Question about Sony KP-51WS500 51" Rear Projection Television
No red in the image on the screen
I originally had red lines on my screen(A sony kp51ws500) and used the adjustment at the base of the TV to correct this problem. Now there is no red color at all in the image and my power light flashes 5 times ever few seconds, but when I power off, I can see the red flicker as the screen goes dim. Is the red projection gun gone out or is this a high voltage problem and can this be fixed? Thanks, DB ... Bryan, Tx.
  • Sony Master
  • 8,617 Answers
The adjsutment that you turned down was the G2 voltage to the red tube which is just a temporary fix for a CRT which has a short developing in it. Try turning up the red adjustment again only slightly to see if the red CRT ( tube) will light up
if it does and then the set shuts down its most likely the red CRT which is bad . If it lights up but you get retrace lines but doesnt shut down it possible that its the CR board ( Red CRT Drive Board) which is at the very bottom of the red tube.
Posted on May 26, 2009
Sony TV Model No. KP51WS500 flashes green & turns off
yes u will have to get a expert in but here is a guide to help your tv is going into protect mode if the screen is flashing green with white lines in it its likely that the green tube is faulty this is very expensive & u my want to purchase something else.
Apr 08, 2010 | Sony KP-51WS500 51" Rear Projection...
Double image and 3d color
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 17, 2010 | Sony KP-43T90 43" Rear Projection...
Getting "red" double image
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Apr 27, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
The screen is just blue... apparently, the red ad green lights are blown. How do I rectify this situation? Sony rear video tv kp51ws500
Problem : Convergence Chip Failure ( common problem )
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution :
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com.They have put together a kits for most models. If you don't see a kitfor your set send them a quick note and they will put one together foryou. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Mar 29, 2009 | Sony KP-51WS500 51" Rear Projection...
Double image on my Sony KP 43t90
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Feb 22, 2009 | Sony KP-43T90 43" Rear Projection...
Double Image Red and Green
  • Screen looks 3D
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 08, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP51WS500 Rear Projection TV,Convergence Problem
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Dec 29, 2008 | Sony KP-51WS500 51" Rear Projection...
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
The screen turns red after being on for about 30 minutes
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
or
Nov 10, 2007 | Sony KP-65WV700 65" Rear Projection HDTV
Sony Kp-65wv700 Too much red -- white looks redish
fix the red:
Nov 01, 2007 | Sony KP-65WV700 65" Rear Projection HDTV
Sony KP-51WS500 51" Rear Projection Television Logo
189 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
