Question about Sta Rite Sr333na Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 333,000 Btu Natural Gas
Sta rite heater gives a R1 error message and won't start.
Replaced the keypad 2 years ago, unit is 10 years old, I've checked the flow pressure sensor, checked the air blower sensor, and don't know whether the thermister and exhaust is normally opened or closed. It's open now and don't know if that's preventing start up. Appears as though all the safety's are operational.
Any help would be appreciated.
    Top Expert:
  • Sta Rite Master
  • 5,045 Answers
Bad ignitor
Posted on Oct 11, 2017
  • 83 Answers
SOURCE: sta-rite gas heater won't ignite
I am not sure if either of these issues have been solved, but with the AGS light on, you will need to check the flow of water first. If it is below what is needed for the heater, this will light up. If the water flow is fine, then check the water temp on the display panel. If it is readin higher than that of the ACTUAL pool water temp, you need to replace the Thermister.
If the water temp displayed is about that of the pool water, then the Automatic Gas Shutoff will be the next thing to check and replace.
You can tell IF a Sta-Rite heater has been converted by the model number. The Convesion Kit is supposed to come with a sticker stating that the heater has been converted, but there are two options for the kit and the one without the sticker is cheaper.
If you take off the top two halves of the heater, on the Junction Box there should be a Tri-fold card there. Unfold it, if the model number ends with NA it is a Natural Gas Heater, LP would be Propane.
Posted on Jul 10, 2009
  • 83 Answers
SOURCE: Sta-rite heater error code 126
The 126 is not an error code, but it maybe the temp of the water that the heater is reading. If the heater thinks the water is 126 degrees, it will not start at all.
If the heater is reading the wrong water temp, the problem is the Thermister, which is the sensor that is suppose to read the water temp. You will need to replace this sensor in order to correct the problem with the heater. It is really easy to do!
If you have a manual for the heater, if you go to the Replacement Parts Listing for the Electrical System, page 53 in the online version, the Thermistor is Item #9. It goes into the left side of the manifold in the to place, between the first two manifold bolts.
  • 83 Answers
SOURCE: sta rite 400na gives error code 05 after about 30 seconds
I am not sure if you have received an answer to the issue, or not, but just in case! An EO5 error code is an open stack flue sensor, or switch, There are two forms of the stack flue sensor, so you will need to know which one you have on the heater.
What this error code means is that the sensor "read" the flue temp to be over 500 degrees. Usually, it is just gone bad and reading the wrong temp.
Posted on Jul 14, 2009
SOURCE: Value Stack Flue Sensor
3.5 to 4K If you want to bypass the sensor just jump a 1 dollar resistor in between the two wires. If you want to put another sensor just use a standard gas heater flute sensor(2dollars) and put in line with the resistor
Posted on Nov 26, 2009
  • 246 Answers
SOURCE: sta rite heater won't start
TURN THE BREAKERS OFF FO R 20 SEC IF PROBLEMS PERSIST SEE CODE A POST
Posted on Dec 07, 2009
Why is this pool heater making a very loud whistle sound after heater is fired up?
could be the fan motor or check to see if a rust hole is giving you the whistle
Aug 28, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
I have a sta rite heater installed about a year ago, it is showing Service light on, and it ignites for a couple of minutes then begins to shut down, The gas meter has been changed a couple of times to a...
If this is a propane heater and you have changed the meter that means you have natural gas. A converstion kit is avable and all it is is a washer in the gas line inside the heater. You can buy these but my wholsaler just gives them to me when I get a heater. Get your installer to do this for you first before you buy anything else. Also check the size of your gas pipe to the unit. It need's to be sized to the heater and the run of pipe. You can find this info in your book that came with the heater.
Sep 07, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
So how do I fix this problem "sta rite 400na gives error code 05 after about 30 seconds?"
if it starts check your stack sensor its the one the exaust ----- And if it dont start change your ignition plug
Jun 19, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
Yesterday I had my heater converted fro LP to Natural gas (technician replaced orifice). Now heater makes loud whistling sound when burner is on. Stop making noise when heater is turned off and only blower...
The wrong orifice was installed. Sta-Rite changed their blower configuration 3 years ago. Heaters older than that have a flat orifice that works with the older style blowers. Newer heaters are equipped with a tapered orifice. Mixing a flat with a new blower causes whistling. Mixing a tapered with an old blower causes whistling. Good luck!
Nov 17, 2009 | Sta Rite Sta-Rite Max-E-Therm High...
Sta-rite lp heater wont start
Its the top. There is a membrane that controls the circuit board....the button pad is bad
Aug 26, 2009 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Sta Rite Sr333na Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 333,000 Btu Natural Gas Logo
233 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
