Question about Garden
Fuel line for Toro trimmer
Where can I get fuel line for my Toro trimmer. If you can get it to start, it then dies as soon as you put it to full throttle. I put it in the shed and noticed it was leaking so I followed the fuel line and found the one to the primer button is broken where it goes into the fuel tank. It was only used once but I cant find the receipt. GRR
  • 246 Answers
Hello:
You can Purchase Fuel Line for Trimmers and All Lawn Equipment at your Local Small Engine Service Center or your Local Automotive PArts Retailer.
Take a Piece of the Old Fuel Line so you Purchase the Correct Size.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 26, 2009
You can buy a universal gas line kit from Home Depot #323-460 you will get 1' of line that will work for the Toro Trimmer.
Posted on Oct 28, 2011
Trimmer won't prime to start
Look inside the tank. Some units have a stone inside that blocks the fuel line when it is tipped a certain way. Might be what's happening here.
Aug 13, 2016 | Garden
Gas leak at grommet on gas tank where gas lines enter and leave tank
Yes you should be able to replace the rubber tank seal that the fuel line goes through. Be sure to replace the fuel line(s) when you do.
Apr 01, 2014 | Toro 2-Cycle 25.4 cc Straight Shaft Gas...
Engine dies when putting it to run position
Usually a sign of a carb problem, lack of fuel being the most common.
Carb may have dirt in it.
Sep 22, 2012 | Toro 2-Cycle 25.4 cc Curved Shaft Gas...
Crafsman 25cc weedwacker won't stay running
You probably have a bad hose or a bad hose connection that is sucking mostly air instead of delivering full fuel to the carburetor!
Apr 19, 2017 | Craftsman 25cc Gas Line Trimmer
How far in the gas tank does a toro trimmer fuel line need to go -- I assume not very far and not as far down as the filtered gas line, correct?
The gas line with the weighted fuel filter on it should lay across the bottom of it (somewhere near the opposite side) and the purge/return line only needs to enter the fuel tank 1/2" to3/4" to work.
Sep 11, 2011 | Toro Electric Trimmer
My toro weed trimmer starts good runs great for a few minutes then starts to bogg out then dies, will start back up but won't stay running.i already replaced the fuel tank, lines and filter.
Check the air filter isn't dirty.
If the machine runs ok on high speed but cuts out while idling, the idle speed may be too low. There is usually an adustment screw for increasing the speed.
If the fuel line is a flexible type which moves around inside the tank, check it is able to move freely because if you are cutting at awkward angles, the end of the line can end end up above the surface of the fuel, **** in air and airlock the line. You can eliminate this as the problem by fully filling the tank.
Check whether there is a one way check valve on the tank. This vents air into the tank as the fuel leaves for the carburettor. Sometimes particles of dirt can get stuck in this.
Apr 30, 2011 | RTO Weed Eater Hedge Trimmer 20cc,...
TORO WEEDEATER WONT RUN UNLESS FUEL TANK IS COMPLETELY FULL
Sounds like your fuel lines have broken or hardened and aren't reaching the fuel when the level falls. Replace both (or 3) fuel lines (one at a time) and don't forget to put the pickup filter back on. You can get the lines at your local mower repair shop for less than $5 for the 2 foot of line that it takes to replace all lines.
Aug 23, 2010 | Garden
32 cc craftsman trimmer starts but will not run at full rpm
Air fuel mixture problem,,,you need to have the filter pulled out and cleaned. Check fuel system for debris and clean, that includes all the fuel lines and possibly disassemble carb and clean and reassemble.
Apr 27, 2010 | Craftsman 25cc Gas Line Trimmer
What causes a 2 stroke engine to have too much compression and therefore difficult to pull the recoil starter?
Nothing will do this...what is most likely the problem is either the recoil is going bad or you have the wrong spark plug installed.
Dec 03, 2009 | Toro& Electric String Trimmer
Garden Logo
937 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
