Question about General Electric WHDSR209DWW Top Load Washer
Washer machine will not drain
We were doing a load of wash and the water will not drain or spin. When it is suppose, there is a faint noise but nothing is happening.
Here is the most common cause for this problem, according to the Samsung repair guy that was here to fix mine today.
On these washing machines it is possible for some debris (in my case it was a small screw from my packet) to make its way passed the drum and into the pump. Once this happens then the impeller of the pump becomes restricted or completely blocked which will result in the above mentione symptoms.
On some machines the pump is on the front, on others at the rear of the machine. In my case it was at the rear, removing the rear panel will allow easy access to it. Have a bucket ready, when the hose is removed from the pump the water will be draining from the machine. 3 bolts and a hose clamp on the inlet and another on the outlet hose. Disconnect the electrical plug from the pump and you can remove it from the machine for cleaning. A very easy job, requiring little skills and not much in terms of tools. (make sure machine is UNPLUGGED from AC outlet)
Remove obstruction(s) from pump and reinstall in reverse order of disassembly. The guy says these pumps are really tough so if you hear it buzzing, trying to go while it's jammed it's a good sign it will work. If not, replacement will be necessary.
Cost me $140. Could have been worse I suppose. Advise: Empty pockets BEFORE washing clothes...
localwonder Washer machine will not drain - button_previous_off.gif button_next_off.gif
Rank: Washer machine will not drain - guru_s_bl.pngp://i.fixya.net/uploads/images/guru_s_bl.png" alt="guru_s_bl.png" class="h_mi" /> Guru
Posted on May 26, 2009
Washer making loud noise willnot spin cycle or drain water
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 10, 2011 | Electrolux AWF 1435 Front Load Washer
My washer was filled with water but wont spin.. makes little noise but no spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Jan 18, 2011 | Maytag PAV5157A Top Load Washer
Water will not drain.... grinding noises?
heatman101
Jan 03, 2011 | Frigidaire Affinity ATF7000E Front Load...
It will spin but the water does not come out, then it makes a funny sound-like a high rattle noise. We have never had any problems - we checked the hoses, they are clear. I has worked like a tip for years,...
heatman101
Aug 29, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My LG washer wm2277hw does not drain water and
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | LG WM-2277HW Front Load Washer
Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Front load washing machine is making a grinding noise when it is supposed to spin. the water didn't drain either
You need to clean the hose that drains the water. The water needs to drain completely for a good spin.
Nov 26, 2008 | Frigidaire ATF6000ES Front Load Washer
Cda c1532 front load washer
possible drain pump has a foreign object in it - access the impellor to see what you find or possible the pump has in fact failed. if you can hear a faint humming noise when should be draining, that indicates somkething jammed in the pump
May 19, 2007 | CDA CI532 Front Load Washer
Whirlpool AWM6120 Front Load Washer
Cleaning depends on use. 8 years is a bit over the top! When your water does not drain, check the outlet filter first, then the pipe from below the tub to the filter. Your washer wont spin 'cause the pump/filter is blocked.
Jul 24, 2006 | Whirlpool AWM6120 Front Load Washer
General Electric WHDSR209DWW Top Load Washer Logo
345 people viewed this question
Top General Electric Washing Machines Experts
Sal De
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
