Question about SanDisk Sansa Clip MP3 Player
Ports work but not recognized by computer as being attached; does register on a different computer
Mp3 apparently works on only one computer
It works on all computers, its just something to do with the windows versions, namely sp2 and such .all you have to do to connect to all the pcs is,   Go to Settings (on your sansa clip) > USB mode & choose MSC
Posted on May 28, 2009
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
Computers don't recognize mp3 player
It's hard to help very much without knowing what kind of MP3 player it is but for starters you should:
1. Fully charge the device and then try plugging it in again
2. If that doesn't work try a different USB cable and/or different USB port on your computer.
Some players also have a reset button you could try.
Nov 06, 2013 | Audio Players & Recorders
My winxp will no longer recognize sharper image usb 2 digital photo keychain when cable and viewer are attached
try a different USB port on the computer. If that doesn't work, it might for a scan for errors on the hard drive and a drive defrag, in that order.
Nov 02, 2013 | Innovage Shift3 MP3 Player
It doesn't recognize USB flash drive anymore
The flash drive itself may be faulty or damaged, and sometimes this is not apparent from a physical inspection. Try attaching the drive to a USB port that you know is operational, and try plugging another USB device into that port to verify that the port is working.
Jun 19, 2012 | Kenwood KDC-MP445U CD/MP3/WMA/AAC Receiver...
Computer does not recognize MP3 after reinstall
When you connect your mp3 player to your PC, it will appear in "My Computer" as a removable drive. If it does not, the USB port may be the problem. Plug a different device into this port to make sure it is working. If it is not, make sure you have all the drivers for your computer inastalled. Also try a different USB cable.
Nov 13, 2009 | SanDisk Sansa Clip MP3 Player
Problems with USB port and charging mp3 player with MSI Wind U120
do the usb ports work at all, if not open the case and see if there is a loose wire.
Jul 16, 2009 | MSI WIND U100 Notebook
My computer does not recognize my Creative zen
Go into device manager in control panel in add/remove hardware and find the usb port its plugged into and uninstall then reinstall the driver.
Jan 08, 2009 | Creative Labs ZEN V Plus MP3 Player
Computer doesn't recognized the mp3
this could be a vista compatability issue.
if you have driver or installation cds with the players, try installing any software.
also try a different usb port on the computer, as the port may have already assigned itself, for other devices.
try looking in the device manager, to see if the computer detects the device. but has problems or issues. usually a yellow triangle or exclamation mark.
Finally connect the device, and use ( Add new Hardware Wizard )
thankyou for using Fixya.
Mike @ compurepair.
Jan 05, 2009 | Nextar MA933A MP3 Player
Blue ring of death
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard
Jul 05, 2008 | SanDisk Sansa e260 MP3 Player
USB port problems with hp printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Apr 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
SanDisk Sansa Clip MP3 Player Logo
103 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
