Question about Yamaha 12V Air Pump
Waveraider will not start with out a shot of starter fluid
Waveraider will fire with a shot of starter fluid but will not stay running
    Champion:
  • 207 Answers
You need to replace the carb kits if u have not already done that riva racing youll find them change the plugs first always
Posted on Jul 09, 2009
  • thomas foster
    thomas foster Jul 11, 2009
    so what was your problem????????????????????????????????? since the carbs didnt need carb kits........ becuase if they did u would have had to leave me more than 2 thumbs up good luck with your problemmmmmmmm
ISO definitive eng compartment pic/diag/schematic of fuel line & line-pressure valve/access, bleed disconnects + alt intake spots 4 starting fluid, beyond air filter intake.
to remove contaminated fuel , pull a fuel line of the fuel manifold and run the pump for a few seconds
not firing is sensor , immobilizer , ignition module problem but you stat that it fires on starter fluid so that cannot be right
starter fluid is a d good way of damaging the engine
a better way is to find and fix the fault
now to try and sort out what you are saying
it is cranking so the starter is good
it tries to run on starter fluid so there is spark to the plugs
it will not run and that indicates a lack of fuel to the injectors
a lack of fuel indicates
1--- a bad fuel pump
2--a vacuum in ht e fuel system from the tank not venting properly(EVAP system)
3--- fuel pressure regulator not working and providing pressure to the injectors
4--- bad injectors --- need cleaning
dump the starter fluid , buy a workshop manual and fix the problem properly
Oct 29, 2016 | Cars & Trucks
My 1991 chevy pick up stopped running I sprayed starter fluid in the carberater and it fired did not check fuel filter because i do not know where it is do you know where it is located
Fuel filter in under your truck, drivers side, close to front door area, on frame rail inner side, if you don't have fuel pressure, more then likely, bad fuel pump.Hope this was very helpful.
Aug 19, 2010 | 1991 Chevrolet K1500
Ran out of gas, won't start. Will start when primed won't stay running. changed filter. getting fuel up to carb just not in. Fuel pump is running.
Try hitting her with a spray of starter fluid only a small amount down the (Carb. as you say) throat, should fire up.
Aug 08, 2010 | Chevrolet Tahoe Cars & Trucks
2009 31cc toro weed eater wont stay running. will fire and run at idle but wont stay running in 1,2,3 settings
get a can of starter fluid and a helper. Start the weed eater and then squirt enough starter fluid into the air intake to keep it running while you move it through the settings. This will rid your tool of the crud that is causing your problem. Joe
May 07, 2010 | Garden
I have to run starter for 45 seconds for engine to start
have you looked at the plugs,and fuel filter also breather
Jul 13, 2009 | 1983 Honda GL 1100 Innerstate Gold Wing
Craftsman 917.270662 starts with starter fluid but won't stay run
the float in the carburator is stuck shut not opening alowing fuel to enter engine
Jun 07, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
99 blazer wont start
need to check your fuel pressure...pump may be running , but not putting out enough pressure
Feb 07, 2009 | 1999 Chevrolet Blazer
The motor runs but you have to spray starting fluid in it 1994 Ford F-350 Crew cab Power stroke
I had the same problem,tried everything,I thought,till starter went out.Put new starter in,now fires right up.It takes 200amps to start and found out on web u can't stay on ignition more than 6 seconds or will burn up starter.I had orginal starter on my 94 so it was time,also change air filter,fuel filter regularly.
Aug 03, 2008 | 1994 Ford F350 Crew Cab
Yamaha 12V Air Pump Logo
375 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
