Question about Insignia IS-LCDTV32 32 in. Television
Water in LCD, sound but no picture
Water got into the works of my LCD TV, from the top slats. The sound is fine but there is no picture. Any ideas?
    President:
  • 814 Answers
This unit is having a problem in the main board. This is the television control board. The video television tuner is not working correctly. Have you tried other signal input sources to see if they are working, like dvd or vcr. If they are then the problem is in the tuner section only. If the other inputs are also not functioning , then it a problem with the video circuits failing.This is a problem that need to tested and serviced in a service center. The service center will have all the correct service information to evauluate the problem and repair it for you. The customer support telephone number for Insignia is. 1-877-467-4289. They also have a costumer support section on their website, which is . www.insignia-products.com. You can also contact Best Buy customer support at this telephone number 1-888-237--8289. Give any one of these support centers the brand name of you television and the model number. Ask them to evaluate the problem and where you can take it for testing and service. I hope this information helps you with your problem.
Posted on May 26, 2009
Samsung LCD TV, no picture, but sound and backlights work. Not t-con board. Any ideas what it could be?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 05, 2015 | Samsung Televison & Video
I have a mitsubishi vs 50707 projection tv, sound but no picture
Is the Lamp ok? Go to the rear of the set and turn on the set with your remote while looking at the vent slats. If you can see a bright light through the vent slats then your Lamp is working. If the lamp is on and you have sound and no pix, then the Digital bd is in what we call "Video Mute" and will have to be replaced. Also make sure that the Lamp Door is installed and the screws are tight
also check to ensure the following.....
1. re-seating the DVI cable on both sides
2. Check to be sure the lamp door sensor is closing (that is not your issue but i thought i would post the complete answer)
3. Check colorwheel is spinning up (should be a low hum, and not sound like a fan)
*** it is very possible it is a failed colorwheel, but the set should go into shutdown, so it is probably not the issue.
4. If the set has sound but no picture replace DMD board....
If the set is working and then just stops working best bet is the DMD ( i would not replace just the dmd it is cheaper in most cases and much easier to replace the lightengine) but if the set just is not working and just failed and is now always not working best bet is the digital board.
If you have an osciloscope you can measure the video signal from the Digital board and see if it is present with the no picture, if it is then it is a bad DMD but if the video signal disappears of then you have a failed Digital board. You can not us a computer USB scope, they can not read most of the data from the digital board since they use multiple scan rates and wont trigger on them for some reason, a old school scope works best i have found, or one of those new LCD scopes that have an auto trigger work well i have found that it is all i use anymore.
you can find a service manual with schematics at a very cheap price at ebay......
regards
iversh
Mar 09, 2010 | Mitsubishi VS-50707 50" Rear Projection...
Rca rear projection sound but no picture
regards
iversh
Apr 08, 2009 | RCA P52926 52" Rear Projection Television
42 inch LG Plasma TV - Lost picture
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Feb 24, 2009 | LG 42LC3R 42 in. LCD TV
Hitachi 43GX10B 43 in. Rear Projection TV has sound, but no picture
regards
iversh
Jul 28, 2008 | Hitachi 43GX10B 43" Rear Projection...
No picture just sound
Your projection tubes are messed up. It's a very expensive fix, just get a working TV off craigslist with a smashed screen and reuse your screen itself (usually 100-200$) or just toss the TV and upgrade to an LCD
Apr 29, 2008 | Mitsubishi VS-6043 60" Rear Projection...
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
Insignia IS-LCDTV32 32 in. Television Logo
129 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
