fan, if Fan stops running set will shut off.
Dec 12, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi TS-5053 rear projection TV-Sound but no picture
First make sure to hit the menu button on the TV's remote and if nothing is there then friend while the set is on turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working.
You can also check the transformers they are close to were the wires plug into the panel, make sure all transformers read the same amount of resistance if not you have found a bad one. Now you will have to check to see if the power supply is sending 24v to the backlight, if not the power supply is bad. Cost backlights around 150.00 and power supplies around 100.00. Well this should help you friend.
Oct 19, 2009 | Televison & Video
TV powers up green light is solid and no picture
>>The first thing to do is a system reset using the recessed button on the front panel.
>>If that does not work, unplug the set and let it sit overnight
SYSTEM RESET button with a pointed item like the end point of a paperclip.
Jan 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi
you need to do self test first look in threads and also ctechnicians.com to get error codes.
Dec 30, 2007 | Mitsubishi VS-50611 50" Rear Projection...
Televison & Video Logo
524 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
