Question about Canon Cameras
Automatic lens cover will not open.
FS100 Canon Camcorder. Camera operating properly, except the automatic lens cover will not open. What to do?
  • Canon Master
  • 4,738 Answers
It's likely a little sand or grit got in there and is creating friction preventing it from opening. But the FS100 is a relatively new camera, and is likely still under warranty. Call 1-800-OK-CANON to see if they'll help. Here are some other options. Try these ONLY if Canon cannot help you (stick with the non-obtrusive fixes only, don't open up the camera):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Posted on May 26, 2009
  • 464 Answers
Please try resetting your camera to the factory settings..the procedure to reset is found in the instruction manual as well as in the cd that came along with your device. thank you for using fix ya
Shutter does not open
I guess the lens cover mechanism is stuck.
Jul 11, 2014 | Canon FS100 Flash Media Camcorder
My canon hf 200 automatic lens cover will not open
The lens cover mechanism in these cameras is susceptible to debris and requires disassembling the camera to repair. This can be repaired fairly inexpensively. However, it's not a user serviceable problem due to the fact that the camera will need to be partially disassembled and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Apr 15, 2011 | Canon Legria HF200 Flash Media Camcorder
Last winter I dropped my Canon FS100, and the LCD screen would only display black or a grey strobe in camera mode. After a week of what seemed to be repeated attempts to reboot, it "healed" itself! Now a...
It might be that she damaged the lens where you just got it slightly wet. damaged the lens or the CCD that receives the image itself. it might not be repairable at all, If its a case of water damage remove all power sources from it and use a hair dryer on low for a while to dry it out " make sure the screen itself does not heat up to much and focus on the lens. You may have to replace the camera or contact a repair person. I myself give any repair a try and most things with a little luck can be saved.
Mar 28, 2010 | Canon FS100 Flash Media Camcorder
I have a Canon IXUS 800, the shutter won't open properly, just opens about a millimetre. I don't want to break it as otherwise it is an excellent camera. I think it might have some dust in the shutter...
If you truly mean the lens shutter, please see this link.
However, if you are referring to the automatic lens cover that goes over the lens, then see this link instead.
And yes, dust will cause this problem for both issues.
Jan 23, 2010 | Canon Cameras
Download video from my Canon FS100
Use your flash drive and just drag and drop. Plug it into either a port on your computer or on your printer. Open windows explorer to cut and paste your video and photo files from the flash drive.
Jan 16, 2010 | Canon FS100 Flash Media Camcorder
How do you download video clips from a Canon FS100 camcorder?
the easier way its to go on the actual folder and copy /paste ...but ...the actual way ...is to select it just like a picture..and then download....I believe you used only the automatic download until now...but if you cancel that ...it will either open the folder prompt to ask you what to do ...just like you insert a cd...and there select open folder...and copy manually ...or ...open the manager ...select import from device ..and there look for the folders(browse) where the videos are ..it is usually a different one on the card..
...also if you cancel the initial download....you will find the camera storage (SDcard) into the My computer ...as a removable device ......act with it as any other moving from folder to folder...beware if you select cut ...this will remove from the card permanently ...the file
Jul 16, 2009 | Canon FS100 Flash Media Camcorder
Unable to load video to imac
Most cases, with apple product, I did not have much problem compare to PC computers. I'm not a Mac user but we do have hookup at the shp and simply we use iMovie program to edit and test equipment. Here is how we do it. 1. Set the camcorder at VCR mode and play short portion for a few time for operation. 2. open iMovie program, 3. hook up the firewire cable. If this procedure did not produce the connection, you may have a hardware problem. -James
Mar 28, 2009 | Canon FS100 Flash Media Camcorder
The auto lens cover will not open on the canon FS100. Any ideas?? The battery is charged, and it worked this morning. Now it will not open.
I work for canon at one of there return centers. We get this problem on every model the only way to fix it is by replacing the front cover.
Dec 26, 2008 | Canon FS100 Flash Media Camcorder
DCR-HC96 Automatic Lens Cover won't open
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Feb 22, 2008 | Sony Handycam DCR-HC96 Mini DV Digital...
Cameras Logo
167 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
