Air conditioner is not cooling. The fan is running. When I turn the thermostat past 7, the unit shuts down. Any ideas? Low on Freon?
R1003A3 Goldstar air conditioner is not cooling. The fan is running. When I turn the thermostat past 7, the unit shuts down. Any ideas? Low on Freon?
  • 15 Answers
Sounds like a leak to me - if you have a set of guages available (know anyone working in the refrigeration field???) you could tell this for certain.  Otherwise, try running it when it cools down outside and see what happens.  Take a stick thermometer, and put it in between the fins on the INSIDE condenser coil.  If they get cooler, but not down to about 50 degrees, then you are low on refrigerant.
Good Luck!
Posted on May 26, 2009
My Dometic Rooftop 15000 BTU Model 459516.701CO will come on and run and then shut off it continues to cycle within minutes of shutting off it is controlled by a Dometic Comfort Control Center 2...
THE OUTSIDE FAN MOTOR MIGHT NOT BE WORKING CAUSING THE COMPRESSOR TO GET HOT AND TRIP THE INTERNAL OVERLOAD IN THE COMPRESSOR - IF THE UNIT IS LOW IN FREON SAME RESULTS - WHEN UNIT IS FIRST TURNED ON DOES IT BLOW COLD AIR OR DOES THE AIR NOR FEEL COOL - JUST COOL AIR COULD BE LOW FREON - COLD THEN WARMS UP IS FAN PROBLEM
Jun 30, 2014 | Dometic Rooftop RV Air Conditioner
I have a rooftop ac unit on my popup that was replaced two years ago. The unit works fine but I would like the fan to shut off when the compressor isn't running. Is there a switch for putting the fan...
Please describe your controls. Does it not have low fan, high fan, low cool, high cool on the dial at ceiling? If yes, low cool or high cool setting should shut it down when temperature is reached via thermostat dial.
Aug 29, 2011 | Dometic Rooftop RV Air Conditioner
No cool air comes out
turn your entire system off and let it cool down.
turn everything up, after 30-60 minutes.
If compressor and fan running, on outside unit, check freon
level. If freon level is low, charge it. If freon is too low, crompressor
and fan want turn on. Call tech to charge system.
If fan is not running, check capacitor for fan. Unplug it, after
you tag wiring and terminal properly. Bring capacitor to local appliance
parts store, If it is bad, replace new capacitor of same specification.
This is main culprit (should cost you between $10-40)
Also, have a contact switch check. Usually, it is black.
If fan is still not working replace fan. (Usually, $80-100)
Last resort is to replace compressor.
Jun 14, 2010 | Hampton Bay HBLG5004 Air Conditioner
Outside compressor is frozen - shut the fan down. Will it defrost and be operational
Is the unit a heat pump? Did this unit freeze up during A/C mode? Only if it was due to mild weather and thermostat turned down to low., past 68 degrees. Filter could be dirty or coil dirty or low freon charge.
Jan 10, 2010 | Ruud Handle Air Conditioner
Earlier this week, I noticed that the house felt "stuffy" but the thermostat showed everything to be cooling as expected. Last night, the house was definitely warmer than expected when we got home. My...
If both fans runs (inside and outside), check if the compresor runs , if does probably the unit is low in freon and needs to be recharged after the freon leak has been fixed (remember this is a seal system and it shouldn't leak), but if the compressor doesn't work , it could be the capacitor , the pressure switch (if it's low on freon ) or the compreessor itself.But befor do anything ,if you have a digital thermostat replce the batteries.
Sep 30, 2009 | Ruud UBHC Air Conditioner
When turning the theromostat to 9 it doesn't cool the room.the fan just runs.
the system either low on freon or you have a bad leak. If its low or have no freon the unit will keep running. have the unit recharge and check for leaks.
Aug 24, 2009 | Goldstar R5208 Air Conditioner
Carrier air conditioner cycles on and off
The compressor/condenser is being called all the time. The reason it goes off is because the evaporator (indoors) freezes up when the fan is told to turn off by the thermostat. This further cooling lowers the low side pressure below the low limit switch point turning off the compressor unit.
Solution: Make sure the thermostat is wired correctly. Green wire is usually the compressor wire but maybe not.
Jun 17, 2009 | Carrier 38BRC036 Air Conditioner
Goldstar GWDH 5000 does not cool after storing this winter
sounds like low freon or a blockage in one of the lines, especially since the you say only one row of coils is cool. usually window a/c's have at least a 1-year warranty and since you are pretty close to that, the manufacturer may honor it. if not you will need to have the system fitted with a bullet piercing valve on the low side lines and see if the unit is low on freon with proper gauges. if it is not showing low then there is probably a blockage and the high side should be checked as well. if this unit was an expensive one it could be worth having it repaired. a simple recharge may cost less than a replacement, but anything else probably won't.
Jun 08, 2009 | LG Goldstar GWHD5000 wall/window Air...
Compressor shuts down when warm outside
make sure you provide shade for your unit. It may help keeping it cool.
Aug 27, 2008 | Honeywell Electronic Programmable...
Fan runs, shuts down on cool
Sounds like a power supply problem. There is enough power to run the fan but when you turn it to cool the current draw by the compressor drops the voltage. The lower power light is telling you the answer to your problem.
Jul 17, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
318 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
