Question about Dishwashers
The spray arms do not seem to be rotating. The dishes are not getting clean and even though we had the spray devices cleaned by a service tech and just ran a full wash cycle with vinegar, the soap dispenser isn't fully cleaned of soap and the dirtiest of the dishes are still soiled.
    Problem Solver:
  • 14 Answers
Probably the pump is bad
Posted on May 26, 2009
Dishes on top shelf not getting clean
Check your upper wash arm.... check the holes, especially the ones at the end of the arm. Are they possibly clogged with debris or hard water? This is the usual cause of dishes on the top rack not getting clean. The holes at the end of the wash arm are angled to eject the water at an angle to use the reaction to push the wash arm around. If those holes are clogged, then the arm won't rotate, and only those few dishes or glasses right under the arm will get clean, and the remaining 80% of the dishes on the upper rack won't get clean!
Sep 13, 2014 | GE Dishwashers
My dishes are not getting clean and the door doesn't seem to even get wet. It looks as if the top and middle spray arms are not turning. Both spray arms are cleaned out.
I would suggest you check de waste filter and pump. Normally, such electric devices have a protection that prevents water getting inside if waste water cannot be cleared.
Mar 03, 2011 | Dishwashers
Even though I turned up the thermostat on my hot water heater, the water in the dishwasher does not seem to be hot enough. Mold is growing in the food grinder and even though I choose the heat dry option,...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Oct 25, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Dishes are cloudy and have soap residue. Have cleaned upper &lower spray arm often, as good as posible (find holes plugged). water level & temp. seems normal . Water intake screen appears clean
Clean the spray arm jet holes if they are blocked. Check whether you have filled the rinse-aid dispenser.
Check whether arm turns freely when rotated by hand manually.
May 26, 2010 | Maytag MDB9600A Jetclean II Built-in...
Spray arms not rotating
Check pump in the dish washer. Clean and check!
Apr 28, 2010 | Neff S5946 Built-In Dishwasher
Lower dishwasher arm not rotating
Probably blocked spray arms is the cause of the unit not cleaning properly or rotating. Remove each spray arm (there are 3 in total) and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Jan 25, 2010 | GE Dishwashers
Model DU40JV does not clean dishes.
hello when you load the machine make sure the spray arms rotate freely i'e the forks an knifes are not sticking through the bottom of the plastic tray. also check the arms for strapped food in the holes hope it helps
shaun
Jan 13, 2010 | Dishwashers
Only washing top rack
After observing the water just gushing out when the spray arm was removed, we determined there was still a bunch more calcification/soap in the ends of the spray arm. (We have very hard water in our area). Unfortunately, you cannot open up the spray arms to clean them out, so it took about 30 minutes of pounding and manipulating to get all the gunk out. Now my dishes are clean again. Hallelujeh! And the water cleaning the dishes is cleaner, as well.
Jan 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
The dishes no longer get clean even though the water is getting through....are there filters I need to clean or could the soap dispenser be a problem....please help
there are filers in the inside bottom of the machinbe which should be taken out and cleaned regularly.
problem may be that the spray arms are not rotating. open the door when in cycle and check each arm rotates(you will get a bit of water out)
if they are not, the problem is probably debris in the arm so take them out and clean (this is quite tiresome to do and the usual culprits are rice and sweetcorn)
the arms only rotate by water sqirting out of angled jets at the end of the arm and if these are blocked then arm doesn't turn
Jul 12, 2008 | Dishwashers
Maytag Jetclean Super Quite Plus II Dishwasher
open the door when working and check the spray arms are rotating. if not, the jets in the spray arms may be blocked. very fiddly to clear but doable
Apr 07, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
139 people viewed this question
Top Dishwashers Experts
