Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH8700AWW Front load
My washers is gusing water from the detergent dispense area.  I removed the dispenser and found that the water was not draining into the washer fast enough.  I can only assume there may be some detergent build up or something of that nature.  What can I do?
  • 5 more comments
  • Tdms3 Nov 07, 2007
    I have a Maytag MAH5500BWW front load washer. Started noticing that the bleach and fabric softener cups in the machine were still full after the cycle was complete. I checked the hoses in the back of the macine and they are clear. I watched a whole cycle and the water rinses to the main "add soap" area but never into the bleach or softener cups. Any ideas on a fix? Thank you!!
  • Anonymous Dec 01, 2008
    what is the solution to this issue? I am having the same problem
  • Nedee Dec 01, 2008
    I have a Maytag MAH5500BWW front load washer. Started noticing that the bleach and fabric softener cups in the machine were still full after the cycle was complete. I checked the hoses in the back of the macine and they are clear. I watched a whole cycle and the water rinses to the main "add soap" area but never into the bleach or softener cups. Any ideas on a fix? Also noticed that when machine filling up on cold cycle water dispenses to machine very slowly? Help
  • ronniefoy Dec 09, 2008
    have same problem water coming out of dispener drawer area looks as if water is not draining into machine fast enough. How do you clean the hose? how do you get console off? Please Help. thanks
  •  Brooke Hatfield
    Brooke Hatfield Jan 03, 2009
    I have the same problem with the bleach and fabric softener cups. They do not empty, even though the detergent cup works fine.  Is this a bad solenoid? My machine is 3.5 years old.
  • mooncusser35 May 08, 2009
    my maytag neptune washing machine was working fine yesterday today it wont start it shows a d5 error even though the door is closed Help
  • Anonymous Mar 29, 2014
    Water backs up in the detergent dispenser compartment. Sometimes whatever ever is misaligned gets aligned ad the water flows at it should to the tub. Most the time it just pours out of the seams of the dispenser draw.
I have a maytag neptune front loader (MAH8700AWW) unless I turn the water off @ the faucet the water continues to run into the washer after the load is done .How can I fix this.
Posted on Aug 17, 2008
HELP! I have a Maytag Neptune model #MAH8700AWW. Water is leaking from under the machine when in the wash cycle. I just replaced the drain assy. pump. My machine was not leaking before the new part. The assy pump is not leaking. Water seems to be coming from the front of the machine. Anyone else had this problem?
Posted on Sep 14, 2008
I was able to fix the problem of bleach and softener not dispensing by increasing the water pressure / water flow ( eg opening the supply valves more). I'd also unplugged the washer for 10 minutes, but i don't think this had any effect. I'd recently installed a whole- house water filter and I think the water pressure had dropped.
Here is advise I got from and ebay guide.
There are a couple ways Maytag directed water to the bleach and softener, both are easy to check.  Take the screws out from the door opening (both sides) and squeeze at the top lip of the front panel, it will pop out.  remove the 4 screws that hold in the soap dispenser and the two screws that hold the lid clamps (they were uncovered when you took the front panel off. at the top.  now the top should hinge back.  You should see two tubes directed at the bleach and softener dispenser.  The should be either deflected, or pinched, buy a wax motor, or a solenoid.  Power come from the timer.   Go to my web page and download the service manual (free link on left margin of my Maytag web page www.goetjen.com/maytag.htm.) for more information
Posted on Jan 04, 2009
  • stinkindog Dec 14, 2010
    The link on your web page for the on=line manual didn't work.
  • 64 Answers
You must be on the right track, must be a blockage at the back of the soap drawer, check if junior has posted a toy car! If not turn down the water pressure at the machine stop tap
Posted on Oct 21, 2007
Why maytag neptune washer water pouring out soap dispenser door?
Either there is a sock stuck between the inner tub and the water
inlet to the tub or more likely you have been using to much liquid detergent and cold water wash all the time . This can cause the supply tube below the dispenser to be plugged up. Have fun cleaning it. Warm wash should always be used. Detergent needs the heated water to work properly .
only other possibility is mice building a nest if the washer hasn't
been used in along time.
May 09, 2014 | Maytag MAH6700AWW Neptune Front-Load...
Put detergent
MLG2000A - Maytag Neptune Super Stack SL-3
1 - Select Wash/Rinse Water Temperature
2 - Select Options (Max Extract, Extra Rinse, Signa)
3 - Select Cycle
4 - Load the Clothes Washer (add detergent on top of the load in the tub, and additives [fabric softener, bleach] in their dispensers).
5 - Start the washer.
This is according to the owner's manual I have. Has worked for 14 years for me.
Jan 14, 2014 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune Washer - bleach and softner do not empty or have water left in them - how do i fix?
clean water inlet filter,then check to see if the outlet tubes from the dispenser to the tub are blocked or partially blocked with detergent.
I use liquid detergent... no problem.
Cheers
Feb 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH8700AWW - detergent drawer full of water
try removing the drawer to see if one of your kids has put something in there
Dec 13, 2009 | Washing Machines
Maytag MAH8700AWW will not dispense fabric softener
u need to replace the water valve theres 2 the cold is what u would replace
May 21, 2009 | Maytag MAH8700AWM Neptune Front Load...
Maytag Neptune Washer dispenser unit has mold and mildew inside top of dispenser compartment.
You can pour the bleach in the drawer every time you do white loads and it will stay clear too!
Just flush it out good before you do colored clothes or you may get a small bleach spot on a red shirt !
Neil
Ps. Give me a problem solved rating here on fixya.com
Aug 19, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Repairing leaking Maytag washing machine
Maytag Appliances are ****!! Don't buy Maytag. Spent $2500.00 in 2005 on Maytag Neptune washer and dryer. They have been nothing but trouble. Washer has water running in tub constantly. Recall on ground and recall on footing. Dryer making loud noise when drying clothes.The Maytag man is dead and gone.
Aug 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Neptune stackable washer...
You put the detergent directly on top of the clothes.
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Water leaking out front of maytag washer
Remove the top cover of the machine. Check to see if the three tubes going into the dispenser drawer hv not come loose. Tighten well.
Sep 11, 2007 | Whirlpool WTW6400SW Cabrio Washer
Maytag Neptune MAH5500B Front Load Washer Logo
3,745 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
