When i have my cable tv hooked directly from the wall into the Ant A input on the tv i will loose picture and sound for a little while for no apparent reason. It started about 6 months ago and i learned that if i left it on all the time the problem was far less likely to occur but the past couple days its gotten to the point that i cant watch anything that isn't hooked up via s-video or rca jacks through one of the other inputs
    Problem Solver:
  • 18 Answers
Check the tv setup menu for rf input mode [choices will be 'air', cable' and cable hrc'] usuallu when this is set incorrectly, the upper channels will be most affeced, and in most cases the video quality suffers- however, if the set is otherwise functioning properly, it is possible that this setting is not set for the signal you cable provider is sending. in hrc mode, some channels are shifted a half megahertz. good luck
Posted on May 26, 2009
Hooked game system PS3 to tv-cannot get picture or sound
What input are you trying?
Banana Pins or HDMA Cable
Nov 28, 2013 | Televison & Video
How to hook up a cable remote to a Samsung cable box?
    • 1 Examine the back of the your cable box and the back of your Samsung HDTV. Note which cable jacks are of an identical size and color. Those are the ones that can be used to connect the two devices. Samsung HDTVs cluster all the jacks in a single panel near the power cord.
    • 2 Look at the square rectangular boxes labeled "HDMI In." These are for high-definition multimedia interface cables--combination A/V cables that provide the highest possible image and sound clarity. Look at the back of your cable box for an identical jack labeled "HDMI Out." If you see one, connect the two jacks using an HDMI cable. If you don't, you need to use another set of cables to hook up your cable box.
    • Sponsored Links
    • 3 Check for a series of three round jacks labeled "Component In" and color coded in red, green and blue. These are component video jacks, which provide a good HD picture, but not as good as HDMI. If your cable box has an identical set of "Out" jacks, use them to connect the two components.
    • 4 Look for a pair of red and white jacks (possibly connected to a yellow one). These are audio RCA jacks. If you're using component video cables to hook up your cable box, you will need to hook these two up as well: Component video cables don't provide sound. Any cable box that uses component video cables should also have "Out" jacks for RCA audio cables.
    • 5 Find the raised circular jack with a pinhole in the center of a milky white plastic interior. This is the coaxial jack. Samsung HDTVs label them "Ant In." Every cable box should have a corresponding jack labeled "Out" or "Ant Out." If none of the other cable jacks on the cable box match, use a length of coaxial cable to connect the TV to the cable box through these two jacks. You can also use this connection to hook the TV directly to the wall cable.
    • 6 Turn on your TV and cable box, and set the TV to the input jack connected to the cable box. You can do this by pushing the Menu button on the remote, scrolling down to the "Input" option and pushing "Enter." That will let you cycle through the various input options, labeled by cable type (HDMI, component video). Press "Enter" again when you reach the right component, then exit the menu. You should now be able to watch TV as normal.
Read more: How to Hook Up a Cable Box to a Samsung HDTV ' eHow.com http://www.ehow.com/how_4867255_hook-cable-box-samsung-hdtv.html#ixzz2DwgQRtRE
Dec 03, 2012 | Televison & Video
Hi-\r\n Thank you for being here- We were watching our Sharp Flat Screened TV, beautiful nice picture. We noticed when we hooked the cable up for Direct TV in our new home, the input connection point was...
With Direct TV, you should use the video input (composite video- yellow/picture, red/right stereo, white/left stereo)
OR
component video- (green/video, blue/video,red/video white/left channel stereo, red/right channel stereo)
the antenna connector should never be used anymore unless connecting an outdoor antenna or VCR.
if one of your input connectors is damaged, it is not likely that is will be repaired without replacing the entire circuit board (expensive!!!).
just use a different "input"- there are usually at least 3 on most TV's
Apr 12, 2011 | Sharp Televison & Video
I found a SuperNintendo that has been in our attic for many years, however when I conect it upo my TV cannot find the output from the SuperNintendo when it does a search. What frequency or channel does it...
Locate the TV's VHF IN [ANT, CATV, or 75(ohm)] or Cable Connector.
Disconnect the existing cable wire from the TV's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your TV's VHF IN.
Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
Connect the thin wire of the RF Switch (labeled Control Deck) to the back of the Super NES (labled RF Out).
On the back of the Super NES, set the 3/4 switch so that it matches the channel of the TV.
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck to your TV or VCR using the Stereo Audio/Video Cable.
After the system is connected to the TV:
Insert the Game Pak firmly into the Control Deck.
Plug the controller(s) into the front of the Control Deck. Use the far left port for a one player game.
Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
Slide the Power Switch to the On position.
Turn on the TV and set it to the appropriate channel (3 or 4.)
The game image should now be displayed on the TV screen. You are ready to play!
If after following these directions you are not able to view the game, try our Troubleshooting Tips. Note: pictured above is the redesigned Super NES. The original Super NES uses the same hookup steps listed below.
Installation Steps:
Locate the Audio/Video inputs on the back of the TV.
Place the yellow end of the Stereo AV cable into the Video "in" on the back of the TV. Connect the red end of the cable to Audio "in" Right. Connect the white end of the cable to the Audio "in" Left. Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
Note: If you have a mono television with only one Audio input, click here for a diagram of how the hook-up will look. The Y-adapter pictured is optional; you can also simply leave the white cable disconnected instead.
Connect the rectangular (gray) plug of the Stereo AV cable into the "multi out" connector on the back of the Control Deck.
Plug the Controller(s) into the front of the system. Use the far left port for player one.
Plug the AC Adapter into the back of the system . Plug the other end into a wall outlet.
Slide the Power Switch on (toward Game Pak).
Turn on the TV and locate the input select. It is often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The game image should now be displayed on the screen. You are ready to play!
Nov 27, 2010 | Nintendo Super NES Console
Mitsubishi ws-65313 No Picture
YOU HAVE AT LEAST A DOZEN VIDEO INPUTS ,THE BEST IS THE MONOLINK.WHATEVER WAY YOU HAVE IT HOOKED UP .YOU HAVE TO GO TO THE INPUT MANUAL AND PICK OUT THE ONE YOUR ON .IF YOU DONT WANT TO SPENT 30 BUCKS ON A THE DVI-HMDI MONOLINK CABLE.OR 10.00 ON THE R/G/B TRI CABLE ,FIND ANY COLOR CRAPPY LITTLE SKINNY **** SPEAKER JACK CXABLE AND STICKIT IN THE YELLOW INPUT 1,2 0R 3 THEN GO ON THE INPUT SCREEN AND SCROLL DOWN TO WHATEVER INPUT YOU PUT IT ON.AND OF COURSE HOOK IT TO THE VIDEO OUTPUT ON YOUR BOX SIT BACK AND ENJOY THE 480 P RESOLUTION YOU WIL GET WITH A 50 CENT WIRE.
Jan 17, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Great Picture But No sound
Good Day;
Look in owners manual pages 28-35, pay special attention to page 31 and make sure the antenna is connected to ANT-DTV input. Good Luck, big IRISH.
Sep 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Snowy picture
Try to hard reset the tv..Leave it unplugged for 4-6 hours and then plug it again and use..If this did not help Try to contact a service centre or service person because this is probably a hardware problem which definetly needs service and replacement!!...Thank you..
Hope this helps you....
Kind Regards!!
Sep 08, 2008 | Polaroid 3211TLXB 32 in. LCD Television
Loose cable connection plug
tv back cabinet to second hole to fixing cable hooked
Aug 23, 2008 | RCA F27442 27" TV
No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
Feb 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
