Question about HP iPAQ RX1955 Pocket PC
My sd slot does not recognize my card what can i do
  • HP Master
  • 13,433 Answers
Hi
try another card on it, most likely the connector pins are either dirty or loose or there is something inside that's not supposed to be there.
possible fix is to pull the pins up a little, Just a little so its a little more tight so that the card gets proper contact.
could be a loose connection inside. Hard to say, better take it to someone for testing if the above suggestions don't solve the problem.
Posted on May 26, 2009
Sd ms pro mmc sm xd dv 8000 slot is not recognizing card
Try a different sd card,, chances are your card needs to be replaced.. yes they go bad, sometimes very quickly.
Dec 30, 2012 | HP Pavilion dv8000 Series Laptop DVD Drive...
My SD card reader on my Sony Vaio will not read the card...it seems to know its in the slot, but won't read any data and says 'insert the SD card' if I go to computer and try to read it. Any thoughts?
Take a can of air and blow some into the slot to make sure dust or dirt isn't getting the way of that reader trying to read the sd cards.
If you still get the same message try another SD card in that reader or try to see if another computer will read your SD card, if another computer will read the SD card and the slot still won't recognize the sd cards properly, then you know at that point the reader is bad. If the reader is bad, thats integrated into the motherboard so the motherboard would need to be replaced.
Nov 30, 2009 | Acer Aspire 5610-4648 Notebook
It does not recognize an 8gb sd card in storage expansion.
Your netbook should read SDHC(over 2 GB capacity) memory cards. The problem might be either the card slot driver, Which you should download if a newer one is available. Or in case you format the SD as DOS then it will only have around 2GB of space, You should format it as DOS32 or NTFS so you get the full capacity for the SD card. Some pirated rather cheaper memory cards have a lower actual capacity. With some compression technique the capacity presented is higher than it actually is. If you format it then it will show the real capacity. hope that is not the case!
Good Luck!
Nov 24, 2009 | Acer Aspire One Netbook 8.9" Notebook
Why cant I download my waypoint data to a 2 GB SD card. My Global map 5000c does not recognise the 2GB SD card. Do I need MMC/SD. Can I place the sd card in the slot beside the chart card ?. Thanks
You can place the SD card into the slot beside the chart card.
With the SD card in the GlobalMap unit by itself (take the chart card out), press MENU twice and choose BROWSE FILES. Does the unit indicate that an SD card is present? If yes, the card is working fine in that slot. Try the same thing in the other slot. If it only recognizes the SD card in one of the slots, the other slot is bad and probably won't work with any card. If the card is recognized in the BROWSE FILES menu, but the data that is on the card is not working, there could be compatibility issues with the data and the GlobalMap 5000.
Make sure the GlobalMap 5000 has the latest software update from http://www.lowrance.com/en/Products/Legacy-Products/GlobalMap-5000C/Downloads/GlobalMap-5000C-Software-Update-180/. You might need to get a different, smaller capacity card since your 2GB is not working.
If the 2GB SD card still isn't recognized in the BROWSE FILES menu after the update, the GlobalMap 5000 is not going to work with that 2GB card. You will want to get a different card. I suggest 1GB and smaller.
If this doesn't help, please let me know some more details. Is the 2GB SD card recognized in the BROWSE FILES menu. What are you seeing that makes you determine it does not recognize this card? What files are currently on this card? What kind of card is it (brand, model).
Jul 11, 2009 | Lowrance GPS
Sansa MP3 recognizes 8 gb micro sd card as a 4 gb card
your reader does not support the 8gb device, look for firmware upgrade for the reader
Jun 29, 2009 | SanDisk Sansa e260 MP3 Player
My computer does not recognize my SD 2GB SD Flash Card which I insert into my camera and take pictures. I have a slot on my computer for SD cards. Can I just put the card in the slot and access the...
yes you can directly use the SD card slot, make sure you unlock the write protection before inserting it into the slot if you wish to modify or copy the contents from or to the card.
Jun 24, 2009 | SanDisk 2GB microSD Memory Card
SD Slot doesn't work
If the SD card is a high capacity card (SDHC) the SD slot may not be capable of recognizing it. Suggest to try another SD card. If that still doesn't work find the drivers on your laptop manufacturers website.
May 11, 2009 | HP Compaq Presario V2000 Notebook
My laptop will not recognize my mini sd card (in adapter) but will recognize a regular sd card
mini sd card may need formatting or adaptor may be faulty.
You can buy a USB stick with SD card adaptor slot instead.
Aug 07, 2008 | Computers & Internet
SD SLOT WONT READ 4GB MINI SD REG SPEED
try the 4gb card in a camera or phone. If the card is formatted in fat, it wont be recognized as the fat has a gb limit under 4 I believe. May want to reformat it in a camera or phone with fat32
Jan 24, 2008 | Compaq Presario X1000 Notebook
HP iPAQ RX1955 Pocket PC Logo
90 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
