My sewing machine will not zig zag or back up. I can not find my owner's manual to show me where to put the oil. I need a new owner's manual.
Kenmore machines may have parts and manuals available on searspartsdirect.com -- have the correct model number usually a 3 digit a dot and the rest of the numbers (i.e., 158.xxxx or 385.xxxx1). You will see a list, and if you click on parts or attachments list and scroll down into the parts list, there should be a manual listed as either available or not.
As to the new machines, Euro-Pro or any other, if really cheap, then my personal feeling is that they are planned to not last for a long time -- which may account for the lack of oiling instructions in their manuals. The other possible reason 'may' be that like some Viking Husqvarna machines, the metal parts could be infused with oil and the heat from running them produces the oil needed as it runs. Somehow I doubt that could be the answer in an inexpensive machine. If a lot of the parts inside are plastic, then no oil is needed, and they will run until the plastic breaks, necessitating a trip to the repair shop.
Only use sewing machine oil which can be bought at any JoAnn's, Walmart, sew and vac, or sewing machine dealer. Never use household oil or the yellow/blue can of spray that is a water displacement solution which ultimately will gum up the works. You could use Tri-Flow Superior Lubricant.
Basic oiling procedure is to oil wherever metal parts meet (possible friction points) or slide past each other -- a drop or two usually. No grease needed on plastic gears. If you have an old machine with metal gears, then use sewing machine lube (grease) or Tri-Flow lube (can get it at a bicycle shop if no where else).
I have a euro-pro shark 373. The manual has no instructions for oiling. How do I oil it? Thanks
I have a Kenmore Elite sewing machine (it's probably a 19606, judging by the picture) that I got in 2000. I've gone through the instruction manual line-by-line and nowhere does it mention oiling or lubricating the machine. So--where are the oil ports? How do I lubricate the motor?
I also have a 1950 Singer Featherweight and its instruction manual gives very detailed instructions--why doesn't Kenmore do likewise? (Or is it perhaps that Kenmores aren't made to last 50+ years?)
Thanks,
Robbie
i have a euro pro 420 while i was sewing the needle broke in half after replacing the needle i tried to resume sewing and the needle bar moved up and down and then completly stopped all the machines does at this point is make noie when i step on the petal but the neddle bar does not move. i no longer have my manual and i am not sure how to oil the machine or if this problem is bigger then just oiling if any can help please respond.
i have an older model Kenmore machine... i've been working on a project for the last few weeks... making "banner" flags... 25" x 72", with double seamed edges, etc. i've been running the machine pretty steady and 16 more flags to make... my machine is starting to make a little whining noise that sounds like the belt is tightening.... so... i thought it would be best to oil it a little... however... i don't have the manual and need to know where to put the oil... and how much oil to use.... THANKS... Kathrine =)
I have a singer model 1120 sewing machine and it squeaks a little and I need to oil it, but not sure where and how
Brother Coronado sewing machine
I need to know how to oil my Janome Gem Sewing Machine
i oiled my machine, but it still screeches when i sew
need an owners manual for singer zig zag 758 free
