Question about Rockford Fosgate RFX-9320 CD Player
PROBLEM I NEED TO MANUALLY SCROLL MY RADIO STATIONS BUT MY UNIT AUTOMATICALLY SCROLLS TO THE NEXT AVAILABLE STATION. I NEED TO PRESET IT TO 88.1 , SO I CAN HOOK UP MY XM RECEIVER. MY UNIT IS A ROCKFORD FOSGATE RFX-9320 CD. THANKS
Press and hold the down or up button and it will switch to manual tune
Posted on Feb 09, 2008
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
Rca rt 2770 programming. My fm radio stations
You can manually program a station by pressing AM/FM to get to the correct radio band. Then tune in a station with the Tuner +/- (the left/right arrow) buttons on the remote. Next press Memory (just below 7) and then a number on the keypad. The number must be entered before the Program Preset number stops blinking. (For FM you can use some 2 digit numbers.) To scan through the stations in memory use the Channel +/- buttons on the remote or the Next/Previous track buttons on the RT2770. You could fill all of the memory slots automatically by pressing and holding the AM/FM button for two seconds. The unit will store the stations that it tunes in in order until the memory slots are full. Note: you do need to have the FM antenna and AM loop antenna connected (and extended for the FM antenna).
Retrevo has the manual for the RCA RT2770 available here: http://www.retrevo.com/support/RCA-RT2770-Home-Theater-Systems-manual/id/2869dj191/t/2/ . You will need to enter a code to download the PDF.
I hope this helps.
Apr 30, 2014 | Audio Players & Recorders
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
How do I preset different radio stations?
Hello
There are 6 preset position available for each radio band.
For programming, Radio must be ON. Tune to a station. Press MEMO/DEMO. Press any button 1 to 6. The tuned station will be memorised on the number you select by button press. Repeat using a new station and preset number. There is no atu preset option available with this device. You have to store stations you want according to your preference. Only 6 station positions for each band [total 12 positions] together with AM and FM bands.
To recall the stored stations, press the desired number 1 to 6.
Dec 07, 2011 | Sharper Image SI785 Clock Radio
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Jun 29, 2011 | Audio Players & Recorders
How come i cant find the radio for my Phillips go gear vibe?
From the main menu, select the icon that looks like a little radio
To search for the next stronger signal, press and hold the up or down arrow
To fine tune the frequency, briefly press the up or down arrow
From the main menu, select to enter
radio mode.
• The earphones cable acts as FM
antenna.
Manually tune a radio station
While in mode, you can manually tune to a
radio station:
1 To search for the next stronger signal,
press and hold / .
2 To fine tune the frequency, briefly press
Auto-tune preset radio
station
The auto-tune feature of GoGear Vibe helps
you find radio stations and save them under the
preset numbers.
1 While in mode, select [Auto tune] >
[Yes].
»» The radio automatically tunes radio
stations and saves the frequencies to
presets.
»» There are 20 presets available.
»» To stop auto tuning, press .
»» To exit radio, press and hold for 2
seconds.
EN
Jan 09, 2011 | Philips GoGear ViBE Digital Media Player
I can't figure out how to set the radio station pre sets
hi,
there is no auto presetting available. u have to set all channels in preset manually. if u power off the subwoofer all setting will be erased.for manual preset do the following.
1. Press the FUNCTION button to select "TUNER".
2. Press the FM/AM button to select a band.
3. Select the station you want to listen to (Hold down the TUNING Up or Down button until the
frequency display begins to change. When a station is tuned in, the tuning process will stop automatically.)
when it tune the first station available do the following to preset it,
4 .Press the MEMORY button.( on remote)
5. Within 5 seconds, select a preset channel to store the
station using the PRESET buttons of the remote control
unit.
6. Within 5 seconds, press the MEMORY button.(The station is stored and the MEMORY indicator goes off. To store more stations, repeat steps 3 to 6) .
for listening preset ed station ,Press the PRESET button repeatedly until the desired
preset station is found.
ok
Dec 24, 2010 | Teac CD-X9 Shelf System
I'm trying to change my radio station. The instructions say to push the snooze up or down arrows. But all that does is change it to one preset station to another. I don't want the preset stations.
For me with the M302 moondance system, the remote Tune + and Tune - buttons change the FM station (when the unit is set to FM as the source). Press and hold for 3 second to scan to the next clear station. The Track Forward and Track Backward switch between the presets.
If you are using the buttons on the unit, you can only search through the preset stations with the Snooze Up and Snooze Down. If you do not have the remote, you need to replace it. I believe this is the correct one: http://www.alteclansing.com/ae/restofworld/accessories-parts/wireless-remote-m302-a13547/invt/a13547/ .
I hope this helps.
(btw the manual for the M302 is available here: http://www.alteclansing.com/ae/restofworld/ipod-iphone-speakers/moondance-home-m302/invt/m302/ . Click on the icon with the down arrow.)
Nov 11, 2010 | Altec Lansing M302 moondance HOME Alarm...
How do I preset radio stations?
PRESET RADIO STATIONS
1 press RADIO BAND. AUTO PRESET to select the band.
2 Hold down RADIO BAND > AUTO PRESET for 2 seconds until "AUTO"flashes in the display
3 Press DSPL/ENT/MEM. The stations are stored in the memory from the lower frequencies to the higher ones.
if a station can not be preset automatically.
you need to preset a station manually.
2 tune int he station you want.
3 hold down DSPL/ENT/MEM. for 2 seconds until the preset number flashes in the display.
4 press PRESET + or - until the preset number you watn for the station flashes in the display.
5 press DSPL/ENT/MEM. The new station replaces any old one.
TIP the preset radio stations remain in memory even when all power is disconnected.
manual available at sony
http://www.docs.sony.com/release/CFDF10.pdf
Jan 01, 2010 | Sony CFD-F10 Radio/Cassette/CD Boombox
Radio for Sandisk model SDMX1
Press the AB button to toggle between Audio Play, Radio, and Voice Record. Use the left/right scroll to highlight Radio. Then press the center button or play/pause button once to select radio.
You will see FM Radio in the upper left corner of the display. Under that you will see either Preset followed by a number OR Channel. If it is on Preset, you can use the left/right scroll to switch between preset stations. If you press and hold the AB button, the player will scan through all frequencies to find the strongest stations in your area and set those as the default preset stations. When on a particular station, press and hold the record button to delete that station from your presets.
Press the center button once to switch to Channel (or back to Preset). Under Channel, you can manually scroll through the frequencies yourself. Push left or right and hold for about a second to find the next available station.
Press the play/pause button once to toggle between Mono and Stereo.
Those are all the functions I've found so far. Hope it helps.
Good luck,
vw
May 26, 2009 | SanDisk SDMX1-1024-E18 MP3 Player
Rockford Fosgate RFX-9320 CD Player Logo
137 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
