Question about Fujitsu Heating & Cooling
Verry noisy defrost.Can you manually put into defrost
2 ton heat pump mini split evap motor has high pitch sound even when speed variates.Also can you manually put unit into defrost.
  • darrenhstanf May 26, 2009
    Thanks unit not even one year old
    dont think its bearings.Voltage to this unit is 254 volts on a 208-230 system Could this cause a problem?
    Guru:
  • 587 Answers
How old is the unit? Usually a high pitch sound in a motor is a dry bearing which eventually will cause the bearing to drag and cause the motor to draw high amps and overheat, some of your older motors have oilers on them that you can oil.
As for manually defrosting your unit, usually you can, by being very careful and opening the wire box cover, on the defrost board there should be two pins that say test, by shorting them together with a screwdriver and holding it for a few seconds it should initiate a defrost. the voltage across the test pins is very low, about 5 volts it won't hurt you or anything and it won't arch or spark.
Posted on May 26, 2009
  • Bill Long May 29, 2009
    I would say the higher voltage will cause problems. I'm not sure about the high pitch noise without personally hearing it, it's possible.
    If you can lower the voltage to 230 volts, you would know for sure
    but it still could be the bearing.
    By running about 10% over voltage that's usually the maximum volts ever recommended or allowed, but the higher voltage will cause the windings and bearings to run hotter, breaking down the bearing lubrication and shorten the life of the bearings and the motor.
    One more thing has this high pitch noise always been there since day one or did it just start?
    If it's always been there you might make sure your return air ducts are not restricted and are large enough, Your installation guide should tell you how to size it or minimum recomendations on size.
What are color of wires that goes to the temperature line switch that controls the defrost cycle?
PDF]4HP13/14 SPLIT SYSTEM HEAT PUMP - Armstrong Air
www.armstrongair.com/_/.../Armstrong_4HP13L_Install_506318-01.pdf
4HP13/14 SPLIT SYSTEM HEAT PUMP .... indoor unit, outdoor unit contains system refrigerant charge for operation ... may be installed with up to 50 feet of line set (no more than ..... The defrost control incorporates 2 pressure switch .... Note: Sensor resistance decreases as sensed temperature increases. Pins/Wire. Color.Missing: tempstar
[PDF]RESIDENTIAL SPLIT HEAT PUMP SYSTEMS
icpindexing.toddsit.com/documents/086477/42808100101.pdf
This Manual Supports Split Heat Pump Units of The Above Series .... two groups is based on a difference in Defrost controls and/or the .... completes a circuit between µRµ ? µOµ in the the thermostat sub-base. 2. .... before connecting line voltage. ...Wire "S1" is the first stage of electric heat through the outdoor thermostat.
[PDF]Trane Installer's Guide Air Conditioner/Heat Pump 4TTZ0 ...
Jan 18, 2016 | Heating & Cooling
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
User manual. Where can I get a copy
Pioneer Mini Split AC - Wholesale Prices, Open to Public‎
Adwww.highseer.com/Pioneer-HVACInformation & Support
Download Manuals, Parts Diagrams
Sales, Technical Brochures & More
Nov 08, 2015 | Pioneer Ductless Mini Split INVERTER Air...
WHAT IS REFRIGERANT SUCTION PRESSURE OF MY 1 TON SPLIT AC?
R22= 70-80psig
R410a=120-130psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
Heat pump runs on electric when outside temperature is higher than cutin
Check your thermostat and heat pump owner's manuals. Thermostat may be programmed to require electric heat at higher temps. Also could be bad outdoor temperature sensor tied to
Heat pump system controls (I had that problem) When was it installed? Warranty thermostat and or Heat pump? Call installer
Thermostat programming is a headache. No help from installer? call customer service heat pump and thermostat. Some possibility of bad installer wiring. There is also a heat pump "defrost" cycle. Usually the Electric coil will turn on to compensate for the Defrost cycle which is just the standard air conditioning mode therefore moves heat from inside to the outside coil to melt the frost. This cycle may be occurring too often. I had that problem. Fixed under warrantee.
Heat pumps are complex machines. The controls even more.
You need a tech, hopfully you are still under warranty.
Hope this helps.
Feb 27, 2015 | Payne 15 SEER R-410A Complete Split System...
Squealing sound from our mini-split!
If it were a car I'd say something to do with the belt. Maybe check that out.
Jan 01, 2014 | Klimaire 24,000 Btu 18 SEER DC Inverter...
I have a Mitsubishi heat pump that runs well but the outdoor unit does not defrost what could be the problem.
Why does my heat pump ice up in Winter?
Heat pumps naturally ice-up in the winter. It is normal for the entire coil to be covered in a white frost and even light ice, during cold weather conditions. However, it is bad for the entire unit to be encased in ice. This indicates ductless heat pump problems which should be addressed quickly to save energy and avoid serious damage to your ductless unit. These systems should periodically go into a defrost cycle. This keeps the unit running efficiently. If the coils are blocked by ice, proper heat transfer between the coil and the outside air will not occur.
How does the defrost mode work?
When the mini split heat pump goes into defrost, the reversing valve inside of the outdoor unit is energized, switching the system from heat to the air conditioning mode. The outdoor coil becomes the hot, the indoor coil becomes cold, and both - the outdoor and indoor fans shut off. This allows the outdoor coil to melt accumulated ice. When the built-in micro-computer analyzes that all ice have been melted, the heat pump heating system goes back to heating mode.
sanyo-mini-split-defrost.pngA cloud of water vapor may be seen rising over the outdoor unit and a "whoosh" sound can be heard as the refrigerant reverses direction. The entire process usually takes up to 10 minutes (depending on conditions).
How often does the system goes into defrost mode?
Ductless mini-split heat pumps have different ways of determining when to go into defrost. The built-in microcomputer determines outdoor temperature, refrigerant pressures, and several other factors. In colder temperatures the system will go into defrost more often than in warmer.
If a ductless mini split heat pump is severely iced-up in the winter it is possible that it isn't defrosting (though there could be many other causes). Let the manufacturer certified technician check your system
Oct 29, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Blower works on all speeds but minimal air comes out
youve got a bad blower motor resister. buy a haynes manual and the resistor and have a windy day again.
Jun 05, 2009 | 2004 Dodge Ram 2500
Heating & Cooling Logo
151 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
