Question about Amana AC103E Thru-Wall/Window Air Conditioner
Window air conditioner unit frosts over and stops working.
My Amana Air Conditioner keeps frosting over and prevents the thermostat from taking accurate reads which basically shuts down the window unit. Only runs for 45mins before problem occures.Is this a problem with the unit or is it normal? Thanks...Bob
  • Dennis Boxerman May 11, 2010
    No a/c should frost over. I would look for anything that effect air flow. Check filters, fan speed, item too close in front of unit's air intake. or dirty coil (check both sides.) Anything that obstructs air flow will usually cause a freeze up. Only other thing, could possibly be an improper charge of refrigerant.
    Check it out.
    President:
  • 710 Answers
COILS USUALLY FREEZE UP DUE TO INSUFFICIANT AIRFLOW ACROSS THEM. IF THE FILTER IS DIRTY, THEN IT SHOULD BE REPLACED IF IT IS DISPOSABLE, OF CLEANED IF IT IS A PERMANENT ONE. THE ONLY OTHER REASON FOR A FREEZING COIL IS A LOW FREON CHARGE. IF THE UNIT HAS A LEAK, AND IS STILL UNDER WARRANTY, THEN RETURN IT TO THE MANUFACTURER. HOPE THIS HELPS. THANKS FOR AN HONEST RATING AND FOR USING FIX-YA. GOOD LUCK
Posted on May 26, 2009
HW can I find replacement parts fir this unit. Missing the part between the unit and thr window. The accordian thi9ngs.
Do a search on "
How to Install Frost King Air Conditioner Panels
They fit any air conditioner, provide insulation and reduce draft! Theirs instructions on how to install them to if your air conditioner is currently out of warranty. This sounds like a great option..See attached link
How to Install Frost King Air Conditioner Panels eHow
Jun 04, 2014 | Continental 10,000 BTU Window Air...
What is an E3 error message
E3 FROST PROBE OPEN: Normal operation is allowed. Replace probe.
E3 FROST PRObE OPEN: Normal operation is allowed. Ohm frost probe. Replace probe if ohm value not read. If ohm value is present replace board.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 10, 2010 | Fedders A6D24E7D Wall/Window Air...
Air conditioner not blowing out enough cold air fan is working but frost is built up outside and in on lines
Sounds like the unit may be Short on refrigerant, the frost can be sign the refrigeration is taking place on the pipework between the indoor and outdoor unit and not on the internal coil (evaporator indoor unit)
All the best
Jul 05, 2010 | Heating & Cooling
Blowing of cold air every 5 minutes, and it says FP on the screen
FP is the code for frost or freeze protection. The unit will automatically do this periodically to prevent any damage caused by low temperatures although it should not be running as frequently as every five minutes. If the outside temperature is not low then it could either be a problem with the exterior thermistor (not the one you see from inside your room) or the control board could be on its way out.
Feb 15, 2010 | Amana PTH123B25AJ Heat Pump Air...
High pressure air cond line has frost about 10 feet inside home
You have a low freon charge or a blockage in air flow. Check the filter if it is clean then there is a low freon charge in your system in which an a/c tech will be needed.
Good luck on repairs
Dave
Jan 06, 2010 | Amana PTH123B35AJ Air Conditioner
Frost on front grate unit, starting frosting up on thel ittle grates
Dip the thermostat into a glass of ice water. if the compressor stays on you have a bd control thermostat. Clean your coils. use a foaming coil cleaner that is non rinse for indoor use.
Jul 01, 2009 | Frigidaire FAC124 wall/Window Air...
Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Jun 30, 2008 | Frigidaire FAH08EJ1 Air Conditioner
Amana window air conditioner 10000 btu
Mine has done this alot, mostly because I live in a state with ALOT of wind, and in an area with ALOT of dirt. Sounds like your coils are dirty. Try cleaning it out, or having it cleaned out. If you spray it with water just make sure your compressor is facing up and you don't use too much pressure. Hope this helps
Jun 12, 2008 | Amana PTC074B25AE Electric Heat Air...
Fujitsu general ars40 duct type
you have to clean your A/C unit, indoor and outdoor, be sure all frost are de frosted before you run your unit again, or else it will frost again. if this not work your unit need re-gassing.
Jan 20, 2008 | Fujitsu 24R1 Air Conditioner
Dehumidifier frosts up
A dehumidifier will often frost up if room temperatures are colder than about 65 degrees F. If your room temperature isn't this cold, airflow to the unit may be restricted or blocked entirely. 1) Be sure the unit is set far enough from the wall so that airflow isn't restricted. 2) Clean the evaporator coils. To do this, unplug the dehumidifier and take off the outer cover. Allow excess moisture to evaporate from the coils. Then, using a brush attachment on a vacuum cleaner, remove all dust buildup. If necessary, cover the motor and electrical parts with plastic sheeting and spray with water.
Jan 18, 2006 | Fedders A7DH65B2A Dehumidifier
Amana AC103E Thru-Wall/Window Air Conditioner Logo
327 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
