Question about Hayward SAND FILTER, PRO SERIES
The water seems to be jumping out of the return jet?
The return hose seem sto be almost jumping and the water is jumping in the pool. It almost seems to have too much pressure ot uneven pressure. Our filter is hayward s 180 t
  • 640 Answers
Below is a copy of the users manual for these pool filters. It has a troubleshooting guide and several diagrams that should help you get the pressure problems solved. Hope this helps.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
Posted on Sep 02, 2010
Not filtering
too many chemicals will cloud contact the company website or did you maybe its the water change the water
Feb 28, 2017 | Pentair Tagelus TA 60D Filter
Return port of the intex pump is sucking in water at the top part of the nozzle
If the debris that is getting pulled in is floating, lower the inlet to about 3 to 6 inches under the surface of the water.
Mar 17, 2014 | Intex Above Ground Pool 12x30"" Easy Set...
Pool cleaner will vaccuum but no movement in pool. plenty of water pressure going thru back hose
Before doing anything, take the Jet Vac out of the pool and set it on the deck. Stand clear and turn it on. It should have enough water going through the blue jet to spray several feet and propel the jet vac on dry land.
What propels the Jet Vac is not the water going through the hose, but the water going through the little blue Jet under the Hose. You can unscrew this from the bottom of the shell and clean out any obstructions. Also, check the screen at the connection where the hose meets the wall. It is located in the white valve with the red button on it right at the pool wall. It will unscrew from the wall of the pool with the system off. Also make sure the booster pump is coming on.
Also, it may be stuck in reverse or neutral. If this is the case there will be jets of water shooting forward of the jet vac when it is on dry land.
Apr 15, 2011 | Pentair Jet Vac Venturi Shell Blue Jv2c
It only stays one side of the pool and does not pick up well
First, make sure that your flapper is clean and clear of debris that could cause the pool cleaner to not change position properly. Next, check the return line water flow and redirect it as necessary. Your clean should have come with an "eyeball diverter" to help you regulate the water flow. If you don't have this, you can buy a "wire diverter" from your local pool store (pretty inexpensive). This might seem obvious, but make sure that you have enougth hose to stretch to every end of your pool. Finally, make sure that your cleaner has a proper hose balance.
Apr 26, 2010 | Universal Kreepy Krauly In-Ground Pool...
I got a legend platinum poll cleaner this week and it dosent come up to the shallow end.my slope isnt very steep and the cleaner seems to have plenty of power because it climbs the walls fine.ive tried...
The first thing I would check is the swivels in the hose line. Make sure all of them spin, it not then replace that swivel. You may also want to check the length of the hose, if it was not adjusted to the proper length, this could be the issue also.
Another place to check is other reurn lines. If your pool has more than one return line, check to see if that line is shooting water across the top of the pool, if so, you may want to adjust the flow downward at on angle. The returning water may be stopping the hose and the unit from going to the shallow end.
Jun 27, 2009 | Pentair White/Gray Legend Platinum...
Starting my pool for the first time after winter
Sounds like your hoses are all mixed up on your filter. The filter valve should have labels telling where the hose from the pump to the filter goes, then the filter to the pool.
Jun 17, 2009 | Water Tech Pool Buster Pool Cleaner
My pump pressure is 10psi i cleaned the de filters they seem fine i have good floe out of my jets but when i hook the pool cleaner up pressure drops to almost nothing. could my impeller be the problem
The pressure you are reading is the pressure in the filter tank as water is pumped though it. When the filter is freshly charged, 9 PSI is a good pressure.
As the filter removes particles from the water the filter gets "dirty" -- it takes more pressure to push the water through it thus raising the PSI.
I think you are viewing this in reverse. Low filter pressure is "good" (as long as it stays above 8 PSI) -- as the filter cleans the water the PSI will increase -- when it gets to 15-20 PSI it needs to be back-washed and recharged.
The pressure drops when the pool cleaner is connected because pool cleaners always pull in air (in varying amounts) because of all the hose connections. This causes your filter/tank pressure to drop.
May 25, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Restricted flow
Try cleaning the filter cartridges thoroughly. Also test operation without filter(s) in place, temporarily. Check that any adjustable jets are open and not creating too much back pressure on system.
Apr 16, 2009 | Pool & Spa
Hayward SAND FILTER, PRO SERIES Logo
167 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
