Question about Sony Audio Players & Recorders
Cannot get cassette doors to eject
Sony cassette deck doors won't eject what do i do?
  • addiegrundy May 29, 2009
    How do you get the doors open without forcing them open and possible breaking them?
    President:
  • 1,348 Answers
The motor that drives the mechanism is jammed or burnt out.if you remove the cover and turn the big metal weights driven by the motor,the unit will dock the assembly and the door should open.
it thinks it is playing a tape and that is why the eject doesnt work
Posted on May 26, 2009
  • kirtec auto Jun 16, 2009
    you have to take the back off of the unit. when you open it up,you will see two drive belts that drive the mechanism.pull carefully til the mechaism docks and clicks.then the eject will work
  • kelso9042
    kelso9042 Feb 02, 2013
    thank you! this worked perfectly
I just got an Onkyo R1 TA-RW505 dual cassette deck and the left deck door won't open with the eject button. I did get it open by sliding a slim knife behind the door and it appears that there is a
This is most common as the catch is there to stop you from opening the cassette door while the head base is in the up position. The reason many of these cheap dual cassette decks all have this problem is that the mechanisms are not built to last and then the cost to repair them exceeds their value. You need to find out why the mechanism is not getting back to the stop position and when you do this the eject issue will be fixed. Typically it is a stretched belt.
Putting it in is another matter though.
Mar 11, 2013 | Audio Players & Recorders
Sony TC-WR690 doors will not open to remove the cassette.
If you remove the cover after unplugging the AC, you will see that when you push the eject button that on the back side the putton is held back by a white plastic piece. Push down the white plastic piece as you press the eject button. The door will open and the tape will release. I jsut did this today on my Sony TC WR 670 dual tape player. Both sides were blocked. I noticed that both fuses on the board were also blown. New fuses didn't solve the problem. May be that the transformer is out?
Apr 21, 2012 | Sony CASSETTE DECK Single Dual Cassette...
I have a duel cassette player sony model # TC-WR 565. The doors will not open and both casettes cannot be removed even after prying the door open.
Mine did that - you will have to patiently keep pressing the clear / stop / pause / etc and even power cycle a few (or many) times and finally you will hear the mechanism release the cassette. Once you hear that - you will be able to eject the cassette. After that go replace the belts.
Dec 29, 2010 | Sony TC WE435 Stereo Dual Cassette Deck...
Sony TC WR565 dual tape deck. Both doors will not
you can not fix it without tearing it apart. if you do take it apart, try to get the front panel off. Hit the eject button and look for a lever that is stuck.
Jun 17, 2010 | Sony TC-WR565RM Single Cassette Deck
I can't eject the cassettes from the deck - both seem to be stuck. How do I fix this problem?
only one way. I did this before. take your fingernails, stick them in the top of the door, and pull. want to use it again, put tape to hold door close.
May 11, 2010 | Sony TC-KA3ES Dual Cassette Deck
Sony Dual-Deck Cassette Player/Recorder, doors won't close
Are both sides not staying shut? If it's only one side, look to see if the latch is broken. You should see an arm move when you press down the eject button - while the door is open, press the eject button and see where the arm moves. You should see a hook that catches the door and keeps it closed. It could be broken, or just jammed. Look at the other side of the deck and see it it looks like it's working the same. Unjam the latch arm if it's stuck, or replace it if it's broken.
Feb 23, 2009 | Sony Dual-Deck Cassette Player/Recorder...
545 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
