Question about Nakajima AE-740 Typewriter
Changing tabs and move the right margin over some
I have a Nakajima AE740 typewriter at work. I can't figure out how to change the tabs or the right margin.
  • Nakajima Master
  • 3,594 Answers
On the L. side of the T/W ketboard are the keysmar left, mar right,tab set, tab clear and mar rel. Space to the location thayou want th R. mar and press right mar key, if it stops at the R. mar. press and release the mar rel key. To clear tabs tab to the one you want cleared and press tab clear. To set a tab space to the position and press tab set.
DickyO
Posted on May 27, 2009
Return to tab
Don't confuse tabs and margins, after a return it always goes to left margin. Use the tab key to go from the left to the next place where you set a tab
Jan 30, 2014 | Nakajima AE-740 Typewriter
Change margins on Nakajima AE-740 typewritter
move the carrier with the space bar or the back space to the place you want the new margins and press the left margin key do the same for the right
Jan 28, 2014 | Nakajima AE-740 Typewriter
Clearing margins on a Nakajima AX-90 typewrter
Go to the margin press don't hold the mar rel key, space or backspace to the desired location, press the R. or L. mar key as desired.
DickyO
Jun 14, 2010 | Nakajima AX-150 Typewriter
Cannot release the margins or tabs
Go to the margin, touch and release the mar rel key, space or backspace to desired location, press the margin key you are moving, done.
DickyO
May 13, 2010 | Nakajima AE-830 Typewriter
Need owners manual for Nakajima AE740 typewriter
Contact Nakajima @ 800-809-7138 they are very helpful.
DickyO
Apr 29, 2010 | Nakajima AE-740 Typewriter
How do you clear Tab's
Tab to the position press tab clear. Perhaps the tab you can't clear is really the right margin, to move that tab to it press and release the margin release key, space to the location you like, press R. mar.
DickyO
Apr 20, 2010 | Nakajima AE-830 Typewriter
Beeping
It most likely beeping because it cannot make its resetting movement. That is,it cannot "find-out" where its left margin is. There may be something hindering the actual movement of the print carrier. Check inside the typewriter by lifting up the top cover and move the print unit by hand. It should be able to move from the left to right-hand side of the typewriter unhindered. The shaft that the print unit moves on should be clean and it may have gathered dust etc,so give it a wipe with a clean cloth (lint free) with a small drop of light oil on it.. Replace the top cover and switch on the machine
Nov 05, 2007 | Nakajima AE-740 Typewriter
Changing Margins
Cannot find a picture of this keyboard however the process would be similar to this.  Move (return) the carrier to the left margin. Find the margin release key. It mat be labled M REL.  or M. R. or something similar.
  You may have to use it in conjunction with the code key, if this is the case the M REL or M. R. will be on the front of the key in a different color lettering.
 Press the margin release key and backspace to where you would like the margin and then press the left Margin key.   If these keys require the code key you will need to hold the code key down while pressing the release and set keys.
The right margin will reset in a similar fashion only space past the margin after hitting the release.
Hope this helps.
Oct 24, 2007 | Nakajima AX-150 Typewriter
Nakajima AE-740 Typewriter Logo
349 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Adorjani Laszlo
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
