Question about Panasonic Videoprojector PT-LM1E Multimedia Projector
How do i connect my projector with my tv
I wish to watch tv programs through my projector how can i do that? any suggestions
  • khurram589 May 26, 2009
    i've got digital sky box...when i connect the projector with sky box its stays blank wat do i do?
    i dont no im going to have a look and ill let u know
    President:
  • 2,992 Answers
A TV is meant as a video display device, not a source. As such, it might have an audio output to run to something like a home theater amplifier, but it would be a truly rare TV that has a video output as well.
What you should do is connect another device such as a VCR that can act as a TV tuner. You can run the VCR's video and audio outputs to the projector, tune in the channel you want to watch with the VCR's tuner, and you're all set. If you're on a digital cable system and have a converter box, you can use the outputs from the converter box instead of bothering with the VCR.
Posted on May 26, 2009
  • May 26, 2009
    Have you set the projector for the proper input? Some automatically select an active input. On others you have to tell it to use the AV input by going into a setup menu.
Watch TV (Vizio smart Tv)with my projector (Optoma ML 500)
you cant connect a projector to the hdmi on a tv,you have to connect the cable box to the projector
Jul 03, 2015 | Vizio Razor Led M650vse - 65 Class 64.53...
I want to see my TV
Do you mean that you wish to watch Cale TV on your projector? If so, the cable box must be connected to it. Usually using an HDMI Cable and switch box.
Dec 09, 2014 | Samsung Televison & Video
Want to be able to watch netflex via projector
A simple solution would be to connect the projector to a desktop or laptop computer. Simply watch Netflix on your computer and use the projector the same as you would a monitor. Most projectors have several input options as well as laptops or computers that you would attach to it. This is how I watch internet services on my television, as well.
Nov 28, 2013 | Linksys Computers & Internet
I have the Sony VPL CS1 projektor and want to connect it to my tv, so that i can watch television channels on the big projektor screen, is this possible?
if your TV has video output signals for the program you are watching, then you can connect them to the projector.
otherwise you may need to get a cheap digital set top box and tune to the same tv program, and use the video output to feed the projector
May 14, 2011 | Sony VPL CS4 Multimedia Projector
How do you connect the NEC VT560 to project tv pictures
if you have a cable or sattelite box, or a tv with a video output, connect the video output from the box or tv to the video input on the projector. if you have a tv without a video out, you cannot watch tv and change the channels on the projector.
Jan 12, 2010 | NEC VT560 Multimedia Projector
S-video connection from freeview box - only black and white image
It's quite rare for Freeview boxes to have S-video output (even through the SCART). I suggest checking that your box does in fact provide S-video out.
Nov 07, 2009 | Acer Office Equipment & Supplies
Can i watch tv through my epson projector?
Yes, if your projector has a video input. Connect your projector's composite video input jack (usually colored yellow) to your video source. You said you want to use it to watch TV, so you'll want to connect it to the video output of a video tuner (such as a digital TV converter box) or a VCR with a built-in tuner. Set your projector to the video input and you're good to go! If your only tuner is your television, you'll need to check your owner's manual to see if it has an "output" jack. Some do, some don't. If yes, you're in luck. If not, try one of the other sources I mentioned earlier. Good luck!
Mar 30, 2009 | Epson MovieMate 30s Projector
How do I hook my data projector up to my cable TV?
If the TV offers video and audio outputs, you can connect those to the projector. Otherwise you'll need to use a VCR or DVR as the source. In fact, you don't need a TV set at all if the VCR/DVR you use has TV tuning. Hook the video to the projector, run the audio through your stereo system and you're set.
Jan 28, 2009 | Sanyo DS25390 TV
Connecting Hitachi VCR to my Direct TV.
Connect your Direct TV to the Ant. In connection on your VCR. When you want to watch TV, just tune the TV to channel 3 (or whatever channel the Receiver is set for). When you wish to record, set your VCR to that same channel and set your TV to the channel that your VCR outputs to. For simplicity sake, I would suggest setting both systems to channel 3 and just watching your program through the VCR. If you are still using an "off air" antenna, then connect that antenna to the ANT. IN connection on your Direct TV receiver and when you turn off the dish, it will pass the signal through just like the VCR would.
Jan 28, 2009 | Hitachi VTF392A VCR
Will this projector work for HD TV?
While the projector may attempt to display the HD TV, it will be poor quality if a image is displayed at all.
The native resolution is to low as per the specifications. The resolution needs to be at at leat 480P to be compatble with HD TV.
Jul 22, 2008 | Epson EMP S1 Multimedia Projector
Panasonic Videoprojector PT-LM1E Multimedia Projector Logo
934 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
