Question about Polaroid I533P Digital Camera
The lens is stuck out
The battery died while the lens was stuck out, and now it absolutely will not cut on. i've tried new batteries many times. help?
  • 6 more comments
  • RSasser Nov 02, 2007
    My batteries aren't dead but it won't turn on even when I put brand new ones in.....HELP?
  • candyluver95 Nov 04, 2007
    My polaroid i733 digital camera's batteries will die with the lens still stickng out. I left it like that for a while. I put new batteries in it and light below the m button will flash but the camera won't turn on.
  • a4whsm Nov 07, 2007
    My i533 won't turn on and the lens is stuck in the out position. Other batteries don't help. What's up?
  • labanana Nov 11, 2007
    my camera wont turn on the lense is stuck it will just start beeping at me and shut off the screen wont even show up, it just started out of no where.
  • jrussell424 Nov 12, 2007
    Mine is the same way. The lens is stuck out. The green light always flashes and sometimes it beeps and sometimes it doesn't. :(
  • wandac Nov 20, 2007
    lens stuck out, try to turn on light blinks makeing beeping sound
  • katsniles22 Feb 13, 2008
    i press the on button and it like comes up with my start up image then beeps and turns off. the computer wount even reconize it anymore cause it doesnt stay on long enough
  • chelsea1234 Mar 11, 2008
    The lens is stuck out and when i replace it with new batteries the power button flashes. The camera will not operate at all thr power light will not stop flashing and i can not turn the power off .
    Problem Solver:
  • 7 Answers
My daughter just had this problem with her camera. The camera was off with the lens barrel extended. When I looked at it closely, I noticed that the inner part of the lens barrel was at a slight angle to the camera. I pushed firmly on the low side of the inner part of the barrel, and it popped the rest of the way out. Camera works fine now. Good luck!
Posted on Feb 10, 2008
SOURCE:
Lens won't close
Lens may jammed or control board is bad. You may need to take it to a dealer or time to buy a new one.
Dec 17, 2017 | General Electric A735 Digital Camera
My lens got stuck when the batteries died. I just
Try pushing the delete, LCD power, and menu buttons while turning it on.
Feb 10, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
Lens won't retract
some cameras you can just push the lens in.
Jun 29, 2009 | Pentax Optio M20 7MP Digital Camera with...
Battery warming up the camara
Was your camera working before you put the new battery? if yes, then its possible some dirt or grit has got stuck between the lens and the body and therefore you motor might be warming up.
Since you 've bought a new battery, I dont think It may not be the battery, the way you are explaining. It could be the lens motor itself, since its warming up.
Try to do the following: ( I 've got this checklist from the forum itself)
Remove the batteries from the camera, wait a few minutes. Put a fully charged batteries back in and turn the camera on. if it doesnot work then,
2: Remove the batteries again, as also remove the memory card. Then install the newly charged batteries, when you turn it on it should come back to life.
3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during start up. This extra power can be useful to overcome any grit or sand particles that may be jamming the lens.
4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum
6: Repeatedly tap the padded/rubber usb cover with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand.
Try the above and let me if its any help.
Best of luck
Mar 07, 2009 | Casio Exilim EX-Z40 Digital Camera
Lens not going in & getting stuck
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
Oct 10, 2008 | Samsung S760 Digital Camera
Camera wobn't turn on & lens stuck in out position
My camera stopped working during a wedding. The lens is stuch out, it will power on, but right after turning on, it beeps 3 times, then turns off.
Hope we find a solution!
May 14, 2008 | Samsung Digimax A7 Digital Camera
Zoom error
I had sent my camera in for the same issue and they did nothing to help with it. Seems to happen when battery gets low or dies, lack of on-screen battery meter doesn't help. Typically have to manually twist the lens to close it or open it after fresh batteries installed and then seem to fix it.
Apr 08, 2008 | Fuji FinePix E550 Digital Camera
Lens cover only partially opens
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But it should be similar for the A430:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Mar 31, 2008 | Canon PowerShot A540 Digital Camera
Camera Frozen
New battery time time then Or can you remove battery and try a stand alone charger?
Jun 30, 2007 | Sony Cyber-Shot DSC-P200 Digital Camera
Polaroid I533P Digital Camera Logo
61 people viewed this question
Top Polaroid Cameras Experts
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
