Question about Dometic RM2652 Refrigerator
Fridge stopped cooling and after about 3 hours had a strong odor of amonia
Refridgeator stopped cooling and about 3 hours had an amonia odor
  • 464 Answers
This is serious problem you have to deal with. since you said you said you smelt ammonia like odour one of the cooling tubes (evaporator ) should have been broken are should contain a small opening or something.do not switch on the refrigerator untill you repair it with an authorized service personnel.do not try disassemble the cooling tubes yourself since incorrect repairing will cause the coolant to evaporate easily and it will cost heavy to replace it.!!!
Posted on May 26, 2009
We have a three way fridge which runs on gas between medium and high but if you turn it down it gos out and won't re ignite
Three way fridge means it is running on Amonia. The first main thing is that the fridge has to be level properly. Otherwise Amonia cooling cycle will not work. If it is on a RV or trailer make sure the fridge is level to the ground not to the RV floor.
Oct 26, 2017 | Refrigerators
Harley overheated while idling , lost oil pressure
Hi Anonymous, why would you let it idle for an hour, what was the outside temperature and do you have an oil cooler? Thank you.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 15, 2014 | Harley Davidson Motorcycles
My Dometic RM2652 fridge suddenly quit cooling. No amonia smell, no yellow residue around cooling unit. Gas ignites, lites work.
what is the yellow residue around heating element? my fridge just isnt working right and sometimes stops all together, the freezer worked until lastnight but fridge hasnt cooled right for a week or so.
Aug 03, 2012 | Dometic RM2652 Refrigerator
Had a strong Amonia smell. Fridge wants to turn on but no cooling.
Strong Ammonia smell is dead give away for LEAK. Ammonia is the chief ingredient in the absorption type cooing system. Probably not economical to repair. For a second opinion, contact a Dometic Authorized Service Center.
Thanks for your question @ FixYa.com
May 31, 2011 | Dometic NDR 1292 Refrigerator
There is a strong odor coming from the freezer something like a fish smell or a burnt wire. The ice maker is working ok and the fan blows air just fine and the freezer and refrigerator are operating just...
The smell could either be the fan motor or the defrost heating coil...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana ABB1927DE Bottom Freezer...
Motorhome fridge not working on 12 volt
if you are using an amonia cherged fridge, the amonia in your system normally cristallises after not yousing you fridge forf a long period of time. try to put the fride upside down for a few hours or a day and the turn it upright again. re connect your 12v to teh fridge and it will certainly work again.
Sep 07, 2009 | Dometic RM2652 Refrigerator
Will not cool. Electric is on and there is a strong amonia smell.
TURN THE FRIDGE OFF AND DO NOT USE!!!! Your cooling unit is leaking!!!! You will need to replace either the cooling unit or the entire fridge. There is usually about a 400 dollar difference in the two. Check your model number and serial number of the fridge and call your local dometic dealer to see if it is under recall. You may be able to have it repaired for free. If you provide me with the model, serial number and serial number of the cooling unit (located in the rear through the door on the tank assembly), I can provide you with this information.
Again, TURN THE FRIDGE OFF and DO NOT USE!!!!!
Let me know what happens,
Jeff
Jul 03, 2009 | Dometic Refrigerators
My Dometic trailer refridgerator is warm but freezer is freezing.
Brandi4723,
Unfortunately, you have a bad cooling unit in your refrigerator. Then ammonia smell means that you have a leak in the unit. TURN THE FRIDGE OFF!!! Do not use the fridge on AC or Gas until you have the cooling unit replaced or buy a new fridge. Depending on the model number and serial number of the fridge, it may be under recall by dometic and you might be able to have it repaired for free. If you will provide me with the model number, serial number and the serial number of the cooling unit (found on the outside of the unit in the fridge compartment, lower tank of cooling unit), I can then tell you the pricing of the repairs or whether it is under recall.
Again, TURN THE FRIDGE OFF and do not use it...RISK OF FIRE!!!!
Hope this helps,
Jeff
Jul 03, 2009 | Dometic RM2652 Refrigerator
My electrolux rm 2310 has stoped working (the beer is getting warm). When used in all 3 modes there is a strong smell of amonia. What do I need to do to fix this? What should it cost to fix?
Classicpark;
The cooling unit has lost it's ammonia/hydrogen. Need to replace cooling unit or entire fridge. Prices for repair are as follows.
Part# 2934334091 $ 482.67 New 2 hour install
Replacement fridge RM2354RB $844.00 1 Hour install The R means right hand door. If the is a left you will need an L hinge kit. $27.00 plus .5 hours install.
Rebuilt cooling unit $400.00 2 hour install
All prices do not include shipping.
I know someone that will supply you with what you need.
Post back and I will give you the link.
Thanks for using Fixya
Jerry
Mar 26, 2009 | Electrolux Refrigerators
Dometic fridge amonia smell.
It is simply a bad cooling unit and that particular piece needs replacing.
I can chose to repair it for around $460 or replace it for about $960.
Aug 02, 2008 | Refrigerators
Dometic RM2652 Refrigerator Logo
107 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
