Question about Lightning Audio Bolt B2.150.2 Car Audio Amplifier
Car amp my amp went out and it's a peace inside with Q10 on it and it look burn out and i was wondering if it can be fix
Wires came loose from one of the subwoofers while driving must've touched metal there was a spark noise and then smoke what is most likely the problem?
You probably burned up the output transistors inside your amp, Ethan. Please try to make reliable electrical connections in the future.
Aug 06, 2014 | Planet Audio BB2400.1 Car Amplifier - 1 kW...
Coming on and then cutting off
could be bad capacitors inside the amp. take a look inside and check to see if the cylinder like things are popping out at the top.cheap fix if so
Jun 22, 2013 | Soundstream Lil'' Wonder Lw5830 Car Amp
Dub4001 overheated now protect light comes on
look around the power input on the amp on the inside and wiggle the capacitors around to see if any of the legs burned up because sometimes the tops don't pop up instead they burn the leg off and just so that u know that amp is not stable at 2 ohms only 1 ohm
Jun 22, 2009 | Ultra Linear UL-2200D Car Audio Amplifier
My mtx 81000d amp is burned in a few different places.
Depending on whats wrong with it, bench fees to check it usually start at $45 and then they will tell you parts and labor. without knowing what burned up its hard to quote.
Jun 03, 2009 | MTX Thunder 81000D Car Audio Amplifier
1991 Explorer not starting
Hello;
Boy the cold weather has wreaked havoc on batteries. Get a new battery. 525 cca seems a bit small, I would put in a higher cca battery just for peace of mind. After you install it, make sure the charging system is working properly.Hope this helps.
Thanks;
Rich
RPM Northwest
Dec 16, 2008 | 2005 Ford Five Hundred
Aardvark Direct Pro Q10 wont intall with windows xp
I NEED A AARDVARK, DIRECT PRO Q10 INTERFACE (CONNECTOR) HOST TO BUY. CAN YOU HELP ME FIND ONE?
THANK YOU,
BRIAN MCBEAN
Feb 17, 2008 | Aardvark Direct Pro Q10 (bundle) External...
Aardvark q10 repair
Try Brentz music in Fort myers florida. brentsmusic.com
Sep 13, 2007 | Aardvark Direct Pro Q10 (bundle) External...
Drivers for windows vista???
this manufacturer no longer exists and only XP drivers can be found, no Vista i'm afraid
Aug 24, 2007 | Aardvark Direct Pro Q10 (bundle) External...
Projection TV wil not cut on.
You should first replace the convergence IC's, both of them. Also make sure all the resistors on the convergence IC's are good and not burnt. That's probably what you smelled burning. Good Luck
Jul 11, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Burnt smell
If something is burnt,something made it burn !! These things dont smoke for no reason. Have the amp checked out, and also have the speakers and all the wiring checked for a partial short. Good Luck
Aug 08, 2006 | Power Acoustik PS2-1600 Car Audio...
Lightning Audio Bolt B2.150.2 Car Audio Amplifier Logo
51 people viewed this question
Top Lightning Audio Car Audio & Video Experts
80stech
Tygh Duval
Tygh Duval
Mark Skinner
Are you a Lightning Audio Car Audio and Video Expert? Answer questions, earn points and help others
