Question about Polaroid 15'' HDTV Monitor FLM-1511
Need to download channels from cable to the TV
I got this TV from a friend, but it didn't come with a user manual or a remote. I need to load the channels onto the TV from my cable service, but I can't figure how to do it. Can you help?
  • 2,404 Answers
Hello. Here is the link from Polaroid to your users manual for the tv:
http://www.polaroid.com/service/userguides/ce/lcd_tvs/flm1511_ug.pdf
What you have to do is from the menu choose channel setting and then let the tv search for the signal and it will load the channels. Page 27 from the manual explains it all. Let me know if I can be of further help.
Posted on May 26, 2009
How can I switch channel from Ant. Over to TV with no remote on a 2006 Sansai tv set
Every TV has buttons that can do all a remote does, check the user manual or google the make and model. user manual for instructions,
Nov 10, 2016 | Televison & Video
Samsung HD tv
Your TV should be an output, only the cables are different.
Let me know the exact model of your tv, and what cable you are using to connect it, so that I can give you more information.
Sep 14, 2008 | Samsung TV Set Top Box Remote Control
Television model tp2784c101 what is the remote control menu/set up to keep channel so it doesn't automatically switch to different channel after 30 seconds; or how can I set it up to turn onto AV1 an
If the TV do not respond to remote control; to change channels, there are many possibilities. Check the infrared emission of the remote control first. Check it with fresh batteries. If the infrared sensor inside the TV is faulty, this kind of fault can happen. In other words, your TV need a through check up, which a normal user can't do with ease. Contact any service technician; or the authorized service centre. Electro help
Nov 18, 2014 | Philips Magnavox 27MS343S 27" TV
I don't now how i recive tv chanels in hd
Your source has to be in HD like a local broadcast TV station currently broadcasting in HD which you get with a VHF/UHF antenna connected to the HDTV. Most primetime TV shows are in HD so using the antenna on the HDTV is all you need. Press MENU on your TV remote and make sure you have ANTENNA set instead of cable to get local TV stations.
You also could use your local cable TV provider. You would need digital cable service and a HD cable box with HDMI or component video cable hookup to the HDTV. HD channels are typically above 100. Call your cable TV provider for more details.
Read your user manual for the LG TV. Ask for help from family, friends, neighbors, local electronics shops.
Mar 13, 2011 | LG 32LG30 32 in. LCD HDTV
I have two remotes. One to turn on the cable box and one to control the TV on/off and volume. When I was watching TV I hit the wrong bottom for the volume and now my TV is just noise and so picture. Can...
If the cable from the cable box is attached to the TV via a coax cable, then all you need to change the TV channel to either Channel 3 or Channel 4. You may have accidentally push the CH button on the TV remote. Please post back what you find.
Mar 11, 2011 | Sharp LC-19SB25U 19 in. LCD HDTV
How do you switch to cable without remote
On the Unit itself, are Buttons, up to seven, 7, of them, usually, ON/OFF, MENU, Channel Up, Down, Volume Up, Down, SELECT/ENTER, Nearly ALL functions available on the remote can be performed via the buttons on the TV. Simply choose menu, and Step through with the Channel & Volume keys, and "Selecting" with the select/enter key. www.scribd.com/doc/.../VIZIO-GV42L-HDTV-Service-Manual
static.compusa.com/pdf/GV42L_HDTV_User_Manual.pdf - United States
Above are your User manual, above that is a service manual.
May 15, 2010 | Vizio GV42L 42 in. LCD Television
Toshiba CF32G50 32" TV - wont turn to channel 3
try entering the channel directly via the remote by pressin"03" if that fails check to see if your cable box has a 3/4 switch on the back. if so set it to 4.
The main problem however, is that the TV needs to have the channels reprogrammed by following the instruction manual and/or on screen menu.
Sep 19, 2009 | Toshiba CF32G50 32" TV
My remote wont change channels
I need to use the cable remote to change the channel and the TV remote to change volume.
That is because your TV is looking at the output of the cable box (probably on channel 3 or 4) so the TV has to be statically tuned to see the cable box's output.
On the second question; I, and perhaps others, can't answer this without spending a lot of time to download manuals for both systems while you have them (presumably, since they are new) on hand. You didn't include the TV's model number anyhow so even that wouldn't be adequate.
The home theatre may have a receiver but what does it receive? Unless it also has channel capabilities that correspond to cable channels, it can't. The typical routing should be from the cable box to the TV S-video input and the sound can be routed separately from the cable box to either/or both, the home theatre's and also the TV's audio inputs.
When I am installing new stuff, I make a sketch of the routing I want (or have) to use. To me, this is less confusing than the supplied instructions.
Feb 01, 2009 | JVC LT-42X579 42 in. LCD TV
Polaroid 15'' HDTV Monitor FLM-1511 Logo
268 people viewed this question
Top Polaroid Computers & Internet Experts
micky dee
Tom Chichester
Steve P
Steve P
Are you a Polaroid Computer and Internet Expert? Answer questions, earn points and help others
