Question about Frigidaire Washing Machines
Noisy Frigidaire front load washing machine.
My Frigidayre front loading washer has begun making a very strange noise over the last week or so. This noise can he heard somewhat at low speed but it really gets very strong when spinning at high speed. I had a repair person come in to see what it was and he said that this was the main bearing at the back that was going. He continued by saying, it would cost me about $500 to get it repaired with parts and that this was a very difficult job to do. Can you tell me if this sounds right and if this is about what I should expect to pay to repait it? If so, is it worth repairing? The washer is only 6 years old. Thanks in advance for your help. Regards, Mario
  • 89 Answers
Comming from a Sears Tech,,, ME
he is right. the main bearring is done.
the part in canada costs 149.99
the issue is USUALLY caused by poor quality of water (well water)
or improper detergent.
a "HE" type detergent must be used in this machine. or this issue will come up afer about 5 yrs.
its not too bad of a job to do, takes 1 person about 1.5 hrs.. and does cost roughly 500 to fix.
It might be worth it to go and buy a newer frontload washer that this is not as much of an issue with.
but it is not worthless to fix, providing the proper detergent is used in it all the time.
Posted on May 26, 2009
My frigidaire GLTF2940ES3 front load washer keeps making beeping noises even when not on. I have unplugged it until using it. Seems to work somewhat but it stops in between cycles, beeps and blinks...
frigidaire has problems with their computer boards and it sounds like this is your problem,i've seen them shut down and then after a while start beeping on it's own just like your machine is doing and it was the board part 137006000
Dec 04, 2017 | Frigidaire GLTF2940ES Front Load Washer
My machine is too much noisy
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 25, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a Frigidaire GLTF2070DS Front Load Washer and during the spin cycle, it started making this horrific noise. I started another load of laundry and now it does not spin. What could be the problem?
heatman101
Sep 07, 2010 | Frigidaire GLTF2070DS Front Load Washer
The drum is loose when the washing machine is not in use. When it's in use it makes a loud whirring noise like a train going through my house. This happens on an empty load as well. The machine is a front...
heatman101
Aug 29, 2010 | Frigidaire GLTF1670A Front Load Washer
My front loading washing machine will not spin. it does everything else.
your lid safety switch underneath the top cover has begun to split apart and can no longer make contact to run the spin cycle
Aug 07, 2010 | Frigidaire GLTF2940ES Front Load Washer
Very noisy and loud vibrations on spin cycle of Frigidaire FTF2140FS front load washing machine
Is it just during the spin cycle that it machine is noisy or the noise is less during the wash cycle? Also is the noise a thumping type of noise or is it more of a whining or steady noise? If is a whining noise, it probally means that water has seeped past the seal and corroded the bearing of the washer. The noise is the failing bearing.
Jun 30, 2010 | Frigidaire GLTF2940ES Front Load Washer
My frigidaire front load washer/rear control panel GSTR1670AS0 just started to make a VERY LOAD banging noise. I replaced the belt, but it is still noisy and then got the same banging result during the...
Could be Drum bearings, try Grabbing the inner drum and moving it front to back ,should have little or NO Play, assuming this is okay then check the counter weight, Concrete Slab on top of machine outer drum loose
Dec 06, 2017 | Frigidaire GSTR1670A Front Load Washer
Noisy Spin Cycle
It sounds like the dreaded rear spider corrosion and breakage issue.. You may find your washer is not worth repairing.
Jan 21, 2009 | Frigidaire FWTBB30DS Front Load Washer
FRIGIDAIRE FRONT LOAD WASHER MAKING STRANGE NOISES DURING WASH CYCLE
Depending on where you live use your local directory for assistance.
May 24, 2008 | Frigidaire ATF6000ES Front Load Washer
Greasy mark on cloth and noise
The rear bearing is most likely the cause, High efficiency detergent is a must with front loaders. Most likely not worth repairing unless you can do it yourself. Having it done would most likely run at least 350.00 - 450.00. Call a local servicer, A&E (aka sears) would charge 1,000.00.
Jan 18, 2008 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
132 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
