Question about Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M
Fuel mix wrong, won't fire smokes once in a while
Sorry Canadian metric here does the mix mean a 40:1, or a 30:1 what is 1/4 oz to 4 gallons ?
  • 376 Answers
40:1 =40 parts of gas to 1 part oil. If you run 1/4 oz oil to 4 gallons of gas, you will fry a two cycle. That's like running straight gas.
Posted on May 26, 2009
  • 284 Answers
1 unit divided by 40 units.
1/40 = 0.025 (but how many ounces is .025 of a gallon???)
1 US gallon of gas = 128 ounces, 128/40 = 3.2 ounces
1 Imperial gallon of gas = 160 ounces, 160/40 = 4 ounces
1 liter = 1000 milliliters, 1000/40 = 25 milliliters
4 liters = 4000 milliliters, 4000/40 = 100 milliliters
Posted on Jul 05, 2009
WHAT IS THE OIL TO GAS MIXTURE IN OIL TO GALLONS
Mixing
RatioGAS:OIL UNITED STATESOIL per 1 U.S. GALLON Gasoline
(128 oz.) *INTERNATIONALOIL per 1 IMPERIAL GALLON Gasoline
(160 oz.) *INTERNATIONALOIL per 1 LITER Gasoline
(metric) 32:1 4 oz. 5 oz. 31.25 mL 40:1 3.2 oz. 4 oz. 25 mL 50:1 2.6 oz. 3.2 oz. 20 mL
May 04, 2015 | Garden
Oil petrol mixture for Rockwell 26cc weedeater
Two cycle engines run on a mixture of gasoline and oil. Each engine type is designed to run on a specific gas-to-oil mix ratio.
IMPORTANT: Use only oil that is labeled for use in "Two-cycle" or "Two-stroke" engines. Home Depot and other stores now have "premixed fuel" of gas and 2 cycle oil.
To mix two-cycle fuel, start by putting correct amount of oil in gas can. Then slowly add correct amount of gasoline. Do not try to mix gas and oil directly in gas tank of equipment.
IMPORTANT: Do not use any fuel that is over 30 days old. Do not mix more fuel than you are likely to use in a month. Old fuel can gum carburetors and prevent starting. Always use fresh fuel.
The chart below shows correct amount of oil per gallon that each mixing ratio requires. Expect that yours will be between 32 gas to1 oil and 50 to 1. 32:1 and 50:1 are most popular.
Ratio GAS:OIL UNITED STATES OIL per 1 U.S. GALLON Gasoline
(128 oz.)
*INTERNATIONAL OIL per 1 IMPERIAL GALLON Gasoline
(160 oz.)
*INTERNATIONAL OIL per 1 LITER Gasoline
(metric)
Jan 01, 2015 | Weedeater Garden
Black smoke on Nissan Navara engine
"Black" exhaust smoke means unburned fuel, meaning one or more fuel injector is not properly atomizing the fuel. The fuel injector sprays a fine mist into combustion chamber. When fuel injector is clogged or has deposit build up on the tip, the fuel dribbles into large droplets instead of a fine mist, which results in poor combustion and black exhaust smoke. After you replace the faulty fuel injector, ALWAYS pour one bottle of "fuel injector cleaner" once a month when topping off your fuel tank. Normally, a bottle of fuel injector will treat 20 gallons, but it doesn't hurt fuel injectors if you mix with less than 20 gallons to increase cleaning solvent concentration to keep fuel injector nozzles clean.
Nov 25, 2013 | Eliminator-Series Fuel Pump EFI or...
Fuel/oil mixture
HELLO THERE AND THANK YOU FOR CHOOSING FIXYA
From Poulan website:
The fuel-oil mixture ratio for all Poulan two-cycle products is 40:1. You can obtain this ratio by mixing 3.2 oz. of oil with one gallon of regular gas. If you have other brands of equipment that require different fuel/oil ratios and you don't want to mix separate fuel cans, you should use the lowest numerical ratio. For example, if you have products requiring 40:1, 50:1, and 32:1 ratios you should use the 32:1 ratio for all products. This may cause slight smoke increase in the exhaust in the 40:1 and 50:1 products due to more oil in the fuel, but it won't damage either of the engines.
Aug 15, 2011 | Poulan Garden
What percentage of gas and oil do we mix into craftsman gas trimmer
You don't state how old your unit is. Most of the older units use 40:1 (3.2 oz. oil /gallon of gas or 1.6 oz oil/half-gallon gas). Newer models have tighter tolerances built into the carburetors (per EPA Emissions Standards) and are made to run 50:1 (2.5 oz oil/gallon of gas or 1.3 oz oil/half-gallon gas).
To be safe, I would run the 40:1 mix and use a synthetic 2 stroke oil or at least a blend. If it calls for 50:1 and you use 40:1, the extra lubrication won't hurt a thing.
Apr 22, 2011 | Garden
How to mix the gas and oil for a qiubo mini bike?
The ratio is 1:25 so for every 25 parts of gas you use 1 part of 2 cycle oil. Any brand is fine but it must be for 2 cycle engines. Whatever measuring device you want is fine. Usually start by finding your oil container and your gas container. The 2 cycle can come in many sizes but 6,8,16 ounces is very common. An 8 oz bottle of 2 cycle will combine with 1.56 gallons because each gallon is 128 ozs and 8x25 = 200 ounces of gas or 1.56 gallons.
Of course measuring in metric is much easier.
I pour a little gas in a container add the oil and then finish off the gas to the correct amount. This mixes the oil and gas just fine and then with a black markery write on the container that it is mixed 1:25 that way you dont accidentally use it the wrong engine.
Feb 15, 2011 | Cycling
My Ryobi 700R "EZ" weedeater smokes excessively.
Check the fuel/oil mix ratio you are using. Some Ryobis use a 32:1 mix and some use a 40:1 mix. There isn't much difference there. To be on the safe side, if you machine is possibly running or tuned a little "lean" I would start off with about 4 oz/gallon oil to gas mix. Use synthetic 2-stroke oil also. Your machine will perform much better.
Nov 27, 2010 | Ryobi Garden
What ratio gas to oil do I mix?
Use 3.2 oz of 2-cycle oil to one gallon of gasoline. If you use 3.3 up to 4 oz you would be okay nut it may smoke a little. Sorry to hear about your husband. Good luck...Lee
Jul 29, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
How I can fix it. Smoking and leaking oil from muffle and carburetor
Probably too much oil added to the gas. At 40:1 that is only 3.2 Oz per gallon of gas. Smoking isn't completely a bad thing, at least you're getting lubrication to the engine (though it may be a bit too much). Remove the muffler, clean it. (throwing it in a fire and burning the carbon out is the most elementary way... on a grill... propane torch etc..and mix up a fresh batch of gas/oil (recommend synthetic) at the specified rate. The carburetors are very temperamental and the wrong fuel mix does this...tighten all carb screws you can unless you are going to pull it and rebuild it with new gaskets, etc (this can be done). Ethanol in gas ruins carburetor gaskets etc. over time.
Jun 10, 2010 | Craftsman 25cc Gas Line Trimmer
Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M Logo
571 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
