Question about Honeywell Heating & Cooling
The air doesnt work at all its 80 degrees in here owners manual is brief and no help
Cant get the air to work
    President:
  • 3,433 Answers
Everything off, unplug and plug back in, make sure breaker has not tripped or that power is availoableplug unit back in and set to cool and make sure vents or discharge is closed. Good luck
Posted on May 26, 2009
I am working on a M # GPG13420901AB. This is a 3.5 ton package unit that replaced a 3 ton package unit on 1700sq/ft single level home. Old unit was working fine but was replaced when the home was...
It sounds like you are low on charge. I think you have a thermostatic expansion valve and you need to check the subcooling, you should have 12 to 15 degrees at 95. At 95 degrees your head should be about 280# for a 12 or 13 SEER unit or higher depending on the effeciency. At 78 to 80 degrees indoor depending on the humidity, that is normal. The valve will open to try to fully feed your indoor coil and it sounds like your head pressure is to low to force enough refrigerant thru the coil.
Aug 16, 2010 | Goodman Heating & Cooling
We have a3 yr old Goodman CAPF3030B6AA Airconditioner and Furnace. The Air conditioner hasnt worked right all summer. Its 102 degrees outside and we can set the thermostat on 72 degrees and it will be...
A/C units have a design temperature of 90F. Now when the temperature is above 90F they start to have trouble keeping up. Depending on how well your unit is sized for the house, you will notice when the temp is over 90F. I don't know if who ever looked at your unit checked the refrigerant pressures since you said he checked the temps but I assume he did, however, it could possibly need charging.
Aug 05, 2010 | Heating & Cooling
HI I have my hot tub at 104 but it will only heat up to about 80 degrees. what is my problem
If its set at 104, but only heats to around 80 degrees, then your heater is not working. Either the heating element is bad, or the pressure switch is not closing. The reason why the water heats up to 80 degrees, is from the friction caused by the mechanical shaft seal when the pump is running. Either way, you should really have it checked by a qualified spa technician. It is not something that the average spa owner can normally repair themselves. Sorry.
Sep 27, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Where can I find the owner's manual for an IR Type 30 model 25T
IR has not made their owner's manuals available online. You have to contact your nearest dealer in order to get one. If you do get one, could you please consider uploading the manual to fixya.com to help other people who a looking for the same thing.
May 13, 2009 | Ingersoll Rand Type 30 Reciprocating Air...
Admiral air conditioner
20 degree's is the difference you are looking for.
Jan 21, 2009 | Heating & Cooling
Manual needed
I own a Haier A/C window unit, and have the owner's manual. If anyone needs help with this make and model, I might be able to help. Please remember, I am not a certified tech. I only have the manual for simple questions. chicagosinger
Jul 11, 2008 | Haier hwr10xc6 Air Conditioner
Heating & Cooling Logo
74 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
