Question about Philips Televison & Video
Tv keepsTurning off by it self frequently
My Philips projection tv turns it self off after a few minutes of operation. After I turn it back on it my stay on or sometimes it will do it again. It has been doing this for about 3 months it seems the problem is more frequent The model # 55PL9772
  • 431 Answers
Hi I am Vortash sounds like a component is heating and going Open circuit then it cools and the cycle begins again .. now if it is an actual component this pattern will not change however should it just be a dry joint then the set will sometimes stay on for long periods until it cools after switch off . Then the joint parts and the cycle begins again .. Now if it is a dry joint I would suggest that although it sounds an easy fix .. touching a soldering iron in the wrong place can prove rather hazardous for the unskilled not to say lethal .. and can actually cost you far more if you cross solder the wrong components on the closely packed circuit board , most engineers give a free estimate so you can also get second opinions to this problem .. I hope this is of help Regards Vortash
Posted on May 26, 2009
I have a 50" philips magnavox tv that changes channels on it own and turns itself on frequently. What is causing this issue?
Do you live with someone who likes practical jokes; even silly ones?
There are a number of companies that make remotes that can mess with someones TV or other remote devices.
I have a watch, as a gag, that will self program its remote to operate any TV capable of this feature. With this watch, I can change channels, power status and even reset the TV to factory default state.
Next time this happens, look behind you.
Jan 15, 2013 | Televison & Video
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
Turning off by itself
This TV probably needs the convergence amp IC's replaced. When they go bad the TV will not turn on.Call a good TV Tech and tell him you want the IC's upgraded to STK 392-150 instead of the original STK 392-120 and check all resistors in the circuit for proper value. They could be burned or open.
Jul 30, 2009 | Philips Magnavox 55P9271 55" Rear...
I have a philips 60 inch tv with on picture and sound
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 28, 2009 | Philips 60P8342 60" Rear Projection...
TV freezes at "Philips" screen
a professional. -These electronics go threw a self diagnostic when they start up, normally they turn off when they find a problem.
Jun 01, 2009 | Philips 42PFL3603D 42 in. LCD TV
Turn on TV no sound or picture just chirps
Get the chirping TV repair kit from www.TvRepairKits.com to fix this problem
Apr 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
TV SHUTS OFF AFTER A FEW MINUTES
Very likely to be a heat issue, the first thing to do would be to clean the ventilation slots in the back.
Feb 28, 2009 | JVC AV-60D501 60" Rear Projection...
KDF-46E2000 turns off then back on by its self
* Most common would be a couple of capacitors in the power supply that are not letting the proper voltage to the lamp.
* The lamp itself is not working properly.
Jan 25, 2009 | Sony KDF46E2000 46" Projection HDTV
I think I have the same tv. Its a philips 50 in projection tv.
Common problem with the older projection Magnavox TV set. The opto IC chip has failed. Try www.magnavoxhelp.com - They have instructions and kits on their site.
Jun 14, 2008 | Philips 9P5034C 50" Rear Projection...
Tv turns off by it self
Ours 60" (60P8342) turns off after a short period of time also. My husband researched it online. The cheap solution he was told to try is to unplug the TV (or plug into power strip and switch off) when you are done watching it. A computer board inside over heats and it's a protection mechanism for it to turn off. Otherwise, it's over $100 to fix the computer board.
May 29, 2008 | Philips 60P8342 60" Rear Projection...
Televison & Video Logo
71 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
