Question about HP Pavilion dv1000 Notebook
Screen replacement for a dv1000 laptop notebook?
I have a dv1000 and i bought a whole replacement screen because the back light went out and i don't even know where to begin to take the old one off..can anyone help out?Thanks,Steve
  • 1 more comment
  • Steve M May 30, 2009
    Thanks guys but i'm still having problems.I have replaced a few on older laptops but for some reason i can't get this plastic hinge cover off.I used the screwdriver and tried to pop it up from the hinges but it is not coming off..If i pry any harder i'm gonna break it
    I got it off and back on.I had forgot about the screws under the battery.Well actually i didn't forget is just didn't know haha. Anyways just my luck i get the replacement i bought hooked up and i have the same problem.I can see everything but only under the light. I bought it from an ebay computer store and they had 100% feedback but i think i might have just got a bad one.Hopefully they will refund or send me another one...Anyways,thanks for all the help guys.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Did the screen come with its own backcover and front bezel or is it just the bare screen?
    Sergeant:
    Champion:
  • 212 Answers
Where the screen looks like it connects to the computer tehre are screws underneath. You will have to remove some of the plastic pieces to get to it. Once You take it apart You can see how it goes. I was scared my first time when I had to do it but after you do it once You will never forget how to do it.
Posted on May 26, 2009
    President:
  • 688 Answers
Hi steve
The screen shouldn't be to hard to replace.
I have found that for great take apart video youtube is best.
here is a link to a video that may help you get the concept even though
it's not exactly your computer most laptops are similar in design.
Check it out:
http://www.youtube.com/watch?v=6eorC7BI7JY
You can also you searches for other video about laptop lcd replacement and there are a bunch
Good Luck
If this helps you please leave a vote in fixya
Hp dv1000 does not power up
maby the charger is not compatible with your laptop.
Aug 25, 2012 | HP Pavilion dv1000 Notebook
I have an HP Pavilion Notebook. Quite unexpectedly, I went to turn my computer on, and the screen never came on. The lights on the keyboard lit up, but not the screen. I let it sit for a day, turned it on,...
Hi tecarter...
Hook your laptop to an external monitor and see if the screen comes on...if it does then your lcd screen is faulty and needs replacment.
If it does not come on then re-download your video driver/s.
If that does not work.
Maybe your lcd inverter or backlight bulb is faulty and needs replacement.
Please take time to rate me thumbs up
Sep 14, 2011 | HP Pavilion dv1000 Notebook
First our screen was going red, started in the bottom left hand corner then as the computer was on it would gradually lessen. Then one day we went to boot up computer and screen was all red then nothing...
Hi:
You may not have ot rep;ace the entire screen or the backlight on one side of the screen if you open it up there is a inverter board make sure the connection wires from the main board to the inverter are not pinched from opening and closing the lid.
Jan 23, 2011 | HP Pavilion dv1000 Notebook
The screen remains black when computer is turned
maybe a hardware problem, on booting the pc, move the screen to every angle to see if there is a connection problem.
If so, then use your warranty if you have one.
Jun 13, 2010 | HP Pavilion dv1000 Notebook
HP DV1000 screen too dim
The 4 most common problems with dim lcd's on a laptop are boken screens, bad power inverter, bad florescent bulbs or a broken cable.
You can test the power inverter with a meter.
There should be 2 bulbs. If your screen is dim and your inverter is good and you can still make out what is on the screen, you probably have a bad bulb. If you can't determine which bulb is bad you'll have to replace both.
In my opinion, the easiest way to handle this is to replace the whole screen. Yes, it's more exspensive, but consider that it is most likely to fix your problem. A replacement screen comes with the power inverter, both bulbs, and the cable; already assembled and ready to install.
Mar 06, 2010 | HP Pavilion dv1000 Notebook
Screen replacement.taking the old off and installing the new
OK this is sorta ez and hard. Before you start unplug and take out battery. Ok on most laptops on the top part of the keyboard area is space where there are buttons for volume/power/etc. That piece comes off by using a tiny screw driver. Look for a little dip in the plastic it unsnaps there by popping it up. once this is off you remove the keyboard by removing either the 2 or 3 screws that hold it down. Now dont yank the keyboard out since there is data cable you need to pull out. By holding the keyboard in 45 degree you can pull the data plug from its socket. Now you have the keyboard out and from there u can see that there is a cable that runs to your lcd. Unplug it. That was the worst part of the ordeal. Now close your LCD and turn the lappy over and directyl under the lcd hinge under the laptop should be a tiny bolt holding the hinge down. Remove those and then open the laptop up at and try to pull the LCD out if it still dont come out then there are 2 more screws on each hinge u need to remove. Now it should come off. VIola its done now just put back the new one in same fashion. First hinges
May 26, 2009 | HP Pavilion dv1000 Notebook
Hp DV1000 backlight flickers on then off on button press
If you go to this site you can get step by step instructions. The lamps and inverter aren't really that hard to replace if you can follow directions and have patience. Good Luck, hope this helps.
Jan 17, 2009 | HP Pavilion dv1000 Notebook
Display went dark
The backlighting is provided via the LCD inverter as you described.
Dec 08, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion DV1000 Screen Replacement
Here's the HP manual for it, too many instructions to post and the pictures should be helpful. Just take your time, figure out what you're going to do twice and then do it once. Much cheaper to take a few hours longer than you'd figured on than to fix a self-made problem:
http://h10032.www1.hp.com/ctg/Manual/c00312379.pdf
(Starts at 5-31)
Oct 17, 2008 | HP Pavilion dv1000 Notebook
Hp pavilion dv1000 notebook Pc will not start
mother board filure willbe the reason . consult a n authorized service technician
Dec 07, 2007 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
106 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
