Question about HP Pavilion dv1000 Notebook
Screen replacement.taking the old off and installing the new
I have a dv1000 and i bought a whole replacement screen because the back light went out and i don't even know where to begin to take the old one off..can anyone help out? Thanks,Steve
    Brigadier General:
  • 8,619 Answers
Hi Steve
Thanks For using FixYa. Please check this link which will explain you what needs to be done.
HP Pavilion DV1000 Service Manual
Please do rate the solution as FixYa and revert for further assitance.
Thanks
Rylee
Posted on May 26, 2009
  • 85 Answers
OK this is sorta ez and hard. Before you start unplug and take out battery. Ok on most laptops on the top part of the keyboard area is space where there are buttons for volume/power/etc. That piece comes off by using a tiny screw driver. Look for a little dip in the plastic it unsnaps there by popping it up. once this is off you remove the keyboard by removing either the 2 or 3 screws that hold it down. Now dont yank the keyboard out since there is data cable you need to pull out. By holding the keyboard in 45 degree you can pull the data plug from its socket. Now you have the keyboard out and from there u can see that there is a cable that runs to your lcd. Unplug it. That was the worst part of the ordeal. Now close your LCD and turn the lappy over and directyl under the lcd hinge under the laptop should be a tiny bolt holding the hinge down. Remove those and then open the laptop up at and try to pull the LCD out if it still dont come out then there are 2 more screws on each hinge u need to remove. Now it should come off. VIola its done now just put back the new one in same fashion. First hinges
2 Suggested Answers
  • 212 Answers
SOURCE: screen replacement for a dv1000 laptop notebook?
where the screen looks like it connects to the computer tehre are screws underneath. You will have to remove some of the plastic pieces to get to it. Once You take it apart You can see how it goes. I was scared my first time when I had to do it but after you do it once You will never forget how to do it.
Sound but why no picture?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Aug 25, 2015 | Vizio E701i-A3
This is a new monitor, had it running 2 days, screen started flickering on/off every 8 seconds, then it went dead. All connections were tight. I just plugged in a old monitor to get on line since I am...
The monitor you just bought died - hardware failure. Take it back to the one from which you bought it and either replace it or get your money back.
May 27, 2011 | Samsung Computers & Internet
First our screen was going red, started in the bottom left hand corner then as the computer was on it would gradually lessen. Then one day we went to boot up computer and screen was all red then nothing...
Hi:
You may not have ot rep;ace the entire screen or the backlight on one side of the screen if you open it up there is a inverter board make sure the connection wires from the main board to the inverter are not pinched from opening and closing the lid.
Jan 23, 2011 | HP Pavilion dv1000 Notebook
Backlight failure HP DV1010
You need a new screen or inverter, depending on the problem. You can't replace the backlight itself because it is build into the LCD panel. Using a mercury reaction, it makes light. Because of the mercury, it is also dangerous to replace.
Jun 25, 2009 | HP Pavilion DV1010 Notebook
Screen replacement for a dv1000 laptop notebook?
hi steve
The screen shouldn't be to hard to replace.
I have found that for great take apart video youtube is best.
here is a link to a video that may help you get the concept even though
it's not exactly your computer most laptops are similar in design.
Check it out:
http://www.youtube.com/watch?v=6eorC7BI7JY
You can also you searches for other video about laptop lcd replacement and there are a bunch
Good Luck
If this helps you please leave a vote in fixya
May 26, 2009 | HP Pavilion dv1000 Notebook
Cannot get comp to install resource cd
pls take out all pci cards and have u installed AGP for VGA instead of in built tell me the make of ur vga , i think i can help u in this the first blue screen thing u were facing was not ur motherboard infact ur RAM u have changed it it should be gone even on ur old system, u have also changed the hard drive it has nothing to do with freezing thing u were facing ok
tell me how many pci cards have u installed in ur system and what abt VGA is it in built on mother board or additionally fixed by u , actually something is faulty and it is causing u trouble in hardware kindly do this
take all pci cards out modem , sound,tv card
use new RAM chips
just install RAM and VGA to start take out all drives like dvd or cd just leave one for installation the newest one
u can use ur old hardrive or new i dont feel it is ur hard rive
and then try to install OS without pci cards if u have
check the CPU fan is it running and also check the Casing Fan also
pls tell me the results
if not resolved tell me the whole config of ur system what u have inside
i can solve ur problem if u want
regards
Feb 28, 2009 | Dell Dimension 4300 PC Desktop
Tecra 8200, I have bought a replacement keypad
take it to a shop. because i know how to do it but you hav to take the whole cover of the laptop then take the old one off and put the new one on the screw everything back. the thing you shouldnt have bought a new keyboard. because its not the key pads its probably the panels under them might be meesed up. but you can try to open it up and install the new one but one mistake could cost you $100 or maybe $200 so the chance is pretty risky
Nov 29, 2008 | Toshiba Replacement Keyboard
DV1000 KeyBoard Replacement
you press just enough to hear it click. Light pressure... You will feel the difference when it snaps into place.
Nov 27, 2008 | HP Pavilion dv1000 Notebook
Hp Pavilion dv1000 Black screen
It is either the inverter board or the bulb
If it looks pink in color than it is the bulb and that can be quite the intensive project to replace
If it is the inverter board than that is not so bad and you can pick up an inverter board on eBay usually for around $10 to $20 and that usually installs right under the LCD screen (usually screwed to the LCD screen)
The inverter board is what powers the light bulb the data cable is totally separate function.
If you can see data on the screen with a flashlight but there is absolutely no light coming from the screen at all ever than it is probably just the inverter board
But there is a possibility that you could order the inverter board and have it turn out to be the bulb and if that is the case then unless you are very comfortable taking apart laptops then maybe a new screen would be best since you practically have to take apart the LCD to change the bulb.
But screen cost around 100 to 150 on eBay so if you decide to do that then might as well try for a deal like this: (I just spotted this on eBay and it is for entire new top half of laptop with glossy screen and inverter board wire harness and all for the same price or less than just the screen http://cgi.ebay.com/HP-dv1000-Pavilion-14-1-BrightView-Glossy-LCD-screen_W0QQitemZ310102538774QQihZ021QQcategoryZ31569QQssPageNameZWD1VQQrdZ1QQcmdZViewItem#ebayphotohosting
That is guaranteed to solve your problem for sure.
Nov 24, 2008 | HP Pavilion dv1000 Notebook
Hp pavilion dv 1000 screen replacment
Here's the directions: http://h10032.www1.hp.com/ctg/Manual/c00312379.pdf
(Starts at 5-31)
Jan 24, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
90 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
