Question about Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer
Flashing f11 whirlpool duet washer flashing f11 and doors locked
    Brigadier General:
  • 8,619 Answers
Hi
F11 is a Serial Communication Error i.e. communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly. You need to
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
  • Please do rate the solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    Posted on May 26, 2009
    Whirlpool Duet F11
    Seems that the fault is within the main control panel board. It can be due to failure of the drive relay or semiconductor within and might need a board level service or a replacement of the board.
    Jul 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
    We have a whirlpool duet washer that flashes F11 and will not start, I made sure the door shuts tight and also tightened the plastic latch that was loose, still not responding, please advise what you think...
    The F11 error code means that the motor control unit& the central control unit aren't communicating with each other
    It could be a loose wire connection between the MCU/CCU or either one could be defective
    Gene
    Jul 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet Sport Model WFW8300SW0 basket won't
    The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
    If Pause/Cancel does not work:
    1. Unplug washer or disconnect power for one minute.
    2. Plug in washer or reconnect power.
    3. Re-select the cycle and press Start.
    NOTE: If the error remains on the display, call for service.
    I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
    Hope helps.
    Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
    Whirlpool front load washer displays error f did what the manual says but still same problem
    it shows f11,also DL,
    I did change the door lock,
    same alarms.
    it's fine for few wash but when it happens again it just stop and show
    F11.
    Mar 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    My Whirlpool duet washer lights flash/beep
    probably your door then, look at the door itself, at the latch is it broken? should form a complete square hole with four sides. if broken some part is probably inside lock asm. if complete, look at lock and determine if its in the lock position with door open, a arm will be up preventing the latch from going in. replace as necessary. Old duets (red lights) use standard lock asm same as GE and samsung. New duets (green lights) use whirlpool/new maytag unique asm. New locks come in two interchageable models, German (made in china) and Mexican, Mexican model is more troublesome, get german.
    If lights flash during a cycle or other time, its giving a code, note the F code displayed
    Jul 19, 2009 | Whirlpool Washing Machines
    Fdl code message
    >"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
    Door lid is not closed completely due to interference.
    Wash media buildup is preventing the lock bolt from extending.
    Machine/motor control detects open door lid switch when attempting to lock.
    Machine/motor control cannot determine if door lock is in a locked state.
    Check for lock interference with lid or lock bezel
    Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    F dL symbol on Whirlpool duet HT
    It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
    Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
    Whirlpool Duet Washer GHW9150PWO Have F11 and DL errors. Have replaced the door lock 2 x and still have same error messages.
    Well du is a door lock error but it can also mean an error with communication to the main control board or ccu. f11 is also a communication error in either the ccu or the mcu ( motor control board)......easiest thing to try is to unplug all your connections to the ccu and plug them back in and try it again.....sometimes a wire harness just may be loose....if that dosent work I would look at replacing the ccu ( central control unit )
    Jul 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpoo? duet displays F11 and F dl alternatively
    F11 IS A COMMUNICATION ERROR BETWEEN THE DOOR LOCK ASSEMBLY AND THE MAIN PROCESSING BOARD THIS HAS BECOME A COMMON ISSUES WITH THE DUET WM THAT WERE MADE BETWEEN 2003 TO 2006. THERE IS A HAIR LINE CRACK IN THE MAIN BOARD THAT IS CAUSING THIS ISSUE. MFG SUGGEST CHANGING THE MAIN BOARD AND THE DOOR LOCK ASSEMBLY
    If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
    May 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Duet Washer not working after a year
    F11 means that the motherboard is not talking to the computer that contols the drive motor Fdl is a door lock failure code - i had this exact issue with several and the motherboard resolved it, unfortunately it retails at $324.99
    Sep 28, 2007 | Whirlpool GHW9300 Duet Washer
    Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer Logo
    230 people viewed this question
    Top Whirlpool Dryers Experts
    Tim Whalen
    Sal De
    Craig Butler
    Craig Butler
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
