Question about Rowenta Steam Generator DG050 Iron
The iron does not heat up.
The iron itself does not heat up. Is it the thermostat? How do I get that repaired, if that is the problem?
  • Rowenta Master
  • 43,501 Answers
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
Philips 6104 duble speed
follow this test and fix it. God bless you
As with many small appliances, regular maintenance makes a dramatic difference in how trouble free your electric iron will be. Even so, things can happen.
If the iron doesn't heat, make sure power is on to the outlet, check the power cord and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber
If the iron produces too much or too little heat, test the power cord Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Nov 29, 2013 | Philips HI-296 Iron
Straightener nano silver
please make this revision and fix it. God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the power cord , and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the power cord. Also test and, if needed, adjust calibration of the thermostat
If the iron does not spray properly, inspect and clean the nozzle (see below).
Nov 29, 2013 | Irons
Water distiller keeps shutting off
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat.and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat
If the iron does not spray properly, inspect and clean the nozzle .
Test the heating elements and power for blowing fuse.use the DVOM
God bless you. see the diagram 2_6_2013_8_23_01_pm.jpg2_6_2013_8_23_30_pm.jpg
Feb 06, 2013 | Irons
Troubleshooting of flat iron for clothes
follow the steps and use the common sense. God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
Sep 20, 2012 | Irons
How to repair aan electrical iron
If the iron doesn't heat, make sure power is on to the outlet, check the electrical chord, and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical chord . Also test and, if needed, adjust calibration of the thermostat.
If the iron does not spray properly, inspect and clean the nozzle.
If the iron sticks to fabric, clean or repair the sole plate. If the iron stains fabric, clean the sole plate, clean the tank with a commercial cleaner, and use distilled or filtered water.
The tools you will need are
  • Screwdrivers
  • Toothpicks or pipe cleaners
  • Sewing needle
  • Commercial electric iron cleaning solution or vinegar and water
  • Commercial sole plate cleaner or baking soda and water
  • Steel wool
  • Emery cloth
Please rate my solution.
Jun 25, 2010 | Rowenta Professional Luxe DM880 Iron
My iron wont heat up and makes a clicking noise when plugged into socket!!
This is a classic thermostat problem and the sound you hear is the thermostat cycling on & off, because it has gone faulty. You need to repair or replace. If you can find an appliance repair center it is not an expensive repair, however always et a "Quote" before proceeding with any repair.
Jun 15, 2010 | Rowenta Professional DM890 Iron with Auto...
My iron will not heat when plugged into to the wall socket. Tried different places. Light comes on but won't heat. press to reset light stays on.
try opening the iron and see if the wires are connected to the thermostat/heating element, if not you can easily tie them again, it sometimes happens when the thermostat fails to open the circuit and the heating elements over heat and causes a break in the line or heating element.
Feb 07, 2010 | Oreck Cordless Speed JP8100CA Iron
My iron turns off when its hot
Thermostat bad...
heatman101
Oct 09, 2009 | Euro-Pro Shark GI490 Iron
Polti Vaporetto 1000 steam iron - iron not heating
my iron cork handle is coming to pieces can you put new 1 in
Mar 28, 2009 | Irons
The black and decker iron wont heat up
It probably has a high temp overload opened up inside or the thermostat control has gone bad.You can only tell for sure by taking the unit apart and testing the circuit for continuity.The steam feature on the iron is heated by the same element that heats the iron so it wont work.the element itself could also be bad,but I have never seen one go bad.You will have to check each component seperately to find the damaged part.or you can test the whole circuit at the plugs end,and use a jumper across each part until you have continuity through the unit.Make sure the thermostat is turned all the way up.the part that you are bypassing when you get continuity is the bad part.
You can buy a cheap continuity checker at any lowes,or even wallmart for that matter.
Mar 16, 2009 | Black & Decker ICR200 Iron with Auto...
Rowenta Steam Generator DG050 Iron Logo
532 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
