Question about Kenmore 63942 Dryer
Where does the pulley go
The pulley or wheel came off and belt is loose
  • 585 Answers
If it's about a 2-inch wheel with a rubber "tire" it goes on a little stub of a shaft at the back of the dryer and supports the drum from below. There are two, one on the left, other on right. Usually retained by a small triangular plastic clip. If it's gas, you can reach it from the front by reemoving the access under the door. If electric, you'll have to disassemble the dryer.
Posted on May 26, 2009
Will not move
Have you checked for a loose or warn drive belt. A loose belt will not have enough friction to turn the wheels under load. Also check the tensioner pulley for the same belt.
Apr 07, 2014 | Garden
My brother and I discovered that my Serpentine Belt had come off on my 2005 Suzuki Forenza. While attempting to replace the Serpentine Belt I discovered the pulley attached to the crank shaft is loose and...
If the pulley wheel doesn't seem to connect to anything else it is probably just your tension pulley.
These are only to keep the serpentine belt tight while allowing it to adjust to some limited extent.
You can replace the pulley itself. These commonly grind when they go bad, or in your case it sounds like yours just broke off..
Aug 29, 2011 | 2003 Ford Windstar
Loud sqeeling noises when running. Sounded like a belt slipping. Dryer died all together and smells of burning rubber. Suspect a loose or broken belt. How do I change it?? --Dave
Check and see if the belt slipped off the motor pulley broke or wrapped around motor pulley. Check the idler pulley (large white wheel end of motor) Loose?
Oct 16, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
How to adjust belt sqealing problems?
If this vehicle has one serpentine belt chances are the belt must be replaced, look to see if there are visible cracks on the contact surface of the belt if so replace the belt if not then there may be a component in the pulley system that is starting to seize, the squeal is the pulley wheel offering more resistance at certain times therebye causing the noise, with the belt off try turning each pulley to see if binding is occuring, also check each pully wheel for loosness or play the bearing may be worn if play is detected.
Dec 07, 2009 | 1996 Mazda MPV
SQUEEKING NOISE FROM BELTS
Look at belt tension, your description sounds like loose belt(s). Do not use belt dressing, only resolves for short period of time...
Doc
Sep 18, 2009 | 1996 Toyota Corolla
Belt Broke and pulley bracket came loose, where does pully belong
It goes into the front of the motor on the floor with the wheel to the left. You insert the belt between the idler bracket and loop it over the motor pulley.
The ribs of the belt need to be up against the drum for grip. It is best to have a person hold the drum while you do the pulley. Here is a page that shows various belt routings on different machines, yours is bottom right.
Jun 09, 2009 | Whirlpool LER4634J Electric Dryer
Serpentine belt
rempve the belt again and hand spin the pulleys listening for a loud bearing type noise in one of the pulleys .. you see anything that spins has a bearing in it. the bearing drys out and the pulley gets louder than normall.most time it an idler pulley.
good luck chris
Mar 19, 2009 | 2004 Dodge Ram 1500
Replace belt
Remove lid UN PLUG MACHINE FROM WALL SOCKET Undo motor bollts so it can be moved towards drum, GET OLD BELT AND LOWER IN YOUR HAND TOWARDS DRUM THEM MOVE BACKWARDS TILL CLEAR OF DRUM PULLEY ,get new belt and lower so it goes over rear of drum pulley (big wheel)make sure nothing is in drum,put one bolt of motor in loosely and roll belt over motor pulley wheel slowly forcing towards you if working from front a bit until ribs on belt are in grooves on both pulley wheels,Tighten up all motor bolts job done test it
Sep 15, 2008 | Hotpoint WMA64 Front Load Washer
Changing drive belt
ensure that the tensioner pulley wheel is also part of the belt loop and that it is properly sprung to take up slack. sometimes, this pulley looks good mounted in reverse, giving no tension to belt. try it the other way, against the spring force.
Sep 23, 2007 | Dryers
Kenmore 63942 Dryer Logo
61 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
