TV WONT TURN ON AFTER POWER FAILURE
POWER WENT OUT A COUPLE TIMES TODAY, THE CABLE BOX CAME BACK ON, BUT I CAN NOT GET THE TV TO TURN ON EITHER BY REMOTE OR TOP POWER BUTTON. i UNPLUGGED EVERYTHING FOR A WHLE AND THEN PLUGGED INTO A DIFFFERENT RECEPTICLE-NO LOCK.I HAD PLUGS INTO A SURGE PROTECTOR. I HAVE ONLY HAD tv SINCE mARCH.
    Scholar:
  • 145 Answers
What type of TV to you have? Check manufactures website for possible solutions.
Search model # on: www.google.com
Posted on May 26, 2009
HDCP AUTHORIZATION FAILURE- HDMI PORT DISABLED
i just had it happen half hr ago and pulled power cable out of box for few seconds and plugged it back in...turned it on and it basically reset itself works great now
Apr 15, 2012 | Televison & Video
Daughter's TV was on during bad electrical storm. Screen went black and made high pitched sound. cable, internet and telephones all digital through Time Warner Cable. Now TV will not even turn on;...
Ur Main Fuses in the circuits breaker box must be to be restart it back.Turn off/on all the fuses on the main circuits breaker box to all the fuses in the box of the box to restart.All ur electical power outlets should work again.If not those power plug in outlets are shorted and dead must have to be replaced.
Aug 22, 2011 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
No picture 2 days ago power went out thru out the neighborhood, once power came back TV worked great. today, go to power on TV, here it clicking, but no picture... cable box working, cable working in 2nd...
It sounds like there`s a sort on the secondaries of the power supply. Before the power went off, did you ever turn the tv off by unplugging it?? In other words, did you turn the power off completely to the set or leaving it in standby?? if you always left it in stby, it will be the capacitors in the power supply, they dry out if the power is always on, so they will need replacing. If you did turn off the power, then I think you`ll find that the power cut had nothing to do with the fault you`ve got now, it will be the Line Output Stage which has failed or gone short circuit. Ian
Aug 05, 2009 | Sony Televison & Video
TV Wont come on
may be.but most of the time the problem is in your horizontal output transistor or your str,regulator.
Sep 02, 2007 | Broksonic CTGV-5463TCT TV
Tv wont come on
i think it's the built-in power surge/failure sensor.  Plug the TV into the wall and press RESET on the remote twice.
Jul 07, 2007 | Sanyo DS24425 24" TV
Televison & Video Logo
306 people viewed this question
Top Televison & Video Experts
Electro Med Services...
