Question about Emerson DTE315 TV
Turns on the shuts off
My daughters DTE314 TV turns on and stays on for about 1 second before shutting off. It shows the picture and sound for that first second.
I had the same exact problem!!!! If you unplug it, then plug it back in after a couple of days. You will hear a frying sound then a loud clap!!!! Solution: Replace it with a LCD.... Not worth getting fixed!!!
Posted on Mar 09, 2010
Once tv is turned on it stays on for about 2 min and shuts off. first the picture and the sound is still going then seconds later it shuts off and the lamp button blinks??/
Sounds like you have a problem that shuts down the Power Supply Unit, PSU, OR indeed more likely a faulty PSU.
In any event it is time for the repairman.
Jan 18, 2010 | Televison & Video
Dell e770 Monitor
It sounds like the picture tube in the monitor has burned out. Time to replace.
Feb 03, 2009 | Dell E770 Monitor
Projection TV keeps shutting down
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi vs-50609 wont stay powered on
Hello nicolastran,
I gave this advice to someone with this same problem so here it is again:
It sounds like your shutdown circuit is being activated. This is due to excess current being drawn. This usually happens in the High Voltage section of the TV or one of the deflection stages. Due to the nature of this problem I would suggest that you take it to a local TV repair shop or have a TV repair person come out and take a look at the issue. The HV section is dangerous and should be dealt with by a qualified TV repair technician.
Thank you,
I hope this helps
Shuttle83
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Tv turns self off when turned on
Does it blink a certain amount of blinks pause a second or just blink constantly with no pauses? Let me know it will blink a code if its going into protected shutdown. And it will blink constantly for another reason.
Jan 22, 2008 | Sony KP-53HS30 53" Rear Projection...
Sylvania SRC21134
This could be a High- Voltage shutdown circuit problem. The reason it will stay on longer with a bright picture, is the high voltage is slightly reduced, not allowing the shutdown circuit to shut off the set. But I believe your problems to be in the shutdown circuit.
Jan 03, 2008 | Sylvania 6413TC 13" TV
On / Off problem
YOUR ON/OFF BUTTON ON THE FRONT PANNEL IS STUCK
SOME HOW (PRESSED IN ) TY SOME WD40 ON IT . SEE IF THAT WORKS.
Dec 12, 2007 | Samsung TXP3275H 32" TV
Emerson DTE315 TV Logo
164 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
