Question about Kenwood VR-8070 7.1 Channels Receiver
Receiver shuts off on its own
I have the kenwood vr-8070 a/v receiver, it will turn on and will work for a while, but then lets say like half way through a movie, will just shut itself off and the power button will start blinking, so then i push it and it stops blinking, then push it again and turns on for a while again. It does seem a bit hot, but i have nothing sitting on top of it, and it has about 8 inches of room between the top of it and the bottom of the shelf it is under, i have no idea what is wrong, can you help me figure this out?
  • ericlaw1 May 26, 2009
    ok i will try that, and will rate and let know if it helps
    ok i will try that and let you know what happens
A very common issue with receivers turning themselves off derives from a power overload caused by shorting across the speaker wires. Check each wire to make sure there are no breaks and that the ends of the wires are cleanly separated (no errant strands accidentally touching between positive and negative) at both the receiver end and the speaker end. One easy way to test it is to just use different wires and see if it happens anymore. Another unlikely possibility is that the receiver may be set to a different resistance setting than your speakers (say, 4 ohm instead of 8 ohm)--though modern receivers tend to have internal ways of recognizing and dealing with that.
Posted on May 30, 2009
I have a kenwood Auto video surround receiver DR / 409 how to reset it
PDF]KRF-V8030D VR-409 - Kenwood
manual.kenwood.com/files/B60-4593-00.pdf
VR-409. INSTRUCTION MANUAL. KENWOOD CORPORATION. B60-4593-00 (EN) ...on the country and sales area. AUDIO VIDEO SURROUND RECEIVER ...
Kenwood VR-409 Manuals
www.manualslib.com > Brands > Kenwood Manuals > Stereo Receiver
View online or download Kenwood VR-409 Instruction Manual. ... Kenwood Instruction Manual Audio Video Surround Receiver KRF-V8030D VR-409.
Kenwood VR-409 Receiver Repair Questions, Solutions ...
www.fixya.com > Forum > Audio & Video Receivers > Kenwood
Recent Kenwood VR-409 Receiver questions, problems & answers. Free expert DIY tips, support, troubleshooting help & repair advice for all Audio & Video ...
Kenwood VR-409 PDF Owner's Manual Download & Preview
www.manualguru.com > Kenwood Manuals > VR-409
Feb 03, 2016 | Kenwood Audio Players & Recorders
I have a Kenwood VR-8070 and I have a problem when I turn the receiver off for a few minutes and want to turn it back on. Everything comes on but no sound comes out of the speakers. This problem never...
Hello.
Try to switch it back off.
Unplug it from the main switch.
Then wait after a few minutes, set it back on.
Check the whether the f/m is working properly with the sound.
Sep 08, 2010 | Kenwood Audio Players & Recorders
Kenwood vr-405 turns on only momentarily and then shuts off
your receiver has a bad audio output ic.replacing ic will take care of the problem
Apr 10, 2010 | Kenwood VR-405 Receiver
Does kenwood VR-405 play DTS-HD Master
I have the 405 and a Samsung 3600 which has onboard DTS Master/ Dolby True HD. Out of the 6 movies I 've watched, only 2 have given me Dolby Digital. Bottom line: If the movie doesn't have DD, you cant get DD on the 405. I thought just about all blu rays had DD but its not so. Its time for us to upgrade!
Oct 24, 2009 | Kenwood VR-405 Receiver
Kenwood VR-509 Receiver won't power up...
Check all your speaker wires for shorts, especially behind the amp, doesn't take much for something to throw a spanner in the works, like when cleaning house and moving stuff around.
Oct 03, 2009 | Kenwood VR-509 Receiver
Kenwood VR-409 surround system clicks off when sound is turned up
Assuming you aren't turning the volume knob past half way before the problem occurs, you most likely have a damaged speaker cable or a bad driver in one of your loudspeakers. (Once your volume knob has reached about half way the amplifier is producing its maximum efficiency.)
Note the position of your volume control when the clipping occurs, then remove one speaker at a time and raise the volume. If you identify a speaker as the culprit, inspect or replace the wire running to it and try it again. If you aren't able to find a bad speaker, the problem is internal and will need to be fixed at a repair shop.
Good Luck,
BB
Apr 30, 2009 | Kenwood VR-409 Receiver
Audio Receiver shutting off
check your speaker connections you have a short or wires touching eachother
Mar 14, 2009 | Kenwood VR-406 Receiver
Turns on then shuts off like it has a bad fuse
HI...
Check to see that all the speakers are firmly connected at BOTH ends.
Also,if the receiver has speaker select switches, see if turning off the speakers allows it to stay on.
Let me know , Thanks
Feb 08, 2009 | Kenwood Audio Players & Recorders
I have a kenwood vr 406 and a kenwood rcr0609 remote. After some time, the remote stopped working , so we got a new remote. This worked about a day. The remote itself seems to be working, because I can...
Kenwood receivers recently have a commonly known problem with its receiving IR diode within the receiver, to fix this you will have to re-solder the connection on the receiver panel within the faceplate of your kenwood receiver.
Instructions to fix it are at the following link if you are willing to open up your receiver and repair it. lots of people have reported this fix as successful so it is widely believed to be a design flaw in the VR line-up of receivers as it has occured in all the VR families so far.
good luck.
Jan 20, 2009 | Kenwood VR-406 Receiver
Kenwood VR-8070 7.1 Channels Receiver Logo
307 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
