Question about Linksys Wireless-G Broadband Router
Wireless problem my wireless has stopped working. There is no indicator light for wireless on the router. the change that was recently made is: we replaced an existing ethernet cable with a longer one. the device on the other end of the new cable is working, but the wireless is not. i tried powering it down/up - it worked briefly (light flickering and a brief connection made)..then it went down again, i repowered it again and no light came back on. can anyone please advise? thanks.
  • Anonymous Feb 14, 2008
    My wireless router is encrypted and I can't get it to work. I called lenova/IBM and they told me it was my motherboard so I replaced it and my wireless still doesn't work. Can anyone help with having my wireless router on? Thanks Andrew
  • 30 Answers
Linksys Wireless routers have been known to go into a "freeze" mode that a hard reset will fix. The button is usually in the back, or on the bottom. Press and hold this button for 30 seconds, and let the router reboot.
**WARNING** This will cause you to lose your router settings ( password, firewall settings, SSID).
It is recommended, if you can, to back up your settings.
Hope this helps!
Posted on Nov 10, 2007
    Novelist:
  • 173 Answers
Do you still see your wireless n/w name(ssid), if not u might have pressed the cisco s/ms logo .. in to router and that would have changed ur w/ls settings..try to change ur n/w name ssid- and encryption in the router , and check, that would fix ur problem..
of if ur internet service provider is from a cable service try to reset the router for 30 sec and , do a complete power cycle for ur modem and router for 30 sec..(turning off power and then turn it back on )
Posted on Nov 07, 2007
Try re-flash the router with the latest firmware version.
Posted on Oct 21, 2007
Router stopped working
What lights are "on" on the router - what happens exactly when you do the reset - do the lights change at all
leave the unit unplugged for 30minutes - reconnect - does it now work
is it running hot at all ?
Jul 13, 2014 | NetGear WNDR3400 N600 Wireless Dual Band...
Orange light on the router
The color orange indicates that
the Router is not using the SecureEasySetup
feature, while the color white indicates that the
Router is using the SecureEasySetup feature.
When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and
start flashing. After the Router has generated
the SSID and WPA Shared Key, the Cisco
logo will stop flashing and stay white.
So this "feature" can be turned off (meaning the light is off)
On the web-based router setup (192.168.1.1 in web browser) go to Wireless > Advanced Wireless Settings
Secure Easy Setup
This feature allows you to enable or
disable the SecureEasySetup feature. Select Disable to
disable the feature and turn off the button's light. The
feature is enabled by default.
Click the Save Settings button to apply your changes, or
click the Cancel Changes button to cancel your changes.
Dec 11, 2012 | Linksys WRT320N Wireless Router
I have VAIO laptop, model PCG 7Z2L, and just recently I can't get it to work with the wireless lan. It keeps saying that the wireless switch is off eventhough is on. I can't remember if there was a light...
This is a well-known issue with Sony laptops. While the internal wireless adaptor indicates it is working, it really isn't. The best solution is to buy an external wireless adaptor (USB) and disable the internal adaptor. You will find the replacement will work better than the internal unit ever did.
Dec 06, 2010 | Computers & Internet
Wireless indicator light doesn't light up and
The "Wireless" light doesn't indicate that wireless is available, it indicates that wireless is being used.
You need to narrow down your problem statement by what symptoms you are seeing. Does your PC "see" the wireless router? Does the router accept your connection password?
Then follow the troubleshooting script in the user manual at
http://downloads.linksysbycisco.com/downloads/WRT150N_ug,0.pdf
Nov 25, 2009 | Linksys Wireless-N WRT150N Router
Wireless router not working.
Power cycle the modem/router, which ever it is, or both.
Unplug the power, let it sit for about 30 seconds, plug it back in and wait til all the light stop flashing. Internet light may flicker with activity.
May 31, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Router installed yesterday, but not working today. Wireless light indicator is not on
If the wireless light is not lit up on the router , better reset the router, This is the way how you reset it Press and hold the reset button of the router for 25 seconds and then after that power off the router and check the wireless light if its ON then if its ON just reconfigure the router by running the setup CD, but iof the wireless is still OFF have the router replace since its still new....
Apr 30, 2009 | Computers & Internet
Intel PRO 2200BG will not detect any network
This IS the solution: Set it to use 802.11b _ONLY_ Do this in Windows: Start->Settings->Control Panel->System->Hardware->Device Manager->Network adapters->Intel(R) PRO/Wireless 2200BG Network Connection->Advanced->Wireless Mode = 802.11b only Driver version: 9.04.36 (04.04.2007) PROset/Wireless Software: not installed OS: Windows XP
Aug 15, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Wireless LED blinking, normal?
Same problem here - wireless light starts blinking and I get a network interruption. At that point, I have to walk across the house and downstairs to cycle the power on the router to get it working again. What a pain - and the manual doesn't even mention a blinking status for that light. I'm thinking about hooking the router up to a automated power switch (X12) so I can remotely cycle the power.
Dec 17, 2006 | NetGear RangeMax WPN824 Router
Linksys Wireless-G Broadband Router Logo
94 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
