Question about Black & Decker Mouse Sander/Polisher
Mouse - it blew up - a little
I plugged it in after a year of neglect, turned it on and there was a noise and a burnt smell. can i fix this - is these a fuse in it that can be replaced or is it dead once this occurs?
  • David Ford
    David Ford May 11, 2010
    really depends on what blew up means. No there is no fuse and if it doesn't work it could be a couple things e.g. brushes switch, cord. I would go to Dewaltservicenet.com and type in your model number to look at a breakdown before you throw it away.
What could be wrong with my ford 302 motor for my oil to be thin and smell like gas is mixed in it?
it could of warped if core plugs blew owt, and running rich mixture if smells of petrol
Nov 01, 2012 | Ford Mustang Cars & Trucks
Heater shrieking when cold for about 15 seconds, smelled burnt wires and now only high heat setting works.
replace the blower motor and the blower motor resistor....bad motor blew out resistor and went to d\efault mode which is high setting only...good luck...Lee
Feb 22, 2012 | 1999 Jeep Grand Cherokee
I think I blew the fuse on the machine... heard a loud pop followed by the smell of something burnt... Please tell me this can be fixed...
If there was a bang and a burnt smell then you have destroyed the breadmaker. It would be cheaper to buy a new one than trying to get it repaired.
You should have connected the breadmaker to a stepdown transformer from 240 volts to 110 volts.
Nov 25, 2011 | Cuisinart CBK-200 Bread Maker
When I turn on the fan past the 3 speed it sounds like a low,loud, growling sound like it has airplane engines turning on. I also smelled a fowl odor in side my car, my husband thinks a field mouse is in...
It's very possible that a mouse has gotten into the duct work and ended up trapped inside the blower motor fan. The now dead mouse would cause the blower fan to be out of balance & wobble considerably and make noise plus it would smell quite a bit. I see a handfull of dead mice in blower motor fans each year so it's not all that uncommon. The fix is to remove the blower motor and clean out all the debris. Most of the time the blower and fan are fine and can be reinstalled once they are cleaned up. Hope this helps you find your problem!
Jul 12, 2010 | 2000 Honda Accord
Microwave not heating and giving burnt plastic smell
STOP USING IT!! UNPLUG IT!! Microwaves are inexpensive now. It will cost you more than a new one costs, to get it fixed.
Apr 02, 2010 | Microwave Ovens
Amcor dehumidifier motor running very slowly
Hello Filter neglect is a popular cause of problems.20yrs you got your moneys worth the unit dosent owe you a thing.Burning smells sounds dangerous.Please look into replacement.
Mar 31, 2010 | Dehumidifiers
Vizio L32 HDTV - Blew Out, No Power
Yes, I do in home warranty work on vizeo, it sounds like you need a power board and perhaps a main board. The power board is what pooped.
Nov 13, 2008 | Vizio L32 32 in. LCD HDTV
Frigidaire side by side ice maker, water and ice dispencer inop
It would depend on the age of the refrigerator whether repair is economical. If the refrigerator is under ten years old repair it. If it is over ten years old you have to consider how much life is remaining for the refrigerator. Burnt smell source must be located because that is the key to your problem. It could be a simple matter of replacing the switch in the door.
Jul 05, 2008 | Refrigerators
Kenwood KDC-X890 won't turn on
maybe a fuse blew out or maybe a wire came loose. check the fuses first then check the wiring make sure everything is cool. then smell the cd player if it has a funky burnt smell kind of like burnt olives or almonds it blew the diode and its toast.
Dec 08, 2007 | Kenwood KDC-X890 CD Player
Black & Decker Mouse Sander/Polisher  Logo
239 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
