Question about Electrolux Washing Machines
Washing machine will not spin or drain
Have drained water out with emergency hose and have also cleaned out the filter next to it
Check to see if your belt is still on the track.
Then if it the belt is on the track, it may be the timer.
Posted on May 27, 2009
  • vgrantc2 May 27, 2009
    I thought about it and the timer may be bad. that is at the top where you turn the washer on in the casing. Look up timer for your washer. The is what tells your washer wht to do and when to do it.
  • 464 Answers
If your machin is semi automatic, check for the following thing. there is belt thye thread connecting the drain controller and the drain switch. this should have worn out. open the cabinet and check it out. the spin also wont work unless the drain switch is good and clear.
Posted on May 26, 2009
Wat area is the pump filter on my Samsung washer and dryer combo
How do I clean the debris filter in my front loading Samsung washing machine?. Open the filter cover(A) by using a coin or key.Take one end of the emergency draining tube (B) out.Open the emergency drain cap (C) by pulling it. Allow all the water to flow into a bowl. Note: hold the cap at the end of the emergency draining tube (B) and slowly pull it out. Note: you may need to drain several bowlfuls of water. . Prepare a dry cloth. Wash any dirt or other material from the debris filter. Make sure the drain pump propeller behind the debris filter is not blocked.Replace the debris filter cap tightly.Reinsert the emergency drain cap and the drain tube.ake sure to replace the debris filter and emergency drain cap after cleaning it. If they are not reinserted properly your washing machine may leak or otherwise malfunction.Close the filter cove
Sep 30, 2016 | Samsung Washing Machines
Tip
AEG Electrolux Lavamat 50600 is not spinning here are a few work throughs
Download manual
First off that was a link to the online user manual. If this was the first time using the machine did you follow the recommended first time use procedure by following these steps:
Before using your machine for the first time
0 Slightly pull the detergent compartment out of the control panel.
0 Pour about 1 liter of water through the detergent compartment into the washing machine.
When this has been done the ?KO lock can function correctly.
0 Run a wash cycle without laundry (COTTONS 95, with half the amount of washing powder).
This removes any residues from the drum which may have been left during manufacture.
If you have used this prior to the problem occurring try this:
The issues for not spinning are numerous as to what may cause this and it appears to be a lot but most of it is rather simple :
If there is water in the drum you need to follow the pump out procedure and remove water in the drum. Then there may be a "Bend" in the inlet hose. If there is water reaching the drum this is the possible causes and simple to check:
Water is leaking out from under the washing machine.
Fabric softener is not added, compartment for fabric softener is filled with water.
Appliance does not spin, water in the drum.
Washing has not been spun sufficiently, there is water left in the drum.
Door cannot be opened.
The rinse water is cloudy.Possible cause
The inlet hose connection is not tight.
The inlet hose has a leak.
The drain pump cover is not tight.
Washing is caught in the door.
Suction cap in the fabric softener compartment is not correctly fitted or is blocked.
RINSE HOLD selected.
SOAKING program is terminated.
There is a "Bend" in the outlet hose.
Maximum pumping height (drain height 1 m from the position of the machine) is exceeded.
Drain pump is blocked.
The water drainage system is blocked.
The door is locked due to safety reasons
Probably caused by a washing powder with a high silicate content.
Troubleshooting these are the remedies:
Tighten the inlet hose connection.
Check the inlet hose and if necessary replace it.
Tighten cover by turning clockwise.
Abort the program, remove the washing caught in the door, start a new program.
Clean the detergent compartment, fit the suction cap on firmly.
Deselect RINSE HOLD.
Pump out water and set the main wash cycle as desired.
Eliminate the Bend ( it would not allow me to use the proper word here see manual.)
Please contact AEG Service Force Centre, it has a retro- kit available for pump heights above 1 m.
I would definitely try this as it appears to the reset procedure for this machine:
Switch off the machine and pull the plug out of the socket
I would say no less than 20 minutes
but do this while waiting further:
clean the drain pump.
Clean the blockage
Carrying out an emergency emptying
1 Warning! Isolate the washing machine from the main supply before the emergency emptying!
If the washing machine no longer pumps out the water an emergency emptying must be carried out.
Warning! The water, which flows out of the emergency emptying hose can be hot.
First allow the water to cool down before emergency emptying!
0 Put down a flat container to catch the water draining out.
0 Pull down the flap in the left corner of the base strip and remove it.
0 Release the emergency emptying hose from its holder.
0 Pull the emergency emptying hose out a little.
0 Place a container underneath to catch the water.
0 Release the plug of the emergency emptying hose by turning it anti-clockwise and pull it out.
The water will drain out. Depending on the amount of water, it may be necessary to empty the container catching the water several times.
To do this, temporarily close the emergency emptying hose again with the plug. When the water has drained out completely:
0 Push and twist the plug firmly back into the emergency emptying hose.
0 Push the emergency emptying hose back in a little and let it catch onto the holder.
0 Replace the flap in the base plate and close it. When the washing machine is completely empty, the ?KO lock can no longer function correctly. Therefore before the next wash pour in approx 1 liter of water (pour it in through the washing powder compartment)
steps to Clean the drain pump
1 Warning! Switch off the washing machine and pull the plug out of the socket before cleaning the drain pump!
0 First carry out an emergency emptying (see section "Carrying out an emergency emptying").
0 Place a towel on the floor in front of the cover of the drain pump. Surplus water may flow out. 0 Unscrew the cover of the drain pump by twisting it anti-clockwise and pull it out.
0 Remove any foreign bodies which maybe in the pump housing.
0 Check whether the impeller of the pump can be turned. (It is normal forthe pump to turn in steps.) If the impeller cannot be turned at all please contact your local AEG Service Force Center.
0 Replace the cover (insert the ridges on the cover into the guiding slots)and screw on tightly in a clockwise direction.
0 Close the emergency emptying hose, push it in and twist.
0 Close the flap. I sure hope this helps a few people especially the one who I posted this for initially. GOOD Luck! If none of these suggestions work then best to call AEG for servicing, I strongly believe that the Bend in the inlet hose or the drain pump most likely the culprit and or any one of the other issues may well resolve the spin malfunction as well as possibly the main computer may have been goofed due to a slight power surge which unplugging from electric and turning off water for 30 minutes is the basic reset procedure for most electronics ( not all ;but most) while working through these steps should not hurt a thing.
on Dec 26, 2014 | Washing Machines
Didn't drain. Won't spin.
Hi Kat, let's see if I can help your with this. The washer will not spin when it senses water inside so we'll start first with the drain. When the machine was finished washing, did you hear the drain pump attempting to discharge water? Try selecting the "Spin Only" or "Rinse and Spin" cycle, you should be able to hear whether or not the drain pump is attempting to operate. If you do hear it running, but the water is not draining, it is possible that the drain filter is clogged. If you need instructions on how to clean the filter let me know. Otherwise, we'll move to the next step.
Mar 07, 2015 | Samsung WF203ANW Front Load Washer
Hi, the challenge is that it washes and wont drain through the hose until i remove the filter
Hi.
Check that the drain hose height and elbow setting is correct, or the problem will be giving by water re-fluxing into the appliance from the drain hose.
Access the filter and clean it.
Check for blockage at drain pump hose.
Replace the filter if you have not done it yet.
Check and clean the hose connected to pressure switch.
Here a general article that I wrote about no-spin problem: If you have no spin ...
Regards.
Ginko
Apr 19, 2011 | Haier XQG50-11 Front Load Washer / Dryer
Washing machine Airturbo stops at 17 minutes and 7 minutes and error code SE appears. what is to be done washing nachine is one year old only
  1. Open the filter-cover near the bottom of the machine. Unscrew emergency drain cap by turning it to the left and drain off all the water. Unscrew the filter cap and take it out. Wash any dirt or other material from the filter. Make sure the drain pump propeller behind the filter is not blocked. Replace the filter cap. Replace the filter-cover.
  2. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
  3. If the water only trickles out of the draining hose, pause the washer and blow air down the hose, you should hear the water inside the unit bubble a few times. If you don't hear bubbles, the hose is still blocked.
  4. Drain the load, empty the washer of clothes and try running a rinse & spin cycle. You should repeat this until the water runs clear from the drain hose.
  5. If the machine still fails to drain, you may need to replace your Drain pump.
Feb 26, 2011 | Samsung Washing Machines
My bosch wfd 2460 won't spin and drain
Needs to drain 1st then spins after this if not draining .Clean filter take out small hose next to filter to assist in removing water 1st if drum quite full ..Then clean filter this should cure,,,
Nov 16, 2009 | Washing Machines
Zanussi washing machine won't start E10, E40 & E50 at times
It was suggested that the pump had failed and taken out the programmer with it - expensive! Wife wouldn't wait, and bought new machine. Problem almost solved - anyone want an out of order washing machine?
Feb 03, 2009 | Zanussi ZWF1440 Front Load Washer
LG front loading washer (3 years old?) not spinning
Open the access door at the lower left front of the machine. Use the small hose to drain the remaining water from the machine. Remove the filter (the big knob thingy next to that little drain hose) and clean it out. Washer will not spin if there is still water in the tub. If there is nothing in the filter, you may have a pump motor / impeller problem. Do an "ask me" if need more help.
Sep 04, 2008 | LG Washing Machines
Washer won't rinse and spin
clean the drain hose, but make sure you have a container to catch the water and lot of debris will come out. Then unplug the washer and put water on spin cycle to drain water, after draining water remove the pump filter located next to the drain hose turn left to open and clean more debris. I found my husband wedding band I thought he lost it on purpose. You will be surprise how much funk is in that filter. Turn pump filter to right to close and put cap back on hose. Don't call the repair guy. Hope this helped.
Darlene, New Orleans
504-296-4391
Jul 24, 2008 | LG WM-1832C Front Load Washer
Washing Machines Logo
154 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Chris Hall
Chris Hall
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
