Question about Refrigerators
Fan not working
The fan does not continually run. The fan only comes on for a short time and stops. What's wrong with this fan?
  • Refrigerators Master
  • 4,655 Answers
If this is an older refrigerator it is possable that either the condenser fan or the evaporator fan is worn out. If a fridge has been turned off with the door closed the evaporator fan shaft will rust and stop running. The symptoms of stop and starting of the fan leads me to think that the fan needs replaced. Still yet we will need more Q&A to help you on this problem.
Posted on Oct 21, 2007
  • 473 Answers
What is the entire model # from the sticker inside the fridge?  Which fan are you talking about?  Is the fridge cooling ok?
Posted on Oct 20, 2007
PTAC stops running after a short time
Sounds like a voltage or amp draw issue. So how about if you only try to run the blower??
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 05, 2017 | Heating & Cooling
The freezer stopped working (the fridge is working but not as cold as it should be), I cleaned all the vents and the freezer worked again fro a short time then I heard a noise like possibly the fan...
It does sound like a bad fan motor. With the compressor getting hot you may need to change the start relay, overload and run capacitor if it continues to run like this with a defective fan motor. What is the correct model number? Sea Breeze
The condenser fan motor for a model MZD2766GES is part number=> 61005323 Condenser Fan Motor or here=> 61005323 Condenser Fan Motor
Oct 18, 2013 | Maytag MZD2766GES Side by Side...
Cooling fan continues to run after engine shut off.
The fan runs for a short time, after ignition off, to continue to cool the hot engine.
Dec 10, 2017 | 2005 Dodge Stratus
Radiator fan constantly runs even when ignition is off. It continues until it drains the battery.
Under the hood should be a fuse box with a relay marked for the fan. Remove the relay and see if the fan stops running. It's possible that the relay latched and is stuck. There should be another relay in the panel that is the same as the fan relay. Try swapping them. If the fan continues to run, there could be a short underneath the fuse box (Chrysler/Dodge/Jeep were known for their fuse boxes corroding and shorting), or it's a possibility that the engine computer is telling the fan to run even when off indicating a bad computer. I would lean toward the fuse box however.
Dec 02, 2010 | 1999 Jeep Grand Cherokee
My fridge just stopped working, and no one can tell me what's wrong
Actually it is a long description to explain but in short, defrost fridge/freezer for 12 hours then after cleaning water up, run fridge again. If it continues, there is very possibly a defrost component issue or the fan is faulty.
Jun 14, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Compressor appears to kick in, runs for short time
It sounds like your unit may have a bad run capacitor or start capacitor and relay. Low voltage will also cause this problem. First you need to make sure that you have the full rated voltages at the unit, if you do, then, have the run and start capacitors checked out and the start relay.
May 31, 2010 | Dometic Rooftop RV Air Conditioner
The fans are continuing to run after the car is turned off
thats supposed to happen, its cooling your car down..it will shut off once the car is cooled down
Dec 01, 2009 | 1996 Ford Taurus
GE Central A/C Unit about 30 yrs old; condenser fan stops after a short time.
I gather that it is the outdoor fan motor that runs a bit then stops.
Fan motors that stop by themselves are overheating and going into self-protect. The fact that you replaced the motor and capacitor opens up a whole world of "which wire is in the wrong place". I could do this if I could see it, but I can't see it. You're probably going to wind up calling a service man to sort out the wiring.
Jul 22, 2008 | Heating & Cooling
Refrigerators Logo
780 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
