Question about Whirlpool Dryers
Dryer does not want to tumble
My whirlpool cabrio electric dryer does not want to tumble ?
Felicia
make sure to see if the blower runs free
in this case is your drum belt broken
if you have someone at home to dissassamble the dryer then
replace the belt and test the machine
this is a normal situation when the dryers are not tumble
Posted on May 26, 2009
I moved my Cabrio electric dryer to another room. A new outlet was installed in the new room. When first plugged in, the dryer runs and tumbles but will not generate heat. Suggestions?
Your electric dryer uses110vac to run the motor which makes the drum turn. It uses 220vac to run the heating elements. I'll assume you had a qualified electrician add the new outlet. If not, I'm betting whoever did the install used the same electrical phase for both 110 sides of the plug. You can't use an electrical tester to test this as both sides will read the same. Manually trip the breaker (should be a double breaker) and then check the outlet. The wiring to the hot leads should be black on one phase and red on the other. Let me know what you find out
Oct 18, 2013 | Whirlpool Cabrio WED6400SB Electric Dryer
How hot does a whirlpool cabrio dryer get
It can because it has a water line coming from washer line it causes steam for you dryer.
Dec 15, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My cabrio stopped providing heat....the fan is working and the drum is tumbling
The heater element is located on the back of this unit. You need to pull the dryer forward and test the element. If you need more help let me know.
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool Cabrio dryer problem
Hello my name is Heath the problem is the heating element is probably burned out and will need replace.
Apr 08, 2010 | Whirlpool WED6200S Electric Dryer
Whirlpool cabrio electric dryer heats and tumbles, but clothes don't get dry
remove your duct from the dryer. DRY a few loads,IF the unit works fine with the duct off, You will need to get the vent to the outside cleaned
Feb 23, 2009 | Dryers
Dryers Logo
276 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
