Question about Bernina Artista 180
Bernina 180 back thread
When I do some basic sewing, hemming, etc. the back thread is all loopy & does not secure the stitches.
The first thing you can do is check the tension, sounds to me like it is too loose. Then be sure the bobbin is in and threaded correctly.
Hope this helps.
Posted on May 26, 2009
Make a rolled hem
If you want it done entirely by machine you will need a special attachment. You'd have to check the make and model of your machine to find out if there is an attachment available from the maker. If not, there are some companies that make general attachments, and they'll list what machines these will fit. Check online sewing supply houses for this kind of thing.
You can also make one by hand. Any decent sewing book would tell you how. Usually you sew a straight stitch along the hem, using quite small stitches. Trim hem to a quarter inch from the stitch line. Crease the fabric or press it along the stitch line to the inside. Anchor your hand thread, then take a short stitch right along the stitch line. Next catch one thread of the fabric a quarter inch above the stitch line. It's just a basic running stitch, back and forth. Every few stitches, gently snug up the thread, which will roll the hem over. The finer the fabric, the smaller the stitches you take where they'll show should be.
There are some images that will help, if you enter the following search terms in google, you will see several pictures. Type the words," Illustrations for how to make a rolled hem by hand ? " and you will get a load of ideas.
Oct 09, 2014 | Sewing Machines
Zig zag problem on Bernina 910
Have you rethreaded the machine, making sure to get the thread between the tension discs?
Jan 31, 2013 | Bernina Sewing Machines
How do you start embroidering a design where the thread breaks on a Bernina Artista 180 sewing/embroidery machine?
Most machines have a stitch counter, stitch forward and step back features. Check your manual and embroidery machine's screens for this.
IN case you have misplaced your manual I found this one for you. It's big so allow time to download.
http://www.itsastitchonline.com/mastery_on_the_web/Mastery_170_180_1-10-02.pdf
Sep 10, 2012 | Bernina Artista 180
What causes the bottom stitch to look like it's catching the material when I sew?
try changing the needle--flat side to the back of the machine
the needle & thread & fabric have to be compatable
light weight fabric requires a different needle than medium to heavy weight fabric
if you do not have a manual check with bernina customer service about one
or
sewing partsonline.com
try a top tension of 3 or 4
clean under the needle plate & in the bobbin area for loose thread or lint
Mar 30, 2012 | Bernina Artista 180
Why won't my Bernina Activa 140 sew the blind hem stitch?
Are you absolutley sure you're not getting a problem with stitch formation on, for example, wide zig-zag. Check again, using a different colour top and bottom and make sure that the stitch is being formed properly with only the top colour on top and bottom colour on the bottom. It sounds as though the bottom loop is not being picked-up by the hook properly. Make sure you've thoroughly cleaned-out any fluff under the stitch-plate and remove the hook/shuttle and give the hook race a good clean and give it a single drop of oil, even if you've got the lightweight part-plastic hook/shuttle fitted.
Nov 19, 2011 | Bernina Activa 140
I have a Bernette 65 and when I sew, the stitch is loose and sometimes loopy on one side. The stitches are crooked on one side and the other side they are loose and the understitch is visible. What do I...
check the thread tension
check the needle to make sure it's the right one for the thread
to check the needle to if it's work with the thread
here's how to check
cut a 8 inch piece of the thread your going to use for the project, take the needle your going to use out of the machine or package, & insert the 6-8 inch thread into the eye of needle
& lift on side of the thread up to a 45 degree angle & if needle is the right size needle for the thread, it will side down the thread easily,,but if it hangs up you need a needle 1 size larger
Sep 25, 2010 | Bernina BERNETTE 65 Mechanical Sewing...
How to use double needle
That stitch is called a coverhem or a coverstitch. It is made with a coverhem machine which is basically a serger with an orbiting looper. Many upper end home sergers have coverstitch capabilities (Elna 945)
To use a double needle, simply thread two threads the same way that you would thread one. ONLY USE A STRAIGHT STITCH, AS THE NEEDLE WILL STRIKE THE PLATE IF IT ZIG ZAGS TOO WIDE.
Jan 05, 2010 | Bernina Artista 180
Thread tension problem when sewing on heavy fabrics
Sometimes when I need to use heavy thread for top stitching to reinforce a seam that has come undone, I will use the heavy thread on the top and regular thread on the bottom. I haven't tried it the other way around for hemming but I would think it would work. I do not currently have a Bernina.
Jan 15, 2008 | Bernina Artista 180
Sewing Machines Logo
190 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
