Question about HP Officejet 5610 All-In-One InkJet Printer
Error 0xd05d010d My HP Officejet 5610 error apper 0xd05d010d
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    There are 3 different resets that I know of for this printer try all of these:
    To do a reset press and hold the # and 3 buttons while plugging in the power.
    If that doesn't work then try these other two resets and do them the same way as you did the first one:
    press # and 6,
    press # and 9,
  • 975 Answers
Try this :
UNPLUG PRINTER FROM WALL SOCKET PRESS # AND 9 AS YOU PLUG PRINTER BACK IN TO DO A FULL RESET, let me know , AJ
Posted on May 26, 2009
    Brigadier General:
  • 8,619 Answers
Hi
This error code indicate that the product has an internal error condition. You need to Reset your Printer:
Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (error 0xd05d010d - c01424575.gif ). Figure 1: Example USB connection (your product might not look exactly the same as this example) 642b444.gif
  1. Remove the cartridges from the product.
  2. Wait for the ' Insert Cartridges ' message to display on the control panel.
  3. Disconnect the power cord from the back of the product.
  4. Wait 60 seconds.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  6. Reinsert the cartridges, and then close any open doors on the product.
  7. If you receive a prompt to print a calibration page, do so.
  8. Reconnect the USB cable to the rear of the product, and then try printing again.
Please do rate the solution as FixYa and revert for further assitance.
Thanks
Rylee
HP officejet 5610 All in one printer cannot print or work because power button,Alert button,copy,fax,scan button all were blinking on and off with message on screen Error:0xd05d010d please help, also reset...
Try to reset the printer:
Unplug the printer from power
Hold the # and 9 together while plugging it back
If still not working try again with a # and 3 combination
Oct 04, 2011 | HP Officejet 5610 All-In-One InkJet...
Message on HP officejet 5610 All in one Error 0xd05d010d and on button,copy,fax,scan and alert yellow light keeps blinking on and off "tried reset the power cord still givwing same problem.Please help
Mi impresora HP 5610 tiene encendidas todas las luces marca un errror 0xd05d010d RESET POWER, que puedo hacer.. gracias
SOLUCION: Hola la solucion para la HP Officejet 5610 con ERROR 0xd05d010d es muy sencilla hay que resetear el Equipo lo cual se hace asi:
1. Desconectas el cable que va de la impresora al equipo
2. Luego desconectas el cable de poder de la impresora
3. Mantienes presionadas las teclas (ASTERISCO) * y (NUMERO) # y conectas el cable de poder a la vez.
4. Te sale unas preguntas de Idioma y pais las respondes y LISTO
BUENA SUERTE
Aug 23, 2011 | HP Officejet 5610 All-In-One InkJet...
Hello; I have an hp officejet 5610n all in one, when I turn on my printer i have this message on the printer "Error:0xd05d010d Reset power." and some buttons are blinking many thanks
lets start uninstalling your hp oj 5610 software from the uninstall program to remove it properly. Second is to install the software again... if the problem occurs the best thing to do is to go to the nearest HP Service Center in your area... i hope it helped.
Dec 22, 2010 | HP Officejet 5610 All-In-One InkJet...
Error of printer HP 5610
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
djiu9ofdfd16
Jul 30, 2009 | HP Officejet 5610 All-In-One InkJet...
FOR HP 5610 All in One error 0xd05d010d Reset power.
0x errors mean that the printer has an internal error within the firmware of the printer. There are not many steps to try except for a reset. This is a document from hp that you can use to do the reset and hopefully it will clear the error.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en
Jan 15, 2009 | HP Officejet 5610 All-In-One InkJet...
Error code 0xd05d010d reset power
Unplug the power cord from the All-In-One as well as the power outlet.
Plug the power cord directly to a wall outlet without surg protector. (if possible connect it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Then check and see
Good Luck
Sep 16, 2008 | HP Officejet 5610 All-In-One InkJet...
Error problems
Sir i have my problem with my printer about Hp 5610..
This error appear : Error 0xD05D010D
kindly give me idea please... please sent my email add:ceasarchiong29@yahoo.com.ph
Aug 14, 2008 | HP Officejet 5610 All-In-One InkJet...
Reset Power Error 0xd05d010d
First power cycle the printer and then reset the printer.
May 21, 2008 | HP Officejet 5610 All-In-One InkJet...
Error 0xd05d010d on hp 5610
Jan 18, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
616 people viewed this question
Seeker5211
Seeker5211
