I took it apart to clean it because it wasn't grabbing my photo paper. after i finished something is wrong, it's not fitting back together properly. (the part that feeds the paper in the printer)
SOURCE: HP Photosmart 3310 does not recognize paper in tray
This is usually do to a sensor, your correct on that, thers usually a plastic piece that indicates theres paper and its broken or worn.
The other thing is that it may be the little rubber grabber is worn and not grabbing the paper, so the printer thinks thers no paper because nothings going through. These parts can be orderd but are usually costly depending on the printer. If its under warranty, take it back.
Also, check the trey and make sure it isnt a I.D.10.T error and you just set the paper to legal or something. I've made that mistake before.
SOURCE: Will not feed paper. HP Photosmart 2575
This is a very common problem. Apparently HP changed the roller because of this fault.
I've tried cleaning, I've tried making the roller rough. I tried to get HP to send me a new roller but they didn't even reply.
HP are a rubbish company who don't care at all about customers (and their printer software (bloatware) is even more rubbish).
BUT - the solution I found:
The spring that holds the roller down onto the paper is too weak. I bent the end of a straightened out paper clip into a small hook then made another hook-like bend a bit further up (but kept the rest of the clip to use like a handle). the length between the two hook parts is just under 1/2 inch. Don't cut it yet - buy you will need to when it's in place.
Hold the handle end (the bit at the bottom of this sketch) so you can fiddle about in the small space and don't loose the spring altogether.
Find the spring that fixes onto the roller gadget, it hooks onto the printer body. Hook the spring off the hole in the printer body, and then catch the second (double) hook of the paperclip onto the small printed circuit board just by the roller (most of the board is empty - so hook it to the left end of the board).
Then, when it's all in place cut the rest of the paperclip off.
You can see the double hook part once I'd cut off the "handle" piece in the photo:
and here you can see where the spring used to go, and where it fixes with the clip thingy I made.
Of course this is what I did (when I was about to throw the printer away so it was a last chance survival idea), if you loose the spring, stick it onto something that goes sparky-sparky or otherwise kill the machine or yourself I can't take responsibility!
SOURCE: HP Photosmart C4180 won't load photo paper
Remove the rear access cover and clean the black rubber rollers with alcohol.
SOURCE: My HP LaserJet 3050 will not grab and feed paper
Open the top as if you were going to change ink cartridges. Find all rollers yuou can and wipe them with a t-shirt type material dry. Do not use any liquids unless you can get some rubbing alcohol. Turn the wheels and claen them as best as is posible. Open the paper jam door and do the same to all rollers in site. Any way you can get to the rollers, use it. This should solve your problem. Also try fanning your paper before loading it. Thanks, Dana
