Question about Acer TravelMate 5520-5678 Notebook
I am using acer travelmate 5520-5678 and the external speaker only works from the left side. Both works when I connect my headset..
  • Acer Master
  • 13,433 Answers
The other speakers cord is cut, loose, or the speaker has failed somehow.
look for a replacement on www.acerparts.com or www.pchub.com shouldn't cost much.
first I would check the connection and test the speaker and of course if your on warranty, use the warranty instead of tampering it with your self.
Posted on May 26, 2009
    Scholar:
  • 93 Answers
Sounds like the spaker on the left hand side is unhooked, blown or the pre-amp in the laptop that drives the speakers is bad, headphones are uneffected as it is a seperate system.
Joe
Speakers external
Look on the side of the laptop for the headset port. Plug your external speakers in there. Then you will have full control of volume and such through the OS system control.
Semper Fi,
Z
Nov 05, 2013 | Acer Aspire 7741z
No sounds comes out in headset but external volume is ok
Try to use external speaker. connect it where you usually connect your head and check if it work . If ever the external speaker will work it only means that the problem is your headset ( defective )If in case the external speaker will not work it means the problem is the terminal ( the port where the headset or external speaker connection )
Apr 01, 2012 | Computers & Internet
No sound when i put the headset
Hi, you need to switch it to headset, from speakers on the computer, you can do this really easy if you click the speaker icon on the bottom right hand screen, right click and go to playback devices and change it to headset so you can hear it.....hope this helps.....
Jan 06, 2010 | Acer TravelMate 3260-4874 Notebook
No sound come through external headset or desktop speaker
Sometimes the headphone jack has its own volume control separate from the internal speakers. Check the levels in the volume mixer.
Apr 22, 2009 | Acer Aspire 5500 5570-2609 Laptop
Where is the wireless switch on my Acer travelmate 2300? I never have had a problem connecting to the internet before and now I can't get wireless and it is telling me to turn on my wireless switch. ...
if you look around the laptops sides there is generally a toggle switch that slides from left to right or visa versa :
If not then there should be an application in the start menu that should allow you to enable / disable the wireless ie turn it off or back on again.
Apr 11, 2009 | Acer TravelMate 2300 Notebook
Acer 4220 TravelMate No incoming sound on speakers or Headset.
Hi, My Name is Henry. I am one of the technicians here.
Have you tried increasing the volume from the control panel settings.
Go to Start - Control panel - Sounds
When that opens double click on the speakers/headphones. Go to levels and increase that.
I hope this helps.
Please do not forget to rate my solutions to you.
Regards
Henry
http://www.clickpcrepair.com
Mar 19, 2009 | Acer TravelMate 4220AWLMi Notebook
Microphone connect have acer aspire travelmate
It appears that your Acer has 3 ports in the front center bottomportion of the laptop. One of them should be for plugging in an external microphone, one should be for external speakers, and one should be an input jack.http://complap.com/yahoo_site_admin/assets/images/acer-travelmate-2420-2.192120139_std.jpg
Feb 27, 2009 | Acer Aspire One PC Notebook
Microphone connect have acer aspire travelmate 2420 where is the microphone connection
It appears that your Acer has 3 ports in the front center bottom portion of the laptop. One of them should be for plugging in an external microphone, one should be for external speakers, and one should be an input jack. http://complap.com/yahoo_site_admin/assets/images/acer-travelmate-2420-2.192120139_std.jpg
White screen
This could be caused for a number of reasons. First thing to determine is if the computer is bad or just the screen. Hook up a external monitor to the laptop and turn it on and use the FN key to turn on the external monitor port. If the computer is running fine with the external monitor then you have a bad LCD or LCD inverter. which is replacable but expensive.. you would want to look at getting a new laptop or using it with the external monitor.
Jan 18, 2008 | Acer TravelMate 2300 Notebook
Acer 5610 sound problems
Hi, It is possible that: 1. You may have recently installed an add-on/external device such as a multimedia keyboard which changed the audio output from internal to external; 2. The laptop's internal speaker might have gone dead (highly unlikely but still a possibility) - try plugging in external speakers or a headset and check; 3. Most if not all laptops uses a female stereo babyphone jack to connect to external speakers. This jack has a built-in switch that cuts off internal speaker if an external is plug in. If you are using eternal or headset from time to time, it is possible that the switch might have locked to external and does not switch back to the internal; 4. You may have a hardware issue specifically the sound card/chipset. This of course would require an inshop repair which may be better off with an authorized service center. At worst is have the entire laptop replace if it is confirmed to be a hardware issue. Hope this be of some help/idea. Post back how things are or should you need additional information. Good luck and kind regards.
Sep 09, 2007 | Acer Aspire 3000 Notebook
Acer TravelMate 5520-5678 Notebook Logo
143 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
