It really depends on the motherboard. The dimension 3000 came with a few different mobos. I happen to have an intel version of the e210882 (which is not the part #, just a UL listing) so I know the pains you are going through. I did a google image search for e210882 until I came across the exact match of my board(pci slots, ram slots, sata, etc.) That gave me the ACTUAL board #. Then I searched for compatible RAM. Mine uses PC4200 DDR2 memory, up to 1GB per slot at 533MHz. 4GB max. Hope this helps!
Ik heb geheugen bijgestoken, deze zijn correct, nu start pc niet meer op, f2 of booten helpt niet,...
(More)
Ik heb geheugen bijgestoken, deze zijn correct, nu start pc niet meer op, f2 of booten helpt niet, ik trachte ook met opstartschijf.... Ik zie dat bios/cmos? niet opstart, op mijn scherm krijg ik enkele seconden "in power safe mode, press any key" ik probeerde al veel, batterij eruit gehaald en vernieuwd, videokaart gewisseld, scherm gewisseld, alle plug ins nagekeken,enz.... Kan iemand zeggen wat er aan de hand is en hoe ik het kan verhelpen, ik trachtte ook het oude geheugen teurg te plaatsen, dit zonder resultaat mvg Jan
i have a new dell inspiron 1525 , my problem is no display but the icons on the disctop can appear...
(More)
i have a new dell inspiron 1525 , my problem is no display but the icons on the disctop can appear during the day for the sun light i mean , the problem begins i closed the screen and the computre was running now the computre can not start unless to remove the buttery but can work normaly if connected other screen how can i solve this problem
intell E210882 DIAGRAM accidentally disconected the power, hd led and front panel wires of mother...
(More)
intell E210882 DIAGRAM accidentally disconected the power, hd led and front panel wires of mother board not sure which goes where. PC is a e machines T3624
Display only shows low 8 bit 800 by 600 Cant get on internet on this machine so need motherboard...
(More)
Display only shows low 8 bit 800 by 600 Cant get on internet on this machine so need motherboard drivers to download direct so i can put on disc to correct
necesito saber el numero impreso del circuito Q8F1 de la tablilla dell E210882. si alguien es tan...
(More)
necesito saber el numero impreso del circuito Q8F1 de la tablilla dell E210882. si alguien es tan amable de pasarmelo se lo voy a agradecer mucho.
